Kiến Thức Linux Monitoring
How to Install Checkmk Using Docker Compose: A Step-by-Step Guide
Checkmk
Checkmk is a powerful and flexible monitoring solution that supports monitoring of networks, servers, cloud services, containers, and applications. In this guide, we’ll walk through how to install Checkmk using Docker Compose — a quick and efficient way to get started with minimal setup.
Before we begin, ensure you have the following installed on your Linux system:
  • Docker
  • curl
If Docker is not installed, follow the instructions on the Docker official site to install it first.
Step 1: Install Docker Compose
Start by installing Docker Compose, which is required to manage multi-container Docker applications.
version="v2.14.2"
curl -L https://github.com/docker/compose/releases/download/$version/docker-compose-linux-x86_64 -o /usr/local/bin/docker-compose \
&& chmod +x /usr/local/bin/docker-compose \
&& docker-compose --version
This command downloads and sets the correct permissions for Docker Compose.
Step 2: Set Up Directory Structure
Now create a directory to store Checkmk’s configuration and data.
mkdir -p /app/checkmk/data
cd /app/checkmk
Step 3: Create Docker Compose File
Next, create a docker-compose.yml file to define the Checkmk container:
cat << FLAG | tee docker-compose.yml
version: "3.6"
services:
  check-mk:
    image: checkmk/check-mk-free
    hostname: checkmk
    restart: unless-stopped
    volumes:
      - /etc/localtime:/etc/localtime
      - ./data:/omd/sites
    ports:
      - "5000:5000"
    ulimits:
      nproc: 65535
      nofile:
        soft: 20020
        hard: 40040
    environment:
      - CMK_LIVESTATUS_TCP=on
    tmpfs:
      - /opt/omd/sites/cmk/tmp:uid=1000,gid=1000
FLAG
docker-compose -f docker-compose.yml up -d
Step 4: Launch the Container
Run the container in detached mode:
This starts Checkmk in the background.
Step 5: Retrieve the Admin Credentials
Once the container is up, check the logs to get the auto-generated admin password:
docker logs -f checkmk-check-mk-1
Look for output similar to this:
The admin user for the web applications is cmkadmin with password: jgOdDfYa
You can log in with this default user and change the password later if needed.
Step 6: Access the Web Interface
Open your browser and visit:
http://localhost:5000/cmk/check_mk/
Use the credentials provided in the logs:
Username: cmkadmin
Password: (Your retrieved password)
Optional: Manage from the Command Line
For advanced operations, you can switch to the site user via Docker exec:
docker exec -it checkmk-check-mk-1 su - cmk
You can then use commands like:
omd start
cmk-passwd cmkadmin
You now have Checkmk running in a Docker container using Docker Compose. This setup provides a flexible and fast way to deploy a monitoring solution without installing anything directly on your host OS. Stay tuned for more tutorials on configuring services and adding hosts to your Checkmk environment.
