uname Linux Command with Examples
The uname (UNIX name) command in Linux is a simple yet powerful tool that offers information about a Linux machine’s operating system and hardware platform. Sysadmins and developers use uname for troubleshooting and monitoring purposes.
This article provides a comprehensive guide on the uname command in Linux and its various options.
uname command in Liux
  • A system running Linux. (This tutorial uses Ubuntu 22.04.)
  • Access to the terminal.
uname Command Syntax
The uname command uses the following basic syntax:
uname [option1] [option2]
When run without any options, uname prints the Kernel name, the same as using the -s option.
uname
uname terminal output
However, using the uname command with specific options provides a more detailed output.
uname Command Options
Options modify the command output by printing specific information, such as the hostname, Kernel release number and version, machine architecture, etc.
The table below is a complete list of the available uname command options and their descriptions:
Option (Short Form) Option (Long Form) Desription
-a  --all Prints all system information.
-s --kernel-name Prints the Kernel name.
-n  --nodename Prints the network node hostname.
-r  --kernel-release Prints the Kernel release number.
-v  --kernel-version Prints the Kernel version.
-m  --machine Outputs the machine’s architecture type.
-p --processor Prints the CPU type.
-i  --hardware-platform Prints hardware platform type.
-o  --operating-system Prints the operating system name.
n/a --help Display a list of all available options.
uname Command Examples
The uname command works with one or more arguments to show different system information. The following sections provide practical examples for the uname command.
Show All System Info
The uname command with the -a argument prints all relevant system information. This is how sysadmins usually use the command to get all relevant information with one request.
uname ˗a
uname a terminal output
The output includes the following information:
  • Kernel name: Linux.
  • Hostname: sara-pnap.
  • Kernel release: 5.15.0-58-generic.
  • Kernel version and the build date: #64~20.04.1-Ubuntu SMP Fri Jan 6 16:42:31 UTC 2023.
  • Machine architecture name: x86_64.
  • CPU type: x86_64.
  • Hardware platform: x86_64.
  • Operating system: GNU/Linux.
Print the Kernel Release Number
The uname ˗a command’s output is extensive but disorganized and difficult to read. To show specific details about the system, use uname with different arguments.
For instance, to display only the Kernel release number, use uname -r:
uname -r
uname -r terminal output
Check Kernel Version
To check the system’s Kernel version, run uname -v:
uname -v
uname -v terminal output
The uname -v output provides more details about the Kernel than the uname -r command. The output includes:
  • Kernel build number: #64.
  • The specific release of the kernel software. In this case, a version of Ubuntu – 20.04.1.
  • The OS name: Ubuntu.
  • An indicator that the Kernel is designed to run on a computer with multiple processors: SMP (Symmetric Multi-Processing).
  • The date and time when the Kernel was built: Fri Jan 6 16:42:31 UTC 2023.
Print System Hostname
Use uname -n to print the system’s hostname. The hostname is a unique name assigned to a computer in a network and used to identify it.
uname -n
uname -n terminal output
Note: The hostname command prints the same output.
Display Hardware Architecture
The uname -m command prints the machine’s hardware architecture:
uname -m
uname -m terminal output
The -m option helps understand the system’s underlying architecture.
Print CPU Type
The uname -p option displays the systems’ processor type, which includes information about the system’s architecture.
uname -p
uname -p terminal output
Print Hardware Platform Type
Print the hardware platform type with uname -i. The hardware platform provides information about the type of hardware the system is running on.
uname -i
uname -i terminal output
Note: The -m, -p, -i arguments often print the same output because these options provide information about the hardware’s architecture. However, the specific information each option offers depends on the OS in use.
Print Operating System Name
Use uname -o to print the OS name:
uname -o
uname -o terminal output
Combining Command Options
Use several uname options to get a specific combination of system information. For example, to display the Kernel’s release number and build date, use the -r and -v options:
uname -r -v
uname -r -v terminal output
To print the Kernel name as well, run:
uname -srv
uname -srv terminal output
After reading this article, you should know how the uname command in Linux works.
