Vim – Find and Replace
Manipulating text and making multiple edits at once is crucial when working in Vim or its older version Vi.
As a popular Linux text editor, Vim offers several practical ways to find and replace terms quickly and efficiently.
This tutorial shows how to use the find and replace function in Vim/Vi and keep track of all the changes.
Vi/Vim - Find and Replace
Note: If you don’t have Vim, check out these tutorials and learn how to install the text editor on CentOS or Ubuntu.
Find and Replace Methods
Finding and replacing text patterns in Vim simplifies navigation and changes in large files.
Hence, Vim offers two ways to search and replace text, depending on whether a single change or multiple edits are necessary.
Warning: Vim must be in normal mode to execute commands. Go back to normal mode with the Esc key.
Slash and Dot Command
Use the slash and dot command to find and replace a single occurrence of a word in Vim.
Open a file in Vim and follow these steps:
  1. Press the slash key (/).
  2. Type the search term to highlight it in the text and hit Enter.
Vim the Slash and Dot Command Using the Slash Key Terminal Output
  1. Use the Esc key to return to normal mode.
  2. Type cgn and enter the replacement term.
Vim the Slash and Dot Command With the Replacement Term Terminal Output
  1. Go back to normal mode.
  2. Hit n to move to the next search term occurrence.
Vim the Slash and Dot Command - Using n Terminal Output
  1. Press the dot (.) key to replace the next occurrence with the same replacement term.
Vim the Slash and Dot Command - Dot Terminal Output
Note: The dot method also works with other Vim search methods.
Substitute Command
The substitute command :s is more versatile than the slash and dot command.
The basic :s command syntax is:
:s/search_term/replacement_term/
The command searches for the search_term in the current line, the line where the cursor is. Next, :s changes the search_term to the replacement_term.
For example, to find the term vi in the current line and replace it with Vim, use the following command:
:s/vi/Vim/
Vim the Substitute Command Finding a Term Terminal Output
Hit Enter and the terminal shows that the string vi changed to Vim:
Vim the Substitute Command Replacing a Term Terminal Output
However, :s offers much more than the basic search and replace function. For instance, the command accepts different options and flags. The complete syntax for the substitute command looks like this:
:[range]s/search_term/replace_term/[flags] [count]
These options and flags help specify the search. For example, to find all occurrences of vi in the current line, add the g flag.
:s/vi/Vim/g
Vim the Substitute Command With g Flag Process Terminal Output
Hit Enter to replace both instances with Vim:
Vim the Substitute Command With g Flag Result Terminal Output
Moreover, confirm each substitution with the c flag:
:s/vi/Vim/gc
Vim the Substitute Command with c flag Process Terminal Output
Output is the following:
Vim the Substitute Command With c Flag Options Terminal Output
Vim prompts users to choose between several options:
  • Substitute selected match with Y.
  • Skip selected match with n.
  • Replace all matches with a.
  • Quit the command with q.
  • Replace the selected match and quit with I.
However, the ^E and ^Y options are available in some Vim installations. Use them to scroll the screen:
  • Scroll the screen up with Ctrl + E.
  • Scroll the screen down with Ctrl + Y.
Find and Replace Important Considerations
The find and replace tools in Vim, especially the substitute command, offer additional possibilities for a more specific and effective search. Check out how to customize the search and replace operation in the following text.
Search Range
Specifying a range when running the :s command helps users search and replace patterns beyond the current line.
To determine the range:
  1. Add line numbers separated by a comma to find and replace a pattern in specific lines.
For example, substitute all occurrences of vi to Vim from line 1 to line 3:
:1,3s/vi/Vim/g
Vim the Substitute Command With Line Numbers Separated by a Comma Process Terminal Output
The output shows that only the first two instances of vi, in the first three lines, were changed to Vim:
Vim the Substitute Command With Line Numbers Separated by a Comma Terminal Output
  1. Choose the % symbol and add the g flag to find and replace a pattern in the entire file.
:%s/vi/Vim/g
Vim the Substitute Command With % and g Flag Terminal Output
  1. Use a dot (.) and a dollar sign ($) separated by a comma to substitute everything from the current line to the last line.
:.,$s/vi/Vim/g
Vim Substitute Command With the Dot and Dollar Sign Process
Since the current line is also the last line, the output shows that the instances of vi in the last line were changed.
