Redmine is a free, open-source, popular project management and issue-tracking system. It supports PostgreSQL and MariaDB databases and is built on the Ruby on Rails framework. It has built-in third-party plugin support, allowing you to set up multiple projects, wikis, and forums. It offers a wide range of features, including Email and Feeds notifications, Multiple language support, Role-based access control, File management, and more.
This tutorial will explain how to install the Redmine project management system on CentOS.
- A server running CentOS 8.
Install Required Dependencies
Before starting, you will need to install some dependencies on your server. You can install all of them using the following command:
dnf group install "Development Tools"
dnf install zlib-devel curl-devel openssl-devel -y
Install and Configure MariaDB Database
Redmine uses MariaDB as a database backend so you will need to install the MariaDB database server in your server. You can install it using the following command:
dnf install mariadb-server mariadb-devel -y
Once the MariaDB server is installed, start the MariaDB service and enable it to start at system reboot:
systemctl start mariadb
systemctl enable mariadb
Next, log in to the MariaDB shell with the following command:
mysql
Once you are log in, create a database and user for Redmine with the following command:
MariaDB [(none)]> CREATE DATABASE redmine CHARACTER SET utf8mb4;
MariaDB [(none)]> GRANT ALL PRIVILEGES ON redmine.* TO 'redmine'@'localhost' IDENTIFIED BY 'password';
MariaDB [(none)]> EXIT;
Install Ruby and Passenger
Next, you will need to install Ruby and Passenger to your system.
First, install and enable the EPEL repo with the following command:
dnf install epel-release -y
dnf config-manager --enable epel -y
Next, install the Ruby and Passenger using the following command:
dnf install mod_passenger passenger passenger-devel ruby ruby-devel -y
Install Redmine
First, you will need to create a separate user for Redmine. You can create it with the following command:
useradd -m -U -r -d /opt/redmine redmine
Next, log in to Redmine user and download the latest version of Redmine with the following command:
su - redmine
wget --no-check-certificate https://www.redmine.org/releases/redmine-4.2.1.zip
unzip redmine-4.2.1.zip
Next, rename the extracted directory with the following command:
mv redmine-4.2.1 redmine
Next, change the directory to redmine and copy the sample database configuration file:
cd redmine
cp config/database.yml.example config/database.yml
Next, edit the database configuration file and define your database settings:Advertisement
nano config/database.yml
Change the following lines that match your database:
production: adapter: mysql2 database: redmine host: localhost username: redmine password: "password" encoding: utf8mb4
Save and close the file then install the Bundler with the following command:
gem install bundler --no-rdoc --no-ri
Next, install other dependencies with the following command:
bundle install --without development test postgresql sqlite --path vendor/bundle
Next, generate a secret token with the following command:
bundle exec rake generate_secret_token
Next, generate the database objects needed by the application using the following command:
RAILS_ENV=production bundle exec rake db:migrate
Finally, start the application with the following command:
bundle exec rails server webrick -e production
/usr/bin/ruby: warning: shebang line ending with \r may cause problems => Booting WEBrick => Rails 5.2.5 application starting in production on http://0.0.0.0:3000 => Run `rails server -h` for more startup options [2021-06-24 00:40:15] INFO WEBrick 1.4.2 [2021-06-24 00:40:15] INFO ruby 2.5.5 (2019-03-15) [x86_64-linux] [2021-06-24 00:40:15] INFO WEBrick::HTTPServer#start: pid=43076 port=3000
Press CTRL + C to stop the application.
Next, exit from the Redmine user with the following command:
exit
Create a Systemd Service File for Redmine
Next, you will need to create a systemd service file to manage the Redmine application. You can create it with the following command:
nano /usr/lib/systemd/system/redmine.service
[Unit] Description=Redmine server After=syslog.target After=network.target [Service] Type=simple User=redmine Group=redmine ExecStart=/bin/ruby /opt/redmine/redmine/bin/rails server webrick -e production # Give a reasonable amount of time for the server to start up/shut down TimeoutSec=300 [Install] WantedBy=multi-user.target
Save and close the file then reload the systemd daemon with the following command:
systemctl daemon-reload
Next, start the Redmine service and enable it to start at system reboot:
systemctl start redmine
systemctl enable redmine
Now, check the status of the Redmine with the following command:
systemctl status redmine
? redmine.service - Redmine server
Loaded: loaded (/usr/lib/systemd/system/redmine.service; disabled; vendor preset: disabled)
Active: active (running) since Thu 2021-06-24 04:26:51 EDT; 1min 37s ago
Main PID: 44044 (ruby)
Tasks: 3 (limit: 25014)
Memory: 121.6M
CGroup: /system.slice/redmine.service
??44044 /bin/ruby /opt/redmine/redmine/bin/rails server webrick -e production
Jun 24 04:26:51 centos8 systemd[1]: Started Redmine server.
