How to Install Discourse Forum with Nginx and Free Let’s Encrypt SSL on Debian 11
Discourse is an open-source community discussion platform built using the Ruby language. It is designed to work as a forum, chat software or mailing list. It integrates easily with other platforms, and its functionality can be expanded with plugins.
In this tutorial, you will learn how to install Discourse Forum with the Nginx server on a Debian 11 based server.
  • A server running Debian 11 with a minimum of 1GB RAM and 1 Core CPU. Discourse setup will automatically create a swap partition on systems with 1GB or less RAM. Therefore, it is recommended to install it on a system with at least 2GB RAM.
  • A Domain name (discourse.example.com) pointing to the server.
  • Everything is updated.
    $ sudo apt update && sudo apt upgrade
  • Few packages that your system needs.
    $ sudo apt install nano ufw software-properties-common dirmngr apt-transport-https gnupg2 ca-certificates lsb-release debian-archive-keyring -y
Step 1 – Configure Firewall
The first step is to configure the firewall. Debian comes with ufw (Uncomplicated Firewall).
$ sudo ufw status
You should get the following output.
Status: inactive
Allow SSH port so that the firewall doesn’t break the current connection on enabling it.
$ sudo ufw allow OpenSSH
Allow HTTP and HTTPS ports as well.
$ sudo ufw allow 80/tcp
$ sudo ufw allow 443/tcp
Enable the Firewall
$ sudo ufw enable
$ sudo ufw status
Status: active
To Action From
OpenSSH ALLOW Anywhere
80/tcp ALLOW Anywhere
443/tcp ALLOW Anywhere
443/tcp (v6) ALLOW Anywhere (v6)
Step 2 – Install Git
Install Git using the default Appstream.
$ sudo dnf install git
Confirm the installation.
$ git --version
git version 2.30.2
Run the following commands to configure the Git installation.
$ git config --global user.name "Your Name"
$ git config --global user.email "[email protected]"
Step 3 – Install Docker
To install the latest version of Docker, add Docker’s official GPG key.
$ curl -fsSL https://download.docker.com/linux/debian/gpg | sudo gpg --dearmor -o /usr/share/keyrings/docker-archive-keyring.gpg
Install the official Docker repository.
$ echo
"deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/debian
$(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
Update Debian system repositories.
$ sudo apt update
Install the latest version of Docker.
$ sudo apt install docker-ce docker-ce-cli containerd.io
Verify that Docker is running.
$ sudo systemctl status docker
Active: active (running) since Sat 2022-02-05 13:32:54 UTC; 1h ago
TriggeredBy: ? docker.socket
Docs: https://docs.docker.com
Main PID: 5818 (dockerd)
Tasks: 26
Memory: 1.4G
CPU: 5min 34.561s
?? 5818 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
??12162 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 8080 -container-ip 172.17.0.2 -contai>
??12169 /usr/bin/docker-proxy -proto tcp -host-ip :: -host-port 8080 -container-ip 172.17.0.2 -container-p>
By default, Docker requires root privileges. If you want to avoid using sudo every time you run the docker command, add your username to the docker group.
$ sudo usermod -aG docker $(whoami)
To enable this change, you will need to log out of the server and back in as the same user.
Step 4 – Download Discourse
Create the root directory for Discourse.
$ sudo mkdir /var/discourse
Clone the official Discourse Docker Github repository.
$ sudo git clone https://github.com/discourse/discourse_docker.git /var/discourse
Step 5 – Configure Discourse
Create the configuration file app.yml by copying the sample standalone.yml file.
$ sudo cp samples/standalone.yml containers/app.yml
Open the app.yml for editing.
$ sudo nano containers/app.yml
Set Domain
Set the variable DISCOURSE_HOSTNAME to the domain name, you chose for your forum. If you don’t have a domain name, you can use an IP address here.
