How to Install WebERP On CentOS 8
webERP is a free, open-source, and complete web-based accounting and business management system. You just need a web browser and PDF reader to use the webERP. With webERP, you can manage many things including, purchase orders, web store, manufacturing, sales, general ledger, and shipping. It is written in PHP and uses MariaDB as a database backend. This tutorial will show you how to install webERP with Apache and Let’s Encrypt SSL on CentOS 8.
- A server running CentOS 8.
Install LAMP Server
First, install the Apache, MariaDB, PHP, and other PHP extensions using the following command:
dnf install httpd mariadb-server php php-mysqli php-curl php-json php-cgi php-xmlrpc php-gd php-mbstring unzip -y
Once all the packages are installed, start the Apache and MariaDB service and enable them to start at system reboot using the following command:
systemctl start httpd mariadb
systemctl enable httpd mariadb
Configure MariaDB
Next, you will need to set a MariaDB root password and secure the MariaDB installation. You can do it with the following command:
mysql_secure_installation
Set root password? [Y/n] Y
New password:
Re-enter new password:
Thanks for using MariaDB!
Next, login to MariaDB shell with the following command:
mysql -u root -p
Once connected, create a database and user for webERP with the following command:
MariaDB [(none)]> create database weberp;
MariaDB [(none)]> create user weberp@localhost identified by 'password';
Next, grant all the privileges to the webERP database with the following command:
MariaDB [(none)]> grant all privileges on weberp.* to weberp@localhost identified by 'password';
MariaDB [(none)]> exit;
Install webERP
First, download the latest version of webERP with the following command:
wget https://sourceforge.net/projects/web-erp/files/webERP_4.15.zip
Once the download is completed, extract the downloaded file to the Apache web root directory using the following command:
unzip webERP_4.15.zip -d /var/www/html
Next, set proper permission and ownership with the following command:
chown -R apache:apache /var/www/html/webERP
chmod -R 755 /var/www/html/webERP
Configure Apache for webERP
Next, you will need to create a new Apache virtual host configuration file to host the webERP. You can create it using the following command:
nano /etc/httpd/conf.d/weberp.conf
ServerAdmin [email protected]
DocumentRoot /var/www/html/webERP
ServerName weberp.example.com
<Directory /var/www/html/webERP/>
Options FollowSymLinks
Order allow,deny
allow from all
ErrorLog /var/log/httpd/weberp.org-error_log
CustomLog /var/log/httpd/weberp.org-access_log common
Save and close the file when you are finished. Next, restart the Apache service to apply the changes:
systemctl restart httpd
Now, verify the status of the Apache with the following command:
systemctl status httpd
? httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; disabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/httpd.service.d
??php-fpm.conf
Active: active (running) since Sat 2021-05-01 05:57:27 EDT; 13s ago
Docs: man:httpd.service(8)
Main PID: 4896 (httpd)
Status: "Running, listening on: port 80"
Tasks: 213 (limit: 25014)
Memory: 24.8M
CGroup: /system.slice/httpd.service
??4896 /usr/sbin/httpd -DFOREGROUND
??4898 /usr/sbin/httpd -DFOREGROUND
??4899 /usr/sbin/httpd -DFOREGROUND
??4900 /usr/sbin/httpd -DFOREGROUND
??4901 /usr/sbin/httpd -DFOREGROUND
May 01 05:57:27 centos8 systemd[1]: Stopped The Apache HTTP Server.
May 01 05:57:27 centos8 systemd[1]: Starting The Apache HTTP Server...
At this point, Apache web server is configured to host webERP. You can now proceed to the next step.
Secure webERP with Let’s Encrypt SSL
Next, you will need to install the Certbot client to install the Let’s Encrypt SSL for webERP. You can install it with the following command:
dnf install letsencrypt python3-certbot-apache
Next, obtain and install an SSL certificate for your domain with the following command:
certbot --apache -d weberp.example.com
You will be asked to provide your email address and accept the term of service:
Enter email address (used for urgent renewal and security notices)
(Enter 'c' to cancel): [email protected]
agree in order to register with the ACME server. Do you agree?
(Y)es/(N)o: Y
Would you be willing, once your first certificate is successfully issued, to
share your email address with the Electronic Frontier Foundation, a founding
partner of the Let's Encrypt project and the non-profit organization that
develops Certbot? We'd like to send you email about our work encrypting the web,
EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: Y
Account registered.
Requesting a certificate for weberp.example.com
http-01 challenge for weberp.example.com
Waiting for verification.
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/httpd/conf.d/weberp.conf
Redirecting all traffic on port 80 to ssl in /etc/httpd/conf.d/weberp.conf
Congratulations! You have successfully enabled https://weberp.example.com
Subscribe to the EFF mailing list (email: [email protected]).
IMPORTANT NOTES:
/etc/letsencrypt/live/weberp.example.com/fullchain.pem
/etc/letsencrypt/live/weberp.example.com/privkey.pem
Your certificate will expire on 2021-06-09. To obtain a new or
tweaked version of this certificate in the future, simply run
certbot again with the "certonly" option. To non-interactively
renew *all* of your certificates, run "certbot renew"
You can now access your website securely using the URL https://weberp.example.com.
Configure Firewall
Next, you will need to allow ports 80 and 443 through the firewall. You can allow them with the following command:
Next, reload the firewall to apply the changes:
firewall-cmd --reload
Access webERP Web Interface
Now, open your web browser and access the webERP web interface using the URL https://weberp.example.com. You should see the following page:
Select your language and click on the NEXT STEP. You should see the following page:
Provide your database name, user, password and click on the NEXT STEP. You should see the following page:
Provide your Company name, Time Zone, Admin username, password and click on the INSTALL button. Once the installation has been finished, you should see the following page:
Provide your admin username, password and click on the Login button. You will be redirected to the webERP dashboard:
Congratulations! you have successfully installed webERP with Apache and Let’s Encrypt SSL on CentOS 8. You can now explore webERP for more features and implement them in your production environment.