Jun 24 04:26:52 centos8 ruby[44044]: /bin/ruby: warning: shebang line ending with \r may cause problems
Jun 24 04:26:56 centos8 ruby[44044]: [2021-06-24 04:26:56] INFO WEBrick 1.4.2
Jun 24 04:26:56 centos8 ruby[44044]: [2021-06-24 04:26:56] INFO ruby 2.5.5 (2019-03-15) [x86_64-linux]
Jun 24 04:26:56 centos8 ruby[44044]: [2021-06-24 04:26:56] INFO WEBrick::HTTPServer#start: pid=44044 port=3000
At this point, Redmine is started and listening on port 3000. You can check it with the following command:
ss -antpl | grep 3000
LISTEN 0 128 0.0.0.0:3000 0.0.0.0:* users:(("ruby",pid=44044,fd=9))
Configure Nginx as a Reverse Proxy for Redmine
Next, you will need to install and configure Nginx as a reverse proxy for Redmine. First, install the Nginx server with the following command:
dnf install nginx -y
Next, create an Nginx virtual host configuration file with the following command:
nano /etc/nginx/conf.d/redmine.conf
upstream backend {
server 127.0.0.1:3000;
server_name redmine.example.com;
access_log /var/log/nginx/redmine.example.com-access.log;
error_log /var/log/nginx/redmine.example.com-error.log;
proxy_pass http://backend/;
proxy_http_version 1.1;
proxy_set_header X-Forward-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forward-Proto http;
proxy_set_header X-Nginx-Proxy true;
proxy_redirect off;
Save and close the file then verify the Nginx for any syntax error with the following command:
nginx -t
nginx: the configuration file /etc/nginx/nginx.conf syntax is ok nginx: configuration file /etc/nginx/nginx.conf test is successful
Next, start the Nginx service and enable it to start at system reboot:
systemctl start nginx
systemctl enable nginx
You can also check the status of the Nginx with the following command:
systemctl status nginx
? nginx.service - The nginx HTTP and reverse proxy server
Loaded: loaded (/usr/lib/systemd/system/nginx.service; disabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/nginx.service.d
??php-fpm.conf
Active: active (running) since Thu 2021-06-24 04:33:48 EDT; 25s ago
Process: 45832 ExecStart=/usr/sbin/nginx (code=exited, status=0/SUCCESS)
Process: 45830 ExecStartPre=/usr/sbin/nginx -t (code=exited, status=0/SUCCESS)
Process: 45828 ExecStartPre=/usr/bin/rm -f /run/nginx.pid (code=exited, status=0/SUCCESS)
Main PID: 45833 (nginx)
Memory: 5.3M
??45833 nginx: master process /usr/sbin/nginx
??45834 nginx: worker process
??45835 nginx: worker process
Jun 24 04:33:48 centos8 systemd[1]: Starting The nginx HTTP and reverse proxy server...
Jun 24 04:33:48 centos8 nginx[45830]: nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
Jun 24 04:33:48 centos8 nginx[45830]: nginx: configuration file /etc/nginx/nginx.conf test is successful
Jun 24 04:33:48 centos8 systemd[1]: Started The nginx HTTP and reverse proxy server.
Access Redmine
Now, you can access the Redmine web interface using the URL http://redmine.example.com. You should see the following page:
Click on the Sign in button. You should see the Redmine login page:
Provide the default user and password as admin then clicks on the Login button. You will be redirected to the change password screen:
Set your new admin password and click on the Save button to save the changes.
Congratulations! You have successfully installed Redmine on CentOS 8 with Nginx. You can now use Redmine in your organization and manage your project from the central location.