DISCOURSE_HOSTNAME: 'discourse.example.com'
Configure Exposed ports
Change the line "80:80 to "8080:80". This will change the external HTTP port for Discourse to 8080 since we will use Nginx at port 80. Comment out the "443:443" line since we will install SSL externally.
expose:
- "8080:80" # http
#- "443:443" # https
Configure SMTP Settings
Fill out the following variables depending upon the transactional email service you are using. Set the email for your administrator account using the variable DISCOURSE_DEVELOPER_EMAILS. This step is compulsory otherwise, your forum won’t be bootstrapped.
DISCOURSE_DEVELOPER_EMAILS: '[email protected]'
DISCOURSE_SMTP_ADDRESS: smtp.example.com
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: [email protected]
DISCOURSE_SMTP_PASSWORD: your_smtp_password
#DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
#DISCOURSE_SMTP_DOMAIN: discourse.example.com # (required by some providers)
DISCOURSE_NOTIFICATION_EMAIL: [email protected] # (address to send notifications from)
Memory Settings (Optional)
If your server has low RAM, you can configure the following variables accordingly to reduce Discourse’s memory footprint.
db_shared_buffers: '128MB'
UNICORN_WORKERS: 2
The variable db_shared_buffers is usually set to 25% of the available memory.
GeoLite2 Settings (Optional)
If you want the IP lookup feature on Discourse, signup for the free Maxmind Geolite2 account and get a license key. Paste that license key as the value for the following variable.
DISCOURSE_MAXMIND_LICENSE_KEY: your_maxmind_license_key
Step 6 – Install Discourse
Run the following command to bootstrap your Discourse container.
$ sudo ./launcher bootstrap app
Start Discourse application.
$ sudo ./launcher start app
You can access the forum by visiting the URLs http://yourserver_IP:8080 or http://discourse.example.com:8080 in your browser. You will get the following screen.
Discourse Setup Home
Click the Register button to proceed. The email id set in the app.yml file will be pre-filled for you.
Discourse Create Admin Account
Click the Register button to register the administrator account. You will proceed to the email confirmation screen.
Discourse Email Confirm
If your SMTP settings are correct, you will receive a mail to activate the account. Click the link from your email to finish setting up the account.
Discourse Confirmation Email
Click the Activate button to finish the installation.
Discourse Account Activate
You will get to the Discourse’s Setup Wizard screen. You can either skip it to proceed directly to the forum or go through the entire wizard.
Discourse Setup Wizard
Your Discourse forum is ready. The next step is installing SSL and putting the forum behind the Nginx server.
Discourse Homepage
Step 7 – Install SSL
To install an SSL certificate using Let’s Encrypt, we need to install the Certbot tool.
We will use the Snapd package installer for that. Since most Debian servers don’t ship with it, install the Snapd installer.
$ sudo apt install snapd
Ensure that your version of Snapd is up to date.
Install Certbot.
Verify the installation.
$ certbot --version
certbot 1.22.0
Generate the SSL certificate.
$ sudo certbot certonly --standalone --agree-tos --no-eff-email --staple-ocsp --preferred-challenges http -m [email protected] -d discourse.example.com
The above command will download a certificate to the /etc/letsencrypt/live/discourse.example.com directory on your server.
$ sudo openssl dhparam -out /etc/ssl/certs/dhparam.pem 2048
Create a challenge webroot directory for Let’s Encrypt auto-renewal.
$ sudo mkdir -p /var/lib/letsencrypt
Create a Cron Job to renew the SSL. It will run every day to check the certificate and renew if needed. For that, first, create the file /etc/cron.daily/certbot-renew and open it for editing.
$ sudo nano /etc/cron.daily/certbot-renew
Paste the following code.
#!/bin/sh
certbot renew --cert-name discourse.example.com --webroot -w /var/lib/letsencrypt/ --post-hook "systemctl reload nginx"
Change the permissions on the task file to make it executable.
$ sudo chmod +x /etc/cron.daily/certbot-renew
Step 8 – Install and Configure Nginx
Debian ships with an older version of Nginx. You need to download the official Nginx repository to install the latest version.
Import the official Nginx signing key.
$ echo "deb [signed-by=/usr/share/keyrings/nginx-archive-keyring.gpg arch=amd64] http://nginx.org/packages/debian `lsb_release -cs` nginx"
Update the Debian repositories.
