How to Install Drupal with Apache and Let’s Encrypt SSL on Debian 11
Drupal is a free and open-source content management system based on the LAMP stack. Drupal has great standard features that allow you to create powerful websites and blogs. It comes with a lot of themes, plugins, and widgets that help you to create a website without any programming knowledge. It provides a lot of features such as multi-site support, multi-language support, comment system, RSS feed, user registration, and more.
In this post, we will show you how to install Drupal CMS with Apache and Let’s Encrypt SSL on Debian 11.
  • A server running Debian 11.
Install LAMP Stack
Drupal is based on LAMP stack. So the LAMP stack must be installed in your server. If not installed, you can install it by running the following command:
apt-get install apache2 mariadb-server mariadb-client php libapache2-mod-php php-cli php-mysql php-zip php-gd php-fpm php-json php-common php-intl php-mbstring php-curl php-xml php-pear php-tidy php-soap php-bcmath php-xmlrpc -y
Once the LAMP stack is installed, edit the php.ini file and change some default settings:
nano /etc/php/7.4/apache2/php.ini
Change the following lines:
memory_limit = 256M
upload_max_filesize = 32M
max_execution_time = 300
date.timezone = Asia/Kolkata
Create a Drupal Database
Drupal uses a MariaDB as a database backend. So you will need to create a database and user for Drupal.
First, log in to MariaDB with the following command:
mysql
Once you are log in, create a database and user using the following command:
MariaDB [(none)]> CREATE DATABASE drupaldb;
MariaDB [(none)]> CREATE USER 'drupaluser'@'localhost' IDENTIFIED BY "securepassword";
Next, grant all the privileges to the Drupal database using the following command:
MariaDB [(none)]> GRANT ALL ON drupaldb.* TO 'drupaluser'@'localhost' IDENTIFIED BY "securepassword";
MariaDB [(none)]> EXIT;
Download Drupal
First, go to the Drupal website pick the latest version of Drupal and download it with the following command:
wget https://www.drupal.org/download-latest/tar.gz -O drupal.tar.gz
Once the Drupal is downloaded, extract the downloaded file with the following command:
tar -xvf drupal.tar.gz
Next, move the extracted directory to the Apache default root directory:
mv drupal-* /var/www/html/drupal
Next, change the ownership and permission of the Drupal directory using the following command:
chown -R www-data:www-data /var/www/html/drupal/
chmod -R 755 /var/www/html/drupal/
Create an Apache Virtual Host for Drupal
Next, you will need to create an Apache virtual host configuration file to host Drupal. You can create it using the following command:
nano /etc/apache2/sites-available/drupal.conf
DocumentRoot /var/www/html/drupal/
ServerName drupal.example.com
<Directory /var/www/html/drupal/>
Options FollowSymlinks
Require all granted
<Directory /var/www/html/>
RewriteEngine on
RewriteBase /
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule ^(.*)$ index.php?q=$1 [L,QSA] </Directory>
Save and close the file then enable the Drupal virtual host and Apache rewrite module with the following command:
a2ensite drupal.conf
a2enmod rewrite
Next, restart the Apache service to apply the changes:
systemctl restart apache2
To check the status of the Apache, run the following command:
systemctl status apache2
Active: active (running) since Sat 2021-09-18 14:59:40 UTC; 5s ago
Process: 19698 ExecStart=/usr/sbin/apachectl start (code=exited, status=0/SUCCESS)
Main PID: 19703 (apache2)
Tasks: 6 (limit: 2341)
Memory: 15.3M
CPU: 78ms
??19703 /usr/sbin/apache2 -k start
??19704 /usr/sbin/apache2 -k start
??19705 /usr/sbin/apache2 -k start
??19706 /usr/sbin/apache2 -k start
??19707 /usr/sbin/apache2 -k start
??19708 /usr/sbin/apache2 -k start
At this point, the Apache webserver is configured to serve Drupal. You can now proceed to the next step.
Access Drupal Website
Now, open your web browser and access Drupal using the URL http://drupal.example.com. You will be redirected to the following page:
Choose language
Choose the English language and click on the Save and Continue button, you should see the following image:
Installation profile
Select an Installation Profile and click on the Save and Continue button. You should see the following page:
Database configuration
In the Database Configuration page, provide all the required database details like database name, database username, and password, database host, then click on the Save and Continue button, you should see the following image:
Site information
Regional settings
In the Drupal Site Configuration page, provide your site name, admin username and password then click on the Save and Continue button to start installing Drupal. Once Drupal is installed, you should see the Drupal dashboard in the following image:
Login to Drupal
Enable Let’s Encrypt SSL Support on Drupal Website
It is always a good idea to secure your website with Let’s Encrypt SSL. First, you will need to install the Certbot client to install and manage the SSL. By default, the Certbot package is included in the Debian 11 default repository so you can install it with the following command:
apt-get install python3-certbot-apache -y
Once the Certbot is installed, run the following command to secure your website with Let’s Encrypt SSL:
certbot --apache -d drupal.example.com
You will be asked to provide your email and accept the term of service as shown below:
Plugins selected: Authenticator standalone, Installer None
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for drupal.example.com
Enabled Apache rewrite module
Waiting for verification...
Cleaning up challenges
Created an SSL vhost at /etc/apache2/sites-available/drupal-le-ssl.conf
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Deploying Certificate to VirtualHost /etc/apache2/sites-available/drupal-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/drupal-le-ssl.conf
Next, select whether or not to redirect HTTP traffic to HTTPS as shown below:
Type 2 and hit Enter to install the Let’s Encrypt SSL for your website:
Redirecting vhost in /etc/apache2/sites-enabled/drupal.conf to ssl vhost in /etc/apache2/sites-available/drupal-le-ssl.conf
Congratulations! You have successfully enabled https://drupal.example.com
https://www.ssllabs.com/ssltest/analyze.html?d=drupal.example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/drupal.example.com/fullchain.pem
/etc/letsencrypt/live/drupal.example.com/privkey.pem
Your cert will expire on 2021-04-20. To obtain a new or tweaked
That’s it for now. You have successfully installed Drupal with Let’s Encrypt SSL on Debian 11. You can now start creating your own blog or website without any programming knowledge. Feel free to ask me if you have any questions.
