How to Repair MySQL Replication
If you have set up MySQL replication, you probably know this problem: sometimes there are invalid MySQL queries which cause the replication to not work anymore. In this short guide, I explain how you can repair the replication on the MySQL slave without the need to set it up from scratch again. This guide is for MySQL and MariaDB.
1 Identifying the Problem
To find out whether replication is/is not working and what has caused to stop it, you can take a look at the logs. On Debian, for example, MySQL logs to /var/log/syslog:
grep mysql /var/log/syslog
server1:/home/admin# grep mysql /var/log/syslog
MAR 19 09:56:08 http2 mysqld[1380]: 080529 9:56:08 [ERROR] Slave: Error 'Table 'mydb.taggregate_temp_1212047760' doesn't exist' on query. Default database: 'mydb'. Query: 'UPDATE thread AS thread,taggregate_temp_1212047760 AS aggregate
MAR 19 09:56:08 http2 mysqld[1380]: ^ISET thread.views = thread.views + aggregate.views
MAR 19 09:56:08 http2 mysqld[1380]: ^IWHERE thread.threadid = aggregate.threadid', Error_code: 1146
MAR 19 09:56:08 http2 mysqld[1380]: 080529 9:56:08 [ERROR] Error running query, slave SQL thread aborted. Fix the problem, and restart the slave SQL thread with "SLAVE START". We stopped at log 'mysql-bin.001079' position 203015142
You can see what query caused the error, and at what log position the replication stopped.
To verify that the replication is really not working, log in to MySQL:
mysql -u root -p
On the MySQL shell, run:
mysql> SHOW SLAVE STATUS G
If one of Slave_IO_Running or Slave_SQL_Running is set to No, then the replication is broken:
*************************** 1. row ***************************
             Slave_IO_State: Waiting for master to send event
                Master_Host: 1.2.3.4
                Master_User: slave_user
                Master_Port: 3306
              Connect_Retry: 60
            Master_Log_File: mysql-bin.001079
        Read_Master_Log_Pos: 269214454
             Relay_Log_File: slave-relay.000130
              Relay_Log_Pos: 100125935
      Relay_Master_Log_File: mysql-bin.001079
           Slave_IO_Running: Yes
          Slave_SQL_Running: No
            Replicate_Do_DB: mydb
        Replicate_Ignore_DB:
         Replicate_Do_Table:
     Replicate_Ignore_Table:
    Replicate_Wild_Do_Table:
Replicate_Wild_Ignore_Table:
                 Last_Errno: 1146
                 Last_Error: Error 'Table 'mydb.taggregate_temp_1212047760' doesn't exist' on query. Default database: 'mydb'.
               Skip_Counter: 0
        Exec_Master_Log_Pos: 203015142
            Relay_Log_Space: 166325247
            Until_Condition: None
             Until_Log_File:
              Until_Log_Pos: 0
         Master_SSL_Allowed: No
         Master_SSL_CA_File:
         Master_SSL_CA_Path:
            Master_SSL_Cert:
          Master_SSL_Cipher:
             Master_SSL_Key:
      Seconds_Behind_Master: NULL
1 row in set (0.00 sec)
mysql>
2 Repair the MySQL Replication
Just to go sure, we stop the slave:
mysql> STOP SLAVE;
Fixing the problem is actually quite easy. We tell the slave to simply skip the invalid SQL query:
mysql> SET GLOBAL SQL_SLAVE_SKIP_COUNTER = 1;
This tells the slave to skip one query (which is the invalid one that caused the replication to stop). If you’d like to skip two queries, you’d use SET GLOBAL SQL_SLAVE_SKIP_COUNTER = 2; instead and so on.
That’s it already. Now we can start the slave again…
mysql> START SLAVE;
… and check if replication is working again:
                Master_Port: 3306
              Connect_Retry: 60
        Read_Master_Log_Pos: 447560366
              Relay_Log_Pos: 225644062
          Slave_SQL_Running: Yes
         Replicate_Do_Table:
                 Last_Errno: 0
                 Last_Error:
               Skip_Counter: 0
        Exec_Master_Log_Pos: 447560366
            Relay_Log_Space: 225644062
             Until_Log_File:
              Until_Log_Pos: 0
         Master_SSL_CA_File:
         Master_SSL_CA_Path:
            Master_SSL_Cert:
          Master_SSL_Cipher:
             Master_SSL_Key:
      Seconds_Behind_Master: 0
mysql>
As you see, both Slave_IO_Running and Slave_SQL_Running are set to Yes now.
Now leave the MySQL shell…
mysql> quit;
… and check the log again:
MAR 19 11:42:13 http2 mysqld[1380]: 080529 11:42:13 [Note] Slave SQL thread initialized, starting replication in log 'mysql-bin.001079' at position 203015142, relay log '/var/lib/mysql/slave-relay.000130' position: 100125935
The last line says that replication has started again, and if you see no errors after that line, everything is ok.
