Strawberry Music Player & Organizer Is A Fork of Clementine
strawberry-icon
strawberry-icon
Strawberry is a free and open source audio player and music collection organizer. It is a fork of Clementine released in 2018 aimed at music collectors, audio enthusiasts and audiophiles. The name is inspired by the band Strawbs.
Strawberry is written in C++ with Qt 5 framework. It’s based on a heavily modified version of Clementine created in 2012-2013. And it features:
  • Supports WAV, FLAC, WavPack, DSF, DSDIFF, Ogg Vorbis, Speex, MPC, TrueAudio, AIFF, MP4, MP3, ASF and Monkey’s Audio.
  • Audio CD playback
  • Native desktop notifications
  • Playlists in multiple formats
  • Advanced audio output and device configuration for bit-perfect playback on Linux
  • Edit tags on music files
  • Fetch tags from MusicBrainz
  • Album cover art from Last.fm, Musicbrainz and Discogs
  • Song lyrics from AudD
  • Support for multiple backends
  • Audio analyzer, Audio equalizer
  • Transfer music to iPod, iPhone, MTP or mass-storage USB player
  • Streaming support for Tidal
  • Scrobbler with support for Last.fm, Libre.fm and ListenBrainz
strawberry-musicplayer
How to Install Strawberry in Ubuntu:
Installing the audio player is quite easy as it has been made into Snap store.
For Ubuntu 18.04 and higher, simply open Ubuntu Software, search for and install strawberry:
strawberry-softwarecenter
For Ubuntu 16.04, open terminal (Ctrl+Alt+T) and install snapd first via command:
sudo apt install snapd
install-snapd
Then install Strawberry music player via command:
sudo snap install strawberry
strawberry-snap
Uninstall:
To remove the audio player, either use Ubuntu Software or run command in terminal:
sudo snap remove strawberry
