How to Install ElkArte Forum with Apache and Let’s Encrypt SSL on CentOS 8
ElkArte is a free and open-source forum software based on Simple Machine Forum. It is written in PHP and uses MariaDB as a database backend. It provides all features needed to build a full-featured community forum. It is simple, lightweight and uses responsive themes that are suitable for any modern browser, smartphone or tablet.
Features
- Simple and user-friendly interface
- Customizable and built-in add-on manager
- Improved Anti Spam functionality
- Drag and drop file attachments
- Integrated video embedding for youtube, vimeo and dailymotion
In this tutorial, we will show you howto install ElkArte with Let’s Encrypt SSL on CentOS 8.
- A server running CentOS 8.
Install LAMP Server
First, you will need to install Apache, MariaDB, PHP and other extensions in your system. You can install all of them by running the following command:
dnf install httpd mariadb-server php php-common php-json php-curl php-intl php-mbstring php-xmlrpc php-mysqlnd php-gd php-pgsql php-xml php-cli php-bcmath php-gmp php-zip unzip -y
Once all the packages are installed, edit the php.ini file and make some desired changes:
nano /etc/php.ini
Change the following values:
memory_limit = 256M
upload_max_filesize = 100M
max_execution_time = 360
date.timezone = America/Chicago
Save and close the file then start the Apache and MariaDB service and enable them to start at system reboot with the following command:
systemctl start httpd
systemctl start mariadb
systemctl enable httpd
systemctl enable mariadb
Configure MariaDB
By default, MariaDB root password is not set. So you will need to set it in your system. You can do that by running the following script:
mysql_secure_installation
Answer all the questions as shown below to set the root password:
Set root password? [Y/n] Y
Once the MariaDB is secured, log in to the MariaDB shell with the following command:
mysql -u root -p
Provide your root password when prompt then create a database and user with the following command:
MariaDB [(none)]> CREATE DATABASE elkarte;
MariaDB [(none)]> CREATE USER 'elkarte'@'localhost' IDENTIFIED BY 'password';
Next, grant all the privileges to the ElkArte database with the following command:
MariaDB [(none)]> GRANT ALL ON elkarte.* TO 'elkarte'@'localhost' WITH GRANT OPTION;
MariaDB [(none)]> EXIT;
Download ElkArte
First, you will need to download the latest version of ElkArte from the Git repository. You can download it with the following command:
wget https://github.com/elkarte/Elkarte/archive/master.zip
Once downloaded, unzip the downloaded file with the following command:
unzip master.zip
Next, move the extracted directory to the Apache root directory with the following command:
mv Elkarte-master /var/www/html/elkarte
Next, change the ownership and permissions with the following command:
chown -R apache:apache /var/www/html/elkarte
chmod -R 775 /var/www/html/elkarte
Configure Apache for ElkArte
Next, you will need to create an apache virtual host configuration file for ElkArte. You can create it with the following command:
nano /etc/httpd/conf.d/elkarte.conf
ServerAdmin [email protected]
DocumentRoot /var/www/html/elkarte
ServerName elk.example.com
<Directory /var/www/html/elkarte/>
Options FollowSymlinks
Require all granted
ErrorLog /var/log/httpd/error.log
CustomLog /var/log/httpd//access.log combined
systemctl restart httpd
At this point, Apache web server is configured to serve ElkArte. You can now proceed to the next step.
Configure Selinux and Firewall
By default, SELinux is enabled in CentOS 8. So you will need to configure it for your ElkArte website.
You can configure the SELinux with the following command:
setsebool httpd_can_network_connect on -P
chcon -R -u system_u -t httpd_sys_rw_content_t -r object_r /var/www/html/elkarte
Next, allow port 80 and 443 through the firewall with the following command:
firewall-cmd --reload
Access ElkArte
Now, open your web browser and access the ElkArte using the URL http://elk.example.com. You will be redirected to the following page:
Click on the Continue button to start the installation. You should see the following page:
Provide your database details and click on the Continue button. You should see the following page:
Provide your Forum name, URL and click on the Continue button. You should see the following page:
Now, click on the Continue button to populate the database. You should see the following page:
Provide your admin username, password, email and click on the Continue button. You should see the following page:
Click on the your newly installed forum button. You should see the following page:
Provide your admin username, password and click on the Log in button. You should see the ElkArte dashboard in the following page:
Secure Elkarte with Let’s Encrypt SSL
At this point, ElkArte is installed and configured. Next, it is recommended to secure your ElkArte site with Let’s Encrypt SSL. First, you will need to install the Certbot client to your system. The Certbot is a Let’s Encrypt client that can be used to download the SSL from Let’s Encrypt website and configure the Apache web server to use the downloaded SSL.
You can install the Certbot with the following command:
Now, run the following command to obtain and install an SSL certificate for your ElkArte website.
certbot-auto --apache -d elk.example.com
The above command will first install all the required dependencies on your server. Once installed, you will be asked to provide an email address and accept the term of service as shown below:
Note : If you got any SSL related error then restart the httpd service and run the above command again.
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for elk.example.com
Waiting for verification...
Cleaning up challenges
Created an SSL vhost at /etc/httpd/conf.d/elkarte-le-ssl.conf
Deploying Certificate to VirtualHost /etc/httpd/conf.d/elkarte-le-ssl.conf
Next, choose whether or not to redirect HTTP traffic to HTTPS, removing HTTP access.
Type 2 and hit Enter to start the installation process. Once the installation has been completed successfully, you should get the following output:
Redirecting vhost in /etc/httpd/conf.d/elkarte.conf to ssl vhost in /etc/httpd/conf.d/elkarte-le-ssl.conf
Congratulations! You have successfully enabled https://elk.example.com
https://www.ssllabs.com/ssltest/analyze.html?d=elk.example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/elk.example.com/fullchain.pem
/etc/letsencrypt/live/elk.example.com/privkey.pem
Your cert will expire on 2020-05-10. To obtain a new or tweaked
You can now access your ElkArte securely using the URL https://elk.example.com.
Congratulations! you have successfully installed ElkArte with Apache and Let’s Encrypt SSL on CentOS 8. You can now start building your own online forum. Feel free to ask me if you have any questions.
