How to Install Wiki.js on CentOS 7
Wiki.js is a modern and powerful OpenSource wiki app based on Node.js, Git, and Markdown. Wiki.js runs on the flamingly fast Node.js engine and is optimized to conserve CPU resources. Some of the Wiki.js features worth mentioning are:
  • Markdown editing, backed by Git
  • Lightweight, yet extremely powerful
  • Beautifully designed for the modern web
  • Integrated Access Control
  • Intuitive Assets Management
  • Built-in search engine
In this tutorial, we will walk you through the Wiki.js version 1 installation process on a CentOS 7 operating system by using NGINX as a reverse proxy server, MongoDB as a database server, PM2 as a process manager and optionally you can secure transport layer by using acme.sh client and Let’s Encrypt certificate authority to add SSL support.
Requirements to run Wiki.js are the following:
  • Node.js 6.11.1 to 10.x is required.
  • MongoDB version 3.2 or later.
  • Git version 2.7.4 or later.
  • Web Server software such as NGINX, Apache, Caddy, H2O…
  • An empty Git repository (optional).
  • Minimum of 512MB RAM. 1GB of RAM recommended.
  • About 300MB of disk space.
  • Domain name with A/AAAA DNS records set up.
  • A CentOS 7 operating system.
  • A non-root user with sudo privileges.
Initial Steps
Check your CentOS version:
cat /etc/centos-release
Set up the timezone:
timedatectl list-timezones
sudo yum update -y
Install some essential packages that are necessary for basic administration of the CentOS operating system:
sudo yum install -y curl wget vim unzip socat epel-release
Wiki.js requires you to install Git version 2.7.4 or greater. Default Git version on CentOS is too old, so you will need to build it from source code. Here are the commands to quickly compile it:
# Remove existing git package if installed:
sudo yum remove -y git
sudo yum groupinstall -y "Development Tools"
sudo yum install -y gettext-devel openssl-devel perl-CPAN perl-devel zlib-devel curl-devel
wget https://mirrors.edge.kernel.org/pub/software/scm/git/git-2.21.0.tar.gz && tar zxvf git-2.21.0.tar.gz
rm git-2.21.0.tar.gz
cd git-2.21.0
make configure
./configure make prefix=/usr/local all
sudo make prefix=/usr/local install
cd ~
which git
git --version
Step 1- Install Node.js and npm
Wiki.js is built on Node.js. We are going to install the latest recommended version for Wiki.js which is version 10 at the time of this writing. On Linux, you have a few Node.js installation options: Linux Binaries (x86/x64), Source Code or via Package Managers. We will use a Package Management option which makes installing and updating Node.js a breeze.
Download and install the latest recommended version of Node.js from the NodeSource repository:
curl --silent --location https://rpm.nodesource.com/setup_10.x | sudo bash -
sudo yum install -y nodejs
NOTE: npm is distributed with Node.js – which means that when you download Node.js, you automatically get npm installed on your system.
Check Node.js and npm version:
node -v && npm -v
# v10.15.1
# 6.4.1
Npm is a separate project from Node.js and tends to update more frequently. As a result, even if you’ve just downloaded Node.js (and therefore npm), you’ll probably need to update your npm. Luckily, npm knows how to update itself! To update your npm, type this into your terminal:
sudo npm install -g npm@latest
This command will update npm to the latest stable version.
Re-check npm version with:
npm -v
# 6.8.0
And it should return the latest version number.
Step 2 – Install MongoDB database
Wiki.js needs a database to store its data, and the current stable version of Wiki.js supports only MongoDB database engine. According to that, we will need to install MongoDB database.
Create a /etc/yum.repos.d/mongodb-org-4.0.repo file so that you can install MongoDB directly using yum.
Run:
sudo vim /etc/yum.repos.d/mongodb-org-4.0.repo
And populate the file with the following config:
[mongodb-org-4.0]
name=MongoDB Repository
baseurl=https://repo.mongodb.org/yum/redhat/$releasever/mongodb-org/4.0/x86_64/
gpgcheck=1
enabled=1
gpgkey=https://www.mongodb.org/static/pgp/server-4.0.asc
To install the latest stable version of MongoDB, issue the following command:
sudo yum install -y mongodb-org
Check the MongoDB version:
mongo --version | head -n 1 && mongod --version | head -n 1
# MongoDB shell version v4.0.6
# db version v4.0.6
Start and enable (set it to start on rebootMongoDB service if not already started and enabled:
sudo systemctl start mongod.service
sudo systemctl enable mongod.service
Step 3 – Install acme.sh client and obtain Let’s Encrypt certificate (optional)
Securing your website with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain an SSL certificate from Let’s Encrypt, we will use acme.sh client. Acme.sh is a pure UNIX shell software for obtaining SSL certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
./acme.sh --install --accountemail [email protected]
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.1
Obtain RSA and ECC/ECDSA certificates for your domain/hostname:
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging flag to the above commands.
