Hướng dẫn cài đặt Janus WebRTC Server trên Ubuntu
Janus
Janus is an open-source WebRTC server designed and developed by Meetecho. Janus has great documentation for the user on how to install and use them, you can see the original post on their github. This tutorial hopefully will make it even easier to start Janus. In addition, we will also create a systemd & logrotate service for Janus, so it will be easier to manage.
Prerequisite
Ubuntu 18.04. We are testing this installation on Ubuntu 18.04, but it may also work on another version of Ubuntu.
Sudo Privileges
Before starting, we make sure that we will have no permission issues on the installation & configuration.
sudo su
Install Dependencies Available in Package Manager
Install dependencies using the apt package manager
apt install libmicrohttpd-dev libjansson-dev \
    libssl-dev libsofia-sip-ua-dev libglib2.0-dev \
    libopus-dev libogg-dev libcurl4-openssl-dev liblua5.3-dev \
    libconfig-dev pkg-config gengetopt libtool automake \
    git python3 python3-pip make cmake ninja-build
Install libnice
To install libnice, we need another dependency called meson. The easiest way to install it is using pip3 by running this command:
pip3 install meson
To confirm the installation, run:
meson -v
You should get version 0.58.1 or higher.
After installing meson, go to your home directory:
cd ~
Clone the libnice repo from the GitLab
git clone https://gitlab.freedesktop.org/libnice/libnice.git
Go to libnice directory
cd libnice
(optional) It is up to you to run which version of libnice, the documentation didn’t provide the detail. But the latest commit we already tested is the commit number a0cfef7. To move libnice to that commit run this command:
git checkout a0cfef7
Install libnice using meson:
meson --prefix=/usr build && ninja -C build && sudo ninja -C build install
Install libsrtp
Before we install libsrtp, make sure you don’t have them installed:
apt list libsrtp*
If you have installed them, uninstall them first
apt remove --purge libsrtp*
After no libsrtp installed in your machine, go to your home directory:
cd ~
Download libsrtp v2.2.0 from GitHub
wget https://github.com/cisco/libsrtp/archive/v2.2.0.tar.gz
Extract the package
tar xfv v2.2.0.tar.gz
Go to the libsrtp directory
cd libsrtp-2.2.0
Run these commands to configure, compile, and install libsrtp
./configure --prefix=/usr --enable-openssl
make shared_library && make install
Install usrsctp
Go to your home directory:
cd ~
Clone usrsctp from the GitHub
git clone https://github.com/sctplab/usrsctp
Go to the usrsctp directory
cd usrsctp
(optional) It is up to you to run which version of usrsctp, the documentation didn’t provide the detail. But the latest commit we already tested is the commit number 965b19a. To move the branch, we can run this command:
git checkout 965b19a
Run these commands to compile and install usrsctp
./bootstrap
./configure --prefix=/usr --disable-programs --disable-inet --disable-inet6
make && make install
Install libwebsockets
Although it is optional, most conference use cases will use WebSocket for webrtc control plane. so it is very recommended to install this library.
cd ~
Clone libwebsockets from the repository
git clone https://github.com/warmcat/libwebsockets.git
Go to libwebsockets directory
cd libwebsockets
Use the stable version of libwebsockets
git checkout v3.2-stable
Create a directory named build and go to the directory
mkdir build
cd build
Run these commands to compile and install libwebsockets
cmake -DLWS_MAX_SMP=1 -DLWS_WITHOUT_EXTENSIONS=0 -DCMAKE_INSTALL_PREFIX:PATH=/usr -DCMAKE_C_FLAGS="-fpic" ..
make && sudo make install
Install Janus
cd ~
Clone Janus project from the repository
git clone https://github.com/meetecho/janus-gateway.git
Go to Janus directory
cd janus-gateway
(optional) It is up to you to run which version of Janus, you can check the list of the versions here. But the latest commit we already tested is the the v0.12.0 version. To move the branch, we can run this command:
git checkout v0.12.0
Generate Janus configuration file
sh autogen.sh
Run these commands to compile, build, and install Janus
./configure --prefix=/opt/janus
make
make install
Create Janus default config file
make configs
Right now, you have already installed the Janus webrtc server. you can find all the Janus config files here:
/opt/janus/etc/janus/
Create Systemd File
Create a janus systemd file
nano /etc/systemd/system/janus.service
Copy this script
[Unit]
Description=Janus WebRTC Server
After=network.target
[Service]
User=root
Nice=1
Restart=on-abnormal
LimitNOFILE=65536
PIDFile=/tmp/janus.pid
ExecStart=/usr/bin/sudo /opt/janus/bin/janus
[Install]
WantedBy=multi-user.target
And then exit and save,
After that reload the daemon service
systemctl daemon-reload
Check weather the systemd file is working properly
service janus status
service janus start
service janus stop
Create Logrotate File
Before creating logrotate, I want to inform you that you can choose where Janus will write the log file. First, edit your Janus configuration to determine the log location:
nano /opt/janus/etc/janus/janus.jcfg
Search for the log_to_file phrase and set your desired log location. In this tutorial, I will place the log file in the common log directory on ubuntu: "/var/log/janus/janus.log"
Create the log folder
mkdir /var/log/janus
Create a janus logrotate file
nano /etc/logrotate.d/janus
Copy this script
/var/log/janus/janus.log {
        daily
        missingok
        rotate 7
        compress
        delaycompress
        notifempty
The file /var/log/janus/janus.log should be created automatically when Janus service started, if not, you can create the file by writing this command:
touch /var/log/janus/janus.log
That’s it! Congratulation you successfully installing Janus WebRTC Server in Ubuntu 18.04.
https://congdonglinux.com/janus-la-gi/