Vim Substitute Command With the Dot and Dollar Sign Command Terminal Output
  1. Combine +/- symbols with numbers to add or subtract lines from the current one.
For example, to substitute each vi with Vim starting from the current line and the next two lines, type:
:.,+2s/vi/Vim/g
Vim the Substitute Command-Using + and- Symbols With Numbers
Note: Learn how to show line numbers in Vim with this guide.
Case Sensitivity
The find and replace process in Vim is case-sensitive by default. For example, using the :s command to substitute vim (in lowercase) with vi does not work. This is because Vim is always in capitalized in this text. Therefore, use Vim instead of vi as the search term.
To make the find and replace operation case insensitive, use one of the two methods:
  1. Add the i flag.
:%s/vim/vi/gi
Vim Substitute Command With the i Tag Terminal Output
The output shows that both instances of Vim have been found and replaced with vi.
Use the I flag to turn the case-sensitive search back on.
  1. Append c after the search pattern.
:%s/vimc /vi/g
Vim the Substitute Command With the Appended c Terminal Output
The output shows that even though the search term is lower case, the command finds the uppercase Vim in the text.
Adding the /C after a search pattern turns on case-sensitive search.
Word Substitution
The :s command, by default, searches for patterns, not unique words. For example, using vi as the search pattern results in matches where vi is part of a larger word, such as visible.
Vim the Substitute Command Searching for Whole Words Terminal Output
Executing the command in the entire text changes patterns included in other words as well.
Vim Substitute Command Replacing Words Nested in Other Words Terminal Output
Search and replace a whole word with:
:%s/<search_term>/replace_term/
The < symbol marks the beginning and the > symbol the end of a word. For example, to search for the word vi, but not when part of a bigger word, and replace the word with Vim, use:
:%s/<vi>/Vim/g
Vim the Substitute Command Find and Replace Whole Word Terminal Output
Find and Replace History
Running the :s command without any options shows previous substitute operations. In addition, run the :s command and use the up/down arrow keys to move across the document.
More importantly, use the :s command to apply previous substitutes to new text. For example, the history shows that the command replaced all instances of vi with Vim.
Running :s finds any already made substitutes, but also all instances of vi not changed yet.
Vim Substitute Command History Terminal Output
Find and Replace Examples
The find and replace function in Vim has extensive practical use. Thus, outlined below are common substitute command examples.
Find and Replace Entire Lines
Use :s to substitute entire lines in Vim based on a single parameter. For example, substitute every line starting with Do you with Learn more about Vim! using this command:
:%s/^Do you .*/ Learn more about Vim!/g
Vim Substitute Command Replacing Entire Line Terminal Output
The ^(caret) symbol matches the beginning of a line, and * matches the rest of the line.
The output shows the change:
Change Number in Numbered List
Adding an item in the middle of a numbered list in Vim means that the user has to change numbers in all the subsequent lines.
Vim Adding an Item to a Numbered List
The substitute command changes the numbers of all other articles accordingly. Use this command:
:5,$s/d+/=submatch(0) + 1/
Vim Substitute Command Changing Numbers in a Numbered List
The command consists of:
  • :5,$ – The range from the fifth line to the last line.
  • d+ – The digits sequence as the search term.
  • =submatch(0) + 1 – The replacement term adding 1 to each match.
After executing the substitute command, the output looks like this:
Vim Substitute Command Changed Numbers in a Numbered List
Eliminate Double Spaces
Double spaces are common typing errors, but :s takes care of this quite quickly with:
:%s/[double space]/[single space]/g
Vim Substitute Command Finding Double Space Terminal Output
All spaces in the last line are doubled. After executing the command, the sentence is single-spaced:
Vim Substitute Command Eliminating Double Spaces Terminal Output
Replace Different Words with One
Use the substitute command to substitute different search terms with one replacement term. For example, replace every instance of vi and Vim with This text editor.
:%s/(vi|Vim)/This text editor/g
Vim the Substitute Command Replacing Different Words With One Process
The changed text looks like this:
Vim the Substitute Command Replacing Different Words With One Result Terminal Output
Delete All Pattern Occurrences
Instead of substituting the search term, delete the pattern by omitting the replacement term. For example, delete all instances of Vim with:
:%s/Vim/
Vim Substitute Command Deleting Words Terminal Output
After reading this tutorial, you know how to find and replace text in Vim.
Next, check out and download this useful Vim Commands Cheat Sheet to learn other common Vim commands.
