How to Install OpenNMS Network Monitoring Tool in CentOS 8
OpenNMS is a free and open-source network monitoring and network management platform used for managing enterprise networks around the world. It is based on Java and is designed to manage thousands of devices from a central location. It has the ability to discover and monitor the services or nodes automatically in your network.
Features
- Supports SNMP, JMX, WMI, NPRE, NSCLient++ and XMP
- Event-driven Architecture
- Supports device and application monitoring
- Typology Discovery and Path Outage
- Configure and Execute Service Monitors
- Supports Layer 2 and Layer 3 Network Topologies
In this tutorial, we will show you how to install and configure OpenNMS on CentOS 8 server.
- A server running CentOS 8.
OpenNMS is a Java-based application. So you will need to install Java in your system. You can install it with other required packages by running the following command:
dnf install java-11-openjdk-devel curl unzip -y
After installing Java, you can verify the java version with the following command:
java -version
openjdk version "11.0.9" 2020-10-20 LTS
OpenJDK Runtime Environment 18.9 (build 11.0.9+11-LTS)
OpenJDK 64-Bit Server VM 18.9 (build 11.0.9+11-LTS, mixed mode, sharing)
Install OpenNMS
By default, OpenNMS is not available in the CentOS 8 default repository. So you will need to add the OpenNMS repository to your system.
First, add the GPG key with the following command:
rpm --import https://yum.opennms.org/OPENNMS-GPG-KEY
Once the GPG key is added, run the following command to add the OpenNMS repo.
dnf install https://yum.opennms.org/repofiles/opennms-repo-stable-rhel8.noarch.rpm
Next, you can install the OpenNMS by running the following command:
dnf install opennms -y
This will install OpenNMS, PostgreSQL and other packages in your server.
Configure PostgreSQL
OpenNMS uses PostgreSQL as a database backend. You can initialize the PostgreSQL database with the following command:
postgresql-setup --initdb --unit postgresql
* Initializing database in '/var/lib/pgsql/data'
* Initialized, logs are in /var/lib/pgsql/initdb_postgresql.log
Next, start the PostgreSQL service and enable it to start at system reboot with the following command:
systemctl enable postgresql
systemctl start postgresql
Next, you will need to create a database and user for PostgreSQL.
First, log in to the PostgreSQL with the following command:
su - postgres
Once login, create a user with the following command:
[postgres@centos8 ~]$ createuser -P opennms
You will be asked to set a password asshown below:
Enter password for new role:
Enter it again:
Next, create a database with the following command:
[postgres@centos8 ~]$ createdb -O opennms opennms
Next, set the password for PostgreSQL user with the following command;
[postgres@centos8 ~]$ psql -c "ALTER USER postgres WITH PASSWORD 'password';"
Next, exit from the PostgreSQL shell with the following command:
[postgres@centos8 ~]$ exit;
Next, you will need to modify the access policy for PostgreSQL. You can do it by editing the file /var/lib/pgsql/data/pg_hba.conf:
nano /var/lib/pgsql/data/pg_hba.conf
Find the following lines:
# IPv4 local connections:
host all all 127.0.0.1/32 ident
# IPv6 local connections:
host all all ::1/128 ident
And, replaced them with the following lines:
host all all 127.0.0.1/32 md5
host all all ::1/128 md5
Save and close the file then restart the PostgreSQL service to apply the changes:
systemctl restart postgresql
Next, you will need to define your database in /opt/opennms/etc/opennms-datasources.xml file.
nano /opt/opennms/etc/opennms-datasources.xml
Change the following lines that match with your database:
<jdbc-data-source name="opennms"
database-name="opennms"
class-name="org.postgresql.Driver"
url="jdbc:postgresql://localhost:5432/opennms"
user-name="opennms"
password="opennms" />
<jdbc-data-source name="opennms-admin"
database-name="template1"
url="jdbc:postgresql://localhost:5432/template1"
user-name="postgres"
password="password" />
Initialize and Start OpenNMS
Next, you will need to initialize OpenNMS. First, add the Java settings with the following command:
/opt/opennms/bin/runjava -s
runjava: Looking for an appropriate JVM...
