What is Ingress Controller and how to deploy Nginx Ingress Controller in Kubernetes Cluster on AWS using Helm
Before we proceed with the installation of the Nginx Ingress Controller, let’s see in short what Ingress and Ingress Controller is. The focus of this article is on the setup, it is assumed that you are familiar with all the prerequisites for setting up Nginx Ingress Controller in the Kubernetes Cluster.
Kubernetes Ingress
It is a Kubernetes object that manages external access to the services in the Kubernetes Cluster. It exposes HTTP and HTTPS routes from outside the Kubernetes cluster to the services within the Kubernetes cluster.
Ingress Controller
To use Ingress, you must have the Ingress Controller in the Kubernetes cluster. It does not come as part of the Kubernetes cluster like other controllers in the cluster, it does not start automatically in the cluster. We can deploy any number of Ingress Controllers in the Kubernetes cluster. To do so, we should annotate each ingress with the appropriate ingress.class. There are a lot of different types of Ingress Controllers available.  Ingress Controller is a LoadBalancer for Kubernetes Environments. It is used as a traffic management solution for Kubernetes environments.
In this article, we will see the installation of the Nginx Ingress Controller using Helm on the Kubernetes Cluster set up using Kops. To know about Nginx Ingress Controller in detail, visit the official documentation here.
  1. AWS Account ( Create if you don’t have one).
  2. Kops 1.18.2 installed on your machine(Click here to learn to create a Kubernetes Cluster using Kops and know more about it.)
  3. Helm v3.5.3  (Click here to learn to install Helm on Ubuntu Server)
  4. S3 Bucket ( Click here to learn to create an S3 Bucket on AWS).
  5. Domain Name (Click here to learn to register a Domain on AWS).
  6. IAM Role with admin permissions(Click here to learn to create an IAM role on AWS).
What will we do?
  1. Create a Kubernetes Cluster using Kops
  2. Setup Nginx Ingress Controller using Helm
  3. Create a Recordset in Route53 pointing to the LoadBalancer created by the Nginx Ingress Controller
  4. Create Object definition files for a sample application
  5. Deploy a sample application
  6. Deploy an Ingress Object
Before you proceed with the creation of the cluster, export your AWS IAM User access and secret keys using the following commands.
export AWS_ACCESS_KEY_ID=<your-aws-access-key-here> #Export AWS Access Key
export AWS_SECRET_ACCESS_KEY=<your-aws-secret-key-here> ##Export AWS Secret Key export
Now, export the KOPS_STATE_STORE variable with value as S3 bucket name on your terminal.
KOPS_STATE_STORE=s3://<s3-bucket-name>
If you are creating a cluster for the first time using Kops and using the above specified S3 Bucket for storing cluster configuration, you should not see any clusters when you try to get clusters using the following command.
kops get clusters
Visit the documentation specified in prerequisites to understand Kops in detail. Here, to create a Kubernetes cluster execute the following command by replacing values. I will not go into detail here.
kops create cluster --name <subdomain.domain.com> --state s3://<s3-bucket> --cloud aws --master-size t2.small --master-count 1 --master-zones us-east-1a --node-size t2.small --node-count 2 --zones us-east-1a,us-east-1b,us-east-1c
Kops command to create a K8S cluster
You can see a few commands in the suggestion.
Out of the previous command
Now, this time if you try to get cluster configuration you will see the cluster name in the output along with Cloud and Zones.
Get clusters
Till this point, the cluster has not been created, execute the following command to update the Cluster configuration.
kops update cluster --name kops.devopslee.com
Dry run update cluster
You will still need to execute the above command with –yes as an option so that cluster resources get created.
kops update cluster --name kops.devopslee.com --yes
Update the cluster to create cloud resources
Validate if the cluster is ready or not.
kops validate cluster --wait 10m
Validate the cluster
You need to wait for some time while the cluster becomes healthy.
Successful cluster validation
Once the cluster is healthy, you can check the default pods across all namespaces using the following command.
kubectl get pods -A
Check default pods in all namespaces
Once the Kubernetes Cluster is ready and healthy, you are good to go and install Nginx Ingress Controller using Helm.
Before you proceed, verify that you have Helm v3.5.3.
Note: I have used Helm binary present at my current location, hence you can see ./helm in screenshots.
helm version
Helm Version
Add the repo and install the Nginx Ingress Controller Helm chart using the following commands. To understand Helm, refer to the documentation mentioned in the prerequisites section.
helm repo add ingress-nginx https://kubernetes.github.io/ingress-nginx
helm repo update
helm install nginx-ingress ingress-nginx/ingress-nginx --set controller.publishService.enabled=true
In the above screenshot, you can see that the Helm chart has been installed.
You can check the resources that have been created as part of the Ingress Controller.
kubectl get pods
kubectl get deployment
kubectl get service
Objects created by Ingress Controller
In the above screenshot, you can see that the Service “nginx-ingress-ingress-nginx-controller” of type LoadBalancer has also been created. It means a LoadBalancer has been created in the AWS account.
