How to Install OrangeScrum on CentOS 8
Orangescrum is an open-source and collaboration web application written by using CakePHP. It is simple and easy to use tools to manage projects, teams, documents, tasks, and communicate with the team on important issues. It is a widely used tool for small to medium size businesses. Orangescrum has many useful features like agile project management, collaboration, issue tracking, notifications, reporting, task management, conversation thread and many other features that will speed up the work process to deliver high-quality projects.
  • OS:- Centos 8
  • If STRICT mode is On, turn it Off. In Database Server.
First, log in to Centos system with sudo privileges and update system using the following command:-
dnf update
Install a LAMP server.
1. Install Apache Web Server
Install Apache Web Server by the following command:
sudo dnf -y install httpd
Now check apache service using the following command
systemctl status httpd
If apache service not working then start and enable it to start at boot time, using the following commands:-
sudo systemctl start httpd
sudo systemctl enable httpd
2. Install and configure MariaDB
Install MariaDB server by executing the following command:
sudo dnf install mariadb-server
Now start MariaDB service and enable it to start at boot time then check MariaDB service status with the following command:-
sudo systemctl start mariadb
sudo systemctl enable mariadb
sudo systemctl status mariadb
Next, you will need to secure database server, to do so run following command in Terminal:-
Here, set up a strong password and answer yes to all questions
Set root password? [Y/n] Y
New password:
Re-enter new password:
Your MariaDB installation is now secure.
Next, log in to MariaDB console as shown below:
sudo mysql -u root -p
Next, you will need to disable strict mode for MariaDB. First, verify which mode MariaDB is running with:
MariaDB [(none)]> SHOW VARIABLES LIKE 'sql_mode';
It will show you output like the following:
| Variable_name | Value        |
| sql_mode      | STRICT_TRANS_TABLES,ERROR_FOR_DIVISION_BY_ZERO,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION |
1 row in set (0.001 sec)
Next, You can disable strict mode by running the following command:
MariaDB [(none)]> SET GLOBAL sql_mode = 'NO_ENGINE_SUBSTITUTION';
Then, you can verify that strict mode disabled or not by running the following:
MariaDB [(none)]> SELECT @@GLOBAL.sql_mode;
Check MySQL mode
Then restart MariaDB service.
sudo systemctl restart mariadb
Next, you will need to log in to the MariaDB console and create a database for the Orangescrum. Run the following command to create the database
Enter your root password when prompted and run following command:-
MariaDB [(none)]> CREATE DATABASE orangescrum;
Now create a new user and grant the required permissions to the user for the database.
MariaDB [(none)]> CREATE USER 'orangescrum_user'@'localhost' IDENTIFIED BY 'YourStrongPassword';
Then grant privileges to the orangescrum database with the following command:-
GRANT ALL PRIVILEGES ON orangescrum.* TO 'orangescrumuser'@'localhost' IDENTIFIED BY 'YourStrongPassword' WITH GRANT OPTION;
Now run the following command to immediately apply the changes on the database privileges.
Next, exit from the MySQL shell:
MariaDB [(none)]> exit
3. Install and configure PHP
Next, you will need to install PHP package, run following command from Terminal
sudo dnf install php php-cli php-mysqlnd php-gd php-ldap php-odbc php-pear php-xml php-xmlrpc php-mbstring php-snmp php-soap php-curl php-opcache php-bcmath php-fpm
Once all the packages are installed, Now you will need to make some changes in php.ini file as required by OrangeScrum:
First, take the backup of php.ini
cp /etc/php.ini /etc/php.ini.bak
Next edit php.ini file
sudo vim /etc/php.ini
Find and change the value from 2M to 200M:
post_max_size=200M
upload_max_filesize=200M
Save and close the file.
Next, You’ll need to restart your apache web server to apply changes, run following command:-
sudo systemctl restart httpd
Install Orangescrum
To download the Open Source version of Orangescrum run following command:
sudo wget https://github.com/Orangescrum/orangescrum/archive/master.zip
Then unzip downloaded file by running
sudo unzip master.zip
This will create the orangescrum-master directory.
Now move orangescrum-master directory to your Apache web directory. You can do this by running:
sudo mv orangescrum-master /var/www/html/
Next Give the orangescrum-master directory the correct permissions:
sudo chown -R apache:apache /var/www/html/orangescrum-master
sudo chmod -R 777 /var/www/html/orangescrum-master
Configure Apache for Orangescrum
First, create a virtual host file for Orangescrum,
sudo vim /etc/httpd/conf.d/orangescrum.conf
Then add the following content:
ServerName localhost
DocumentRoot /var/www/html/orangescrum-master
<Directory /var/www/html/orangescrum-master>
Order allow,deny
allow from all
Save and quit:
:wq!
When you are finished, check the syntax of the configurations.to do so run the following command:-
sudo apachectl configtest
After the syntax check is done, restart Apache service:
Configure Orangescrum
Now Import the OrangeScrum data into the orangescrum database using the following command as shown below:
mysql -u orangescrum_user -p orangescrum < /var/www/html/orangescrum-master/database.sql
Now you need to edit the database.php file to update the database connection details:
vim /var/www/html/orangescrum-master/app/Config/database.php
Change the file as shown below:
class DATABASE_CONFIG {
    public $default = array(
            'datasource' => 'Database/Mysql',
            'persistent' => false,
            'host' => 'localhost',
            'login' => 'orangescrum_user',
            'password' => 'Your_StrongPassword',
            'database' => 'orangescrum',
            'prefix' => '',
            'encoding' => 'utf8',
Then save and exit file. Here you have to enter your database usename, password and database name that you’ve chosen when creating the database and MySQL user.
Next, you need to edit the constants.php file for SMTP:
sudo vim /var/www/html/orangescrum-master/app/Config/constants.php
Next Find and Change the following lines as per your need:
//Gmail SMTP
define("SMTP_HOST", "ssl://smtp.gmail.com");
define("SMTP_PORT", "465");
define("SMTP_UNAME", "[email protected]");
define("SMTP_PWORD", "******");
define("IS_SMTP", "0");
define('FROM_EMAIL_NOTIFY', '[email protected]'); //(REQUIRED)
define('SUPPORT_EMAIL', '[email protected]'); //(REQUIRED) From Email
Now restart Apache service.
Next, Modify firewall rules in order to allow web access:
sudo firewall-cmd --zone=public --permanent --add-service=http
sudo firewall-cmd --reload
You can disable SELinux temporarily using this below-given command.
setenforce 0
Test Orangescrum
From your web browser and visit http://yourserverIP and provide your company name, an email and a password then click on Sign Up button.
Now explore more from the OrangeScrum.