runjava: Checking for an appropriate JVM in JAVA_HOME...
runjava: Skipping... JAVA_HOME not set.
runjava: Checking JVM in the PATH: "/etc/alternatives/java"...
runjava: Did not find an appropriate JVM in the PATH: "/etc/alternatives/java"
runjava: Searching for a good JVM...
runjava: Found a good JVM in "/usr/lib/jvm/java-11-openjdk-11.0.9.11-0.el8_2.x86_64/bin/java".
runjava: Value of "/usr/lib/jvm/java-11-openjdk-11.0.9.11-0.el8_2.x86_64/bin/java" stored in configuration file.
Next, initialize the database by running the following command:
/opt/opennms/bin/install -dis
Next, enable the OpenNMS to start at system reboot with the following command:
systemctl enable --now opennms
Synchronizing state of opennms.service with SysV service script with /usr/lib/systemd/systemd-sysv-install.
Executing: /usr/lib/systemd/systemd-sysv-install enable opennms
Created symlink /etc/systemd/system/multi-user.target.wants/opennms.service → /usr/lib/systemd/system/opennms.service.
Now, you can check the status of the OpenNMS service with the following command:
systemctl status opennms
? opennms.service - OpenNMS server
Loaded: loaded (/usr/lib/systemd/system/opennms.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2020-11-25 09:21:32 EST; 13s ago
Process: 26880 ExecStart=/etc/init.d/opennms -s start (code=exited, status=0/SUCCESS)
Main PID: 27928 (java)
Tasks: 67 (limit: 12523)
Memory: 555.6M
CGroup: /system.slice/opennms.service
??27927 bash /etc/init.d/opennms -s start
??27928 /usr/lib/jvm/java-11-openjdk-11.0.9.11-0.el8_2.x86_64/bin/java --add-modules=java.base,java.compiler,java.datatransfer,java>
Nov 25 09:21:42 centos8 opennms[26880]: [DEBUG] System property 'opennms.library.jicmp' set to '/usr/lib64/libjicmp.so. Attempting to load ji>
Nov 25 09:21:42 centos8 opennms[26880]: [INFO] Successfully loaded jicmp library.
Nov 25 09:21:42 centos8 opennms[26880]: [DEBUG] System property 'opennms.library.jicmp6' set to '/usr/lib64/libjicmp6.so. Attempting to load >
Nov 25 09:21:42 centos8 opennms[26880]: [INFO] Successfully loaded jicmp6 library.
At this point, OpenNMS is started and listening on port 8980. You can check it with the following command:
ss -antpl | grep :8980
LISTEN 0 50 *:8980 *:* users:(("java",pid=27928,fd=988))
By default, SELinux is enabled in the CentOS 8 server. So you will need to disable it first. You can disable it by editing /etc/selinux/config file:
nano /etc/selinux/config
Find the following line:
SELINUX=enforcing
And, replace it with the following line:
SELINUX=permissive
Save and close the file then reboot the system to apply the changes.
Next, allow port 8980 through firewalld with the following command:
firewall-cmd --permanent --add-port=8980/tcp
Next, reload the firewalld to apply the changes:
firewall-cmd --reload
Access OpenNMS Web Interface
Now, open your web browser and access the OpenNMS web interface using the URL http://your-server-ip:8980/opennms. You will be redirected to the OpenNMS login page:
Provide default admin username as admin and password as admin then click on the Login button. You should see the following page:
Click on the Opt-in to send anonymous usage statistics to OpenNMS. You should see the OpenNMS dashboard in the following page:
Click on the Admin => Change password to change the default password. You should see the following page:
Change your default password and click on the Submit button. You should see the following page:
Click on the + icon to add the new host. You should see the following page:
Provide the name of new requisition and click on the OK button. You should see the following page:
Provide your remote host details and click on the Provision button. Once the host is added, you should see the following page:
Now, click on the Info => Nodes. You should get details information of the remote host in the following page:
Congratulations! you have successfully installed OpenNMS on CentOS 8 server. You can now add unlimited network hosts and devices to the OpenNMS and start monitoring from the central location.
