How to Install Grafana 8 Monitoring Tool on Debian 11
Grafana is a free and open-source data visualizing tool that is used to monitor metrics from other hosts. It is written in Typescript and Go and allows you to create and edit both log and data graphs and create metrics. It can generate graphs and dashboards from a time-series database including Graphite, InfluxDB, or OpenTSDB and allows you to share them with other users.
Features
  • Dashboard templating
  • Provisioning Annotations
  • Kiosk mode and playlists
  • Custom plugins
  • Alerting and alert hooks
In this post, we will show you how to install Grafana 8 on Debian 11.
  • A server running Debian 11.
Before starting, it is recommended to update your system to the updated version. You can update all the packages using the following command:
After updating all the packages, install other required dependencies using the following command:
apt-get install gnupg2 curl wget git software-properties-common -y
Install Grafana 8
By default, Grafana is not included in the Debian 11 default repository. So you will need to add the Grafana repository to the APT. You can add it using the following command:
curl https://packages.grafana.com/gpg.key | apt-key add -
add-apt-repository "deb https://packages.grafana.com/oss/deb stable main"
Once the repository is added, update the repository cache and install the Grafana using the following command:
apt-get install grafana -y
Once the Grafana is installed, start and enable the Grafana service using the following command:
systemctl start grafana-server
systemctl enable grafana-server
You can also check the status of the Grafana service with the following command:
systemctl status grafana-server
? grafana-server.service - Grafana instance
Loaded: loaded (/lib/systemd/system/grafana-server.service; disabled; vendor preset: enabled)
Active: active (running) since Fri 2022-02-04 04:08:25 UTC; 5s ago
Docs: http://docs.grafana.org
Main PID: 8602 (grafana-server)
Tasks: 9 (limit: 2341)
Memory: 29.6M
CPU: 1.299s
CGroup: /system.slice/grafana-server.service
??8602 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:>
Feb 04 04:08:27 debian11 grafana-server[8602]: t=2022-02-04T04:08:27+0000 lvl=info msg="migrations completed" logger=migrator performed=381 s>
Feb 04 04:08:27 debian11 grafana-server[8602]: t=2022-02-04T04:08:27+0000 lvl=info msg="Created default admin" logger=sqlstore user=admin
Feb 04 04:08:27 debian11 grafana-server[8602]: t=2022-02-04T04:08:27+0000 lvl=info msg="Created default organization" logger=sqlstore
Feb 04 04:08:27 debian11 grafana-server[8602]: t=2022-02-04T04:08:27+0000 lvl=info msg="Initialising plugins" logger=plugin.manager
Feb 04 04:08:27 debian11 grafana-server[8602]: t=2022-02-04T04:08:27+0000 lvl=info msg="Plugin registered" logger=plugin.manager pluginId=inp>
Feb 04 04:08:27 debian11 grafana-server[8602]: t=2022-02-04T04:08:27+0000 lvl=info msg="Live Push Gateway initialization" logger=live.push_ht>
Feb 04 04:08:27 debian11 grafana-server[8602]: t=2022-02-04T04:08:27+0000 lvl=info msg="Writing PID file" logger=server path=/run/grafana/gra>
Feb 04 04:08:27 debian11 grafana-server[8602]: t=2022-02-04T04:08:27+0000 lvl=info msg="HTTP Server Listen" logger=http.server address=[::]:3>
Feb 04 04:08:27 debian11 grafana-server[8602]: t=2022-02-04T04:08:27+0000 lvl=info msg="warming cache for startup" logger=ngalert
Feb 04 04:08:27 debian11 grafana-server[8602]: t=2022-02-04T04:08:27+0000 lvl=info msg="starting MultiOrg Alertmanager" logger=ngalert.multio>
By default, Grafana listens on port 3000. You can check it with the following command:
ss -antpl | grep 3000
LISTEN 0 4096 *:3000 *:* users:(("grafana-server",pid=8602,fd=8))
Install Nginx as a Reverse Proxy for Grafana
Next, you will need to install and configure the Nginx as a reverse proxy for Grafana. First, install the Nginx using the following command:
apt-get install nginx -y
Once the Nginx is installed, create an Nginx virtual host configuration file with the following command:
nano /etc/nginx/conf.d/grafana.conf
server_name grafana.example.com;
access_log /var/log/nginx/grafana.log;
proxy_pass http://localhost:3000;
proxy_set_header X-Forwarded-Host $host:$server_port;
Save and close the file when you are finished. Then, verify the Nginx for any syntax error with the following command:
nginx -t
If everything is fine, you will get the following output:
Next, restart the Nginx to apply the configuration changes.
systemctl restart nginx
You can also check the Nginx status with the following command:
systemctl status nginx
Active: active (running) since Fri 2022-02-04 04:09:20 UTC; 4s ago
Docs: man:nginx(8)
Process: 8631 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 8632 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Main PID: 8633 (nginx)
Tasks: 2 (limit: 2341)
Memory: 2.5M
CPU: 35ms
??8633 nginx: master process /usr/sbin/nginx -g daemon on; master_process on;
??8634 nginx: worker process
Feb 04 04:09:20 debian11 systemd[1]: Starting A high performance web server and a reverse proxy server...
Feb 04 04:09:20 debian11 systemd[1]: nginx.service: Failed to parse PID from file /run/nginx.pid: Invalid argument
Feb 04 04:09:20 debian11 systemd[1]: Started A high performance web server and a reverse proxy server.
At this point, Nginx is installed and configured as a reverse proxy for Grafana. You can now proceed to the next step.
Access Grafana Dashboard
Now, open your web browser and access the Grafana web interface using the URL http://grafana.example.com. You will be redirected to the Grafana login page:
Grafana Login
Provide your admin username, password, and click on the Log in button. You should see the Grafana password reset screen:
Set a new password
Set your new password and click on the Submit button. You should see the Grafana dashboard on the following screen:
Grafana dashboard
Secure Grafana with Let’s Encrypt
Next, you will need to install the Certbot client package to install and manage the Let’s Encrypt SSL.
First, install the Certbot with the following command:
apt-get install certbot python3-certbot-nginx -y
Once the installation is finished, run the following command to install the Let’s Encrypt SSL on your website:
certbot --nginx -d grafana.example.com
You will be asked to provide a valid email address and accept the term of service as shown below:
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for grafana.example.com
Waiting for verification...
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/nginx/conf.d/grafana.conf
Next, choose whether or not to redirect HTTP traffic to HTTPS as shown below:
Type 2 and hit Enter to finish the installation. You should see the following output:
Redirecting all traffic on port 80 to ssl in /etc/nginx/conf.d/grafana.conf
Congratulations! You have successfully enabled https://grafana.example.com
https://www.ssllabs.com/ssltest/analyze.html?d=grafana.example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/grafana.example.com/fullchain.pem
/etc/letsencrypt/live/grafana.example.com/privkey.pem
Your cert will expire on 2022-05-07. To obtain a new or tweaked
- We were unable to subscribe you the EFF mailing list because your
e-mail address appears to be invalid. You can try again later by
visiting https://act.eff.org.
Congratulations! you have successfully installed Grafana 8 with Nginx and Let’s Encrypt SSL on Debian 11. You can now add your remote hosts and start monitoring them from the Grafana dashboard. Feel free to ask me if you have any questions.