Go to your AWS account in the region where you created your Kubernetes Cluster. Check the LoadBalancer and copy its DNS Name.
LoadBalancer created by Ingress Controller
Now, go to Route53 and create a single A Record in the HostedZone.
Create a RecordSet
Once we create a valid record, the record we created will be used to route traffic to Kubernetes Cluster through the Nginx Ingress Controller we created. In this case, kops.devopslee.com will route traffic to Services in the Kubernetes cluster through the Nginx Ingress Controller.
Now, let’s create object definition files to deploy a sample application. We will deploy 3 applications using 3 Deployments and 3 respective Services for the deployments. We will then create an Ingress resource with path-based routing to route traffic to our applications using kops.devopslee.com based on the path.
Create 1-nginx-main-app.yaml for application 1.
Github Link: Click here to copy the file from my Github repo.
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
run: nginx
spec:
replicas: 1
selector:
matchLabels:
run: nginx-main
template:
metadata:
labels:
run: nginx-main
spec:
containers:
- image: nginx
apiVersion: v1
kind: Service
metadata:
spec:
type: ClusterIP
ports:
- port: 80
targetPort: 80
selector:
run: nginx-main
Create 2-nginx-green-app.yaml for application 2.
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
run: nginx
spec:
replicas: 1
selector:
matchLabels:
run: nginx-green
template:
metadata:
labels:
run: nginx-green
spec:
volumes:
- name: webdata
emptyDir: {}
initContainers:
- name: web-content
image: busybox
volumeMounts:
- name: webdata
mountPath: "/webdata"
command: ["/bin/sh", "-c", 'echo "<h1>I am <font color=green>GREEN</font></h1>" > /webdata/index.html'] containers:
- image: nginx
volumeMounts:
- name: webdata
mountPath: "/usr/share/nginx/html"
apiVersion: v1
kind: Service
metadata:
spec:
type: ClusterIP
ports:
- port: 80
targetPort: 80
selector:
run: nginx-green
Create 3-nginx-blue-app.yaml for application 3
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
run: nginx
spec:
replicas: 1
selector:
matchLabels:
run: nginx-blue
template:
metadata:
labels:
run: nginx-blue
spec:
volumes:
- name: webdata
emptyDir: {}
initContainers:
- name: web-content
image: busybox
volumeMounts:
- name: webdata
command: ["/bin/sh", "-c", 'echo "<h1>I am <font color=blue>BLUE</font></h1>" > /webdata/index.html'] containers:
- image: nginx
volumeMounts:
- name: webdata
apiVersion: v1
kind: Service
metadata:
spec:
type: ClusterIP
ports:
- port: 80
targetPort: 80
selector:
run: nginx-blue
Create 4-ingress.yaml for creating path-based Ingress rules.
apiVersion: extensions/v1beta1
kind: Ingress
metadata:
annotations:
nginx.ingress.kubernetes.io/rewrite-target: /
spec:
rules:
- host: kops.devopslee.com
http:
paths:
- path: /
backend:
serviceName: nginx-deploy-main
servicePort: 80
- path: /blue
backend:
serviceName: nginx-deploy-blue
servicePort: 80
- path: /green
backend:
serviceName: nginx-deploy-green
servicePort: 80
You can find all these files on my Github repo here.
Deploy sample applications
Let’s deploy sample applications one by one and check their status.
kubectl apply -f 1-nginx-main-app.yaml
kubectl apply -f 2-nginx-green-app.yaml
kubectl apply -f 3-nginx-blue-app.yaml
kubectl get deployments
kubectl get pods
kubectl get service
Now, it’s time to create a path-based routing Ingress resource. At the same time, check logs of the Nginx Pod.
kubectl logs nginx-ingress-ingress-nginx-controller-5c97c6b4d5-btvpl -f
kubectl apply -f 4-ingress.yaml
Create an Ingress resource and check nginx-ingress pod logs
As soon as the Ingress resource is created, you can see that the Nginx has loaded its configuration.
And now, 3 different applications are ready to be accessed using the same Host Name, i.e. kops.devopslee.com, on different paths.
URLs for the applications, the Hostname here name will be different for you.
nginx-deploy-main can be accessed on kops.devopslee.com
nginx-deploy-green can be accessed on kops.devopslee.com/green and
nginx-deploy-blue can be accessed on kops.devopslee.com/blue
Check the ingress resource
You can see that 3 different applications can be accessed using the same Hostname based on the path.
Access the applications
In this article, we saw the steps to create a Kubernetes Cluster using Kops. This article mainly focused on setting up Nginx Ingress Controller using Helm and creating a path-based routing using Ingress resource. We deployed 3 different sample applications and tried accessing them using the same Hostname and different paths.