$ sudo apt update
Install Nginx.
$ sudo apt install nginx
Verify the installation. Make sure you use sudo every time you run the Nginx command on Debian. Otherwise, it won’t work.
$ sudo nginx -v
nginx version: nginx/1.20.2
Create and open the file /etc/nginx/conf.d/discourse.conf for editing.
$ sudo nano /etc/nginx/conf.d/discourse.conf
# enforce HTTPS
listen [::]:80;
server_name discourse.example.com;
listen 443 ssl http2;
listen [::]:443 ssl http2;
access_log /var/log/nginx/discourse.access.log;
error_log /var/log/nginx/discourse.error.log;
# SSL
ssl_certificate /etc/letsencrypt/live/discourse.example.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/discourse.example.com/privkey.pem;
ssl_trusted_certificate /etc/letsencrypt/live/discourse.example.com/chain.pem;
ssl_session_timeout 5m;
ssl_session_tickets off;
ssl_prefer_server_ciphers on;
ssl_stapling on;
ssl_stapling_verify on;
resolver 8.8.8.8;
client_max_body_size 100m;
proxy_pass http://discourse.example.com:8080/;
proxy_http_version 1.1;
Save the file by pressing Ctrl + X and entering Y when prompted once finished.
$ sudo nginx -t
Start the Nginx service to enable the new configuration.
$ sudo systemctl start nginx
Step 9 – Discourse Commands
Activate Discourse Administrator from the command-line
If you don’t receive the activation email, you can activate the administrator account from the command line.
Switch to the Discourse directory.
$ cd /var/discourse
Enter the Discourse container Shell.
$ sudo ./launcher enter app
Enter the command rails c to access the Rails command prompt.
root@discourse-app:/var/www/discourse# rails c
You will see the following prompt.
[1] pry(main)>
Enter the command to locate the administrator account.
[1] pry(main)> User.find_by_email("[email protected]")
=> #<User:0x00005564492032a0
username: "username",
created_at: Sun, 06 Feb 2022 14:46:58.451302000 UTC +00:00,
updated_at: Sun, 06 Feb 2022 14:54:17.079564000 UTC +00:00,
seen_notification_id: 4,
last_posted_at: nil,
password_hash: "[FILTERED]",
salt: "20d6012d3c98da70896dcfc27bc9d264",
active: true,
username_lower: "username",
last_seen_at: Mon, 07 Feb 2022 08:34:12.435844000 UTC +00:00,
admin: true,
last_emailed_at: Sun, 06 Feb 2022 14:47:00.694121000 UTC +00:00,
trust_level: 1,
approved: false,
approved_by_id: nil,
approved_at: nil,
previous_visit_at: Sun, 06 Feb 2022 15:40:35.804941000 UTC +00:00,
suspended_at: nil,
suspended_till: nil,
date_of_birth: nil,
flag_level: 0,
ip_address: #<IPAddr: IPv4:69.28.90.35/255.255.255.255>,
moderator: false,
title: nil,
uploaded_avatar_id: 3,
Enter q to return to the prompt and enter the following commands in sequence.
[2] pry(main)> user.approved = true
[3] pry(main)> user.save
[4] pry(main)> EmailToken.confirm(user.email_tokens.first.token)
Type exit twice to return to the shell. Your administrator account is activated and ready for use.
Upgrade Discourse
To upgrade the forum, you can use one of two ways. The first way is to upgrade it via the administrator dashboard. The second method is to use a command line.
$ cd /var/discourse
Update the Discourse installation by grabbing the latest files from Github.
$ git pull
Rebuild Discourse.
$ sudo ./launcher rebuild app
You need to rebuild Discourse every time you make any changes in the app.yml file. After making the changes, run the command above. It destroys the old container, bootstraps a new one and starts it.
Stop Discourse
$ sudo ./launcher stop
View Discourse Logs
$ sudo ./launcher logs
This concludes the tutorial. You have installed the Discourse forum using Docker behind the Nginx web server on a Debian 11 server. If you have any questions, post them in the comments below.
