Setting up a VoIP server can be a daunting task, but with Asterisk on Ubuntu 22, you can create a robust and scalable communication system. Asterisk is a powerful open-source software that enables you to develop a variety of communication applications. In this guide, we’ll walk through the steps to install and configure an Asterisk VoIP server on Ubuntu 22, ensuring you have a fully operational setup by the end.
- An Ubuntu 22 server
- Root or sudo privileges
- Basic knowledge of Linux commands and the terminal
- Internet connection
Installing Dependencies
Before installing Asterisk, you need to update your package lists and install the necessary dependencies. Open your terminal and execute the following commands:
sudo apt upgrade
sudo apt install -y wget build-essential subversionDownloading and Installing Asterisk
With the dependencies in place, you can now download and compile Asterisk:
cd /usr/src
sudo wget http://downloads.asterisk.org/pub/telephony/asterisk/asterisk-18-current.tar.gz
sudo tar xvf asterisk-18-current.tar.gz
Change into the extracted directory and install additional required packages:
cd asterisk-18*
sudo contrib/scripts/install_prereq installNow, proceed to compile and install Asterisk:
sudo ./configure
sudo make menuselect
sudo make
sudo make install
sudo make samples
sudo make config
sudo ldconfigWith Asterisk installed, you can now set up its user and group permissions:
sudo adduser --system --group --no-create-home asterisk
sudo chown -R asterisk:asterisk /etc/asterisk
sudo chown -R asterisk:asterisk /var/{lib,log,spool}/asterisk
sudo chown -R asterisk:asterisk /usr/lib/asteriskConfiguring Asterisk
Editing the main configuration file is the next step. Open it using your favorite text editor:
sudo nano /etc/asterisk/asterisk.confMake the necessary changes according to your setup, then start and enable Asterisk at boot:
sudo systemctl start asterisk
sudo systemctl enable asteriskEnsure that Asterisk is running without issues:
sudo asterisk -vvvrSetting Up SIP Accounts
To handle VoIP calls, you need to set up SIP accounts. Edit the sip.conf and extensions.conf files:
sudo nano /etc/asterisk/sip.conf
sudo nano /etc/asterisk/extensions.confAdd your SIP users in sip.conf and dial plan in extensions.conf.
Testing the VoIP Server
Finally, connect a SIP client to your server using the credentials you created and test making and receiving calls.
Setting up an Asterisk VoIP server on Ubuntu 22 is a straightforward process if you follow the steps carefully. With Asterisk, you’re now equipped with a flexible and powerful communication tool that can be scaled and customized to fit your needs.
