How to Install Flarum Forum with Nginx and LE SSL on CentOS 8
Flarum is a free, open-source and next-generation forum software that makes it easier for you to start and grow a successful online community. It is simple, lightweight, fast and mobile-friendly software based on PHP. It comes with a rich set of features including, Elegant UI, Two-Pane Interface, Infinite Scrolling, Floating Composer, Fully responsive and many more.
In this tutorial, we will explain how to install the Flarum forum on CentOS 8 server.
  • A server running CentOS 8.
  • A valid domain name pointed with your server IP
Before starting, you will need to install EPEL and Remi repository in your system. First, install the EPEL repository with the following command:
dnf install epel-release -y
Next, download and install the Remi repository with the following command:
wget http://rpms.remirepo.net/enterprise/remi-release-8.rpm
rpm -Uvh remi-release-8.rpm
Install Nginx, MariaDB and PHP
First, install the Nginx webserver and MariaDB server with the following command:
dnf install nginx mariadb-server -y
Once both packages are installed, you will need to enable php:remi-7.3 module to install PHP 7.3. You can enable it with the following command:
dnf module enable php:remi-7.3
Next, install PHP with other required dependencies with the following command:
dnf install php php-fpm php-common php-opcache php-pecl-apcu php-cli php-pear php-pdo php-mysqlnd php-pgsql php-pecl-mongodb php-pecl-redis php-pecl-memcache php-pecl-memcached php-gd php-mbstring php-mcrypt php-xml -y
Once all the packages are installed, start the Nginx, MariaDB and PHP-FPM service and enable them to start after system reboot with the following command:
systemctl start nginx
systemctl start mariadb
systemctl start php-fpm
systemctl enable nginx
systemctl enable mariadb
systemctl enable php-fpm
Configure MariaDB Database
By default, MariaDB is not secured. You can secure it with the following script:
mysql_secure_installation
Set root password? [Y/n] Y
New password:
Re-enter new password:
Once you are done, log in to MariaDB shell with the following command:
mysql -u root -p
Provide your root password when prompt then create a database and user for Flarum with the following command:
MariaDB [(none)]> CREATE DATABASE flarumdb;
MariaDB [(none)]> GRANT ALL PRIVILEGES on flarumdb.* to 'flarum'@'localhost' identified by 'password';
MariaDB [(none)]> EXIT;
Configure PHP-FPM for Nginx
Next, you will need to configure PHP-FPM to work with Nginx. You can do it by editing the file www.conf:
nano /etc/php-fpm.d/www.conf
Change the user and group name from apache to nginx as shown below:
user = nginx
group = nginx
listen.owner = nginx
listen.group = nginx
Next, find the following line:
;listen = /run/php-fpm/www.sock
And replace it with the following line:
listen = 127.0.0.1:9000
Save and close the file when you are finished. Then, restart PHP-FPM service to apply the changes:
systemctl restart php-fpm
Install Flarum
Before installing the Flarum, you will need to install Composer in your system.
You can install it with the following command:
curl -sS https://getcomposer.org/installer | php
Once installed, you should get the following output:
All settings correct for using Composer
Downloading...
Composer (version 1.9.2) successfully installed to: /root/composer.phar
Use it: php composer.phar
Next, move the Composer binary file to the /usr/local/bin directory and give proper permission:
mv composer.phar /usr/local/bin/composer
chmod 755 /usr/local/bin/composer
Next, change the directory to the Nginx document root and create a Flarum project with the following command:
cd /var/www/html
composer create-project flarum/flarum . --stability=beta
Next, give proper permissions on Nginx web root directory with the following command:
chown -R nginx:nginx /var/www/html
chmod -R 755 /var/www/html
chown -R nginx:nginx /var/lib/php
Configure Nginx for Flarum
Next, you will need to create an Nginx virtual host configuration file for Nginx. You can create it with the following command:
nano /etc/nginx/conf.d/flarum.conf
server_name flarum.example.com;
# note that these lines are originally from the "location /" block
root /var/www/html/public;
location / { try_files $uri $uri/ /index.php?$query_string; }
location /api { try_files $uri $uri/ /api.php?$query_string; }
location /admin { try_files $uri $uri/ /admin.php?$query_string; }
location /flarum {
deny all;
return 404;
location ~ .php$ {
try_files $uri =404;
fastcgi_pass 127.0.0.1:9000;
fastcgi_index index.php;
include fastcgi_params;
location ~* .html$ {
expires -1;
location ~* .(css|js|gif|jpe?g|png)$ {
expires 1M;
add_header Pragma public;
add_header Cache-Control "public, must-revalidate, proxy-revalidate";
gzip on;
gzip_http_version 1.1;
gzip_vary on;
gzip_comp_level 6;
gzip_proxied any;
gzip_types application/atom+xml
application/javascript
application/json
application/vnd.ms-fontobject
application/x-font-ttf
application/x-web-app-manifest+json
application/xhtml+xml
application/xml
font/opentype
image/svg+xml
image/x-icon
text/css
#text/html -- text/html is gzipped by default by nginx
text/plain
text/xml;
gzip_buffers 16 8k;
gzip_disable "MSIE [1-6].(?!.*SV1)";
Save and close the file when you are finsihed. Next, you will need to increase the hash_bucket size in nginx.conf file.
You can do it by editing the file /etc/nginx/nginx.conf:
nano /etc/nginx/nginx.conf
Add the following line exact above the last line:
Save and close the file. Then, check Nginx for any syntax error with the following command:
nginx -t
Finally, restart the Nginx and PHP-FPM service to apply the changes:
systemctl restart nginx
First, you will need to create a firewall rule to allow HTTP and HTTPS service from external networks. You can allow it with the following command:
firewall-cmd --reload
By default, SELinux is enabled in CentOS 8. So you will need to configure SELinux for Flarum to work correctly. You can configure SELinux using the following command:
setsebool httpd_can_network_connect on -P
Access Flarum Web UI
Now, open your web browser and type the URL http://flarum.example.com. You will be redirected to the following page:
Flarum Forum installer
Provide your forum name, database details, admin username, password and click on the Install Flarum button. Once the installation has been completed successfully, you should see the Flarum dashboard in the following page:
Flarum Forum
Secure Flarum with Let’s Encrypt SSL
Flarum is now installed and configured. It’s time to secure it with Let’s Encrypt free SSL.
To do so, you will need to download the certbot client on your server. You can download and set correct permission by running the following command:
Now, run the following command to obtain and install an SSL certificate for your flarum website.
certbot-auto --nginx -d flarum.example.com
The above command will first install all the required dependencies on your server. Once installed, you will be asked to provide an email address and accept the term of service as shown below:
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for flarum.example.com
Waiting for verification...
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/nginx/conf.d/flarum.conf
Next, you will need to choose whether or not to redirect HTTP traffic to HTTPS as shown below:
Type 2 and hit Enter to continue. Once the installation has been finished, you should see the following output:
Redirecting all traffic on port 80 to ssl in /etc/nginx/conf.d/flarum.conf
Congratulations! You have successfully enabled https://flarum.example.com
https://www.ssllabs.com/ssltest/analyze.html?d=flarum.example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/flarum.example.com/fullchain.pem
/etc/letsencrypt/live/flarum.example.com/privkey.pem
Your cert will expire on 2020-03-23. To obtain a new or tweaked
Thats it! You can now access your Flarum website using the secure URL https://flarum.example.com.