acme.sh --list
Create folders to store your certs. We will use /etc/letsencrypt but it can be anything you prefer to store SSL certs.
mkdir -p /etc/letsencrypt/example.com
mkdir -p /etc/letsencrypt/example.com_ecc
# RSA
acme.sh --install-cert -d example.com
--cert-file /etc/letsencrypt/example.com/cert.pem
--key-file /etc/letsencrypt/example.com/private.key
--fullchain-file /etc/letsencrypt/example.com/fullchain.pem
--reloadcmd "sudo systemctl reload nginx.service"
# ECC/ECDSA
acme.sh --install-cert -d example.com --ecc
--cert-file /etc/letsencrypt/example.com_ecc/cert.pem
--key-file /etc/letsencrypt/example.com_ecc/private.key
--fullchain-file /etc/letsencrypt/example.com_ecc/fullchain.pem
  • For RSA: /etc/letsencrypt/example.com directory.
  • For ECC/ECDSA: /etc/letsencrypt/example.com_ecc directory.
All the certificates will be automatically renewed every 60 days.
After obtaining certs, exit from root user and return back to normal sudo user:
exit
Step 4 – Install and configure NGINX
Wiki.js (or any HTTP Node.js app) can run without any actual web server (such as NGINX or Apache). However, it is highly recommended to put a standard web server in front of Wiki.js. This ensures you can use features like SSL, multiple websites, caching, etc. We will use NGINX in this tutorial, but any other server will do, you just need to configure it properly.
Download and install NGINX:
sudo yum install -y nginx
Check the NGINX version:
nginx -v
# nginx version: nginx/1.12.2
Enable and start NGINX service:
Run sudo vim /etc/nginx/conf.d/wiki.js.conf and configure NGINX as an HTTPS reverse proxy.
listen [::]:443 ssl http2;
listen 443 ssl http2;
listen [::]:80;
server_name example.com;
charset utf-8;
client_max_body_size 50M;
proxy_pass http://127.0.0.1:3000;
proxy_http_version 1.1;
proxy_next_upstream error timeout http_502 http_503 http_504;
The only thing you need to change in the above config is server_name directive, and potentially proxy_pass directive if you decide to configure some other than 3000 port. Wiki.js uses port 3000 by default.
Check the NGINX configuration:
sudo nginx -t
Finally, for changes to take effect, we need to reload NGINX:
Step 5 – Install and setup Wiki.js
Create a document root directory where Wiki.js should reside in:
sudo mkdir -p /var/www/wiki.js
cd /var/www/wiki.js
Change ownership of the /var/www/wiki.js directory to your_user:
sudo chown -R [your_user]:[your_user] /var/www/wiki.js
NOTE: Replace your_user in the above command with your non-root user that you should have created as a prerequisite for this tutorial.
From /var/www/wiki.js directory, run the following command to fetch and install the latest Wiki.js application:
curl -sSo- https://wiki.js.org/install.sh | bash
Once the installation is completed, you can run the following command in order to view the currently installed version of Wiki.js:
node wiki --version
# 1.0.117
Once the installation is completed, you’ll be prompted to launch the configuration wizard.
So, start the configuration wizard by running:
node wiki configure
Using your web browser, navigate to http://example.com and follow the on-screen instructions. All settings entered during the configuration wizard are saved in the config.yml file. The configuration wizard will automatically start Wiki.js for you.
First, you will see a welcome message. Click on the “Start” button:
Wiki.js installer
Next “System Check” page will appear. If all requirements are met, click on the “Continue” button.
System Check
Enter general information about your wiki and click the “Continue” button:
General information
Read the “Important Consideration” notice and click “Continue” for the next step:
Important to consider
Next, connect to the database and continue:
Database connection
You should see a message that Wiki.js has been successfully connected to the database. Click the “Continue” button:
Database connection successful
Set paths and continue:
Set the path
Set up remote Git repo if you want or skip this step. This step is optional but highly recommended:
Setup remote GIT repo
Next, click the “Continue” button:
Continue with the installation
Create an admin account and click the “Continue” button:
And finally, start the Wiki.js:
Start Wiki.js
Wait around 30 seconds and you should be redirected to Wiki.js homepage:
Wiki.js homepage
The installation is completed. You should wiki welcome page:
Welcome to Wiki.js
Step 6 – Setup PM2 Process Manager
By default, Wiki.js will not start automatically after a system reboot. In order to make it start on boot, we need to setup PM2 process manager. PM2 comes bundled with Wiki.js as a local npm module, so we don’t need to install PM2 globally.
Tell PM2 to configure itself as a startup service by running:
/var/www/wiki.js/node_modules/pm2/bin/pm2 startup
Finally, save the current PM2 configuration by running the command:
/var/www/wiki.js/node_modules/pm2/bin/pm2 save
Your Wiki.js now runs as a background process, using PM2 as its process manager.
