Replacing Amavisd with Rspamd in ISPConfig 3.1 on Debian and Ubuntu
This tutorial describes the steps to replace amavis (amavisd-new) spam scanning software with Rspamd on an ISPConfig 3.1 server. The tutorial is written for Debian and Ubuntu Linux.
  • Root access.
  • ISPConfig 3.1 must be installed. The ISPConfig version will be 3.1.15 or newer after this procedure.
  • The server uses Debian 9 – 10 or Ubuntu 18.04 on an x86_64 processor (64Bit Linux). Older Debian and Ubuntu versions might work too, but I did not test them.
All commands below are run as root user. Login as root user or use ‘su –‘ on Debian or ‘sudo -s‘ on Ubuntu to become root user before you continue with this guide.
Note: This procedure will reconfigure all mailboxes and aliases to write the Rspamd config for each account (similar to an ISPConfig Tools > resync run), this may take quite some time and resources on large mail servers.
Install Redis
The Rspamd setup for ISPConfig requires Redis, so we will install it first.
apt-get install redis-server lsb-release
Install Unbound if BIND is not installed
If your server has no local DNS server installed, then a local DNS resolver like unbound should be installed.
First, check if BIND is installed by using this command:
which named
if the command returns the path to the named binary:
root@server1:/tmp# which named
/usr/sbin/named
then BIND is installed and you must skip this step. In case no path to named is returned, then install unbound:
apt-get install unbound
Install and Configure Rspamd
The first step to install Rspamd is to add the Rspamd Debian/Ubuntu package repository.
CODENAME=`lsb_release -c -s`
wget -O- https://rspamd.com/apt-stable/gpg.key | apt-key add -
echo "deb [arch=amd64] http://rspamd.com/apt-stable/ $CODENAME main" > /etc/apt/sources.list.d/rspamd.list
echo "deb-src [arch=amd64] http://rspamd.com/apt-stable/ $CODENAME main" >> /etc/apt/sources.list.d/rspamd.list
Update the Package list:
apt-get update
And Install Rspamd with apt:
apt-get install rspamd
Activate Redis in Rspamd configuration.
echo 'servers = "127.0.0.1";' > /etc/rspamd/local.d/redis.conf
Increase the Rspamd history, enable compression, and do not show the subject in the history. This step is optional.
echo "nrows = 2500;" > /etc/rspamd/local.d/history_redis.conf
echo "compress = true;" >> /etc/rspamd/local.d/history_redis.conf
echo "subject_privacy = true;" >> /etc/rspamd/local.d/history_redis.conf
Then restart Rspamd.
systemctl restart rspamd
Update ISPConfig
ISPConfig needs to be updated to enable the Rspamd configuration. When the ISPConfig updater asks you if it shall reconfigure services, choose ‘yes‘.
cd /tmp
wget http://www.ispconfig.org/downloads/ISPConfig-3-stable.tar.gz
tar xvfz ISPConfig-3-stable.tar.gz
cd ispconfig3_install/install
php -q update.php
You will see the line “Configuring Rspamd” in the output of the update script when Rspamd is detected and configured.
Enable Rspamd in ISPConfig
The final step requires that you log into ISPConfig as ‘admin’ user.
Log into ISPConfig
In ISPConfig navigate to System > Server Config > Mail.
There you change the value of the field Content Filter from Amavisd to Rspamd and press the save button at the bottom of the page. ISPConfig will start to reconfigure all mailboxes for Rspamd now.
When you go back to System > Server Config > Mail, then you can see some new fields where you can read and set the Rspamd password.
Rspamd password
Make Rspamd Dashboard accessible from outside
The Rspamd dashboard is on port 11334 on localhost, so it can not be accessed from outside. In this chapter, we will create a website in ISPConfig and add a proxy configuration. The configuration differs between Apache and Nginx web server, use the chapter which matches your installed web server software.
Apache
Enable the Proxy Module and restart apache.
a2enmod proxy
systemctl restart apache2
Then log into ISPconfig and create a website which will get used to access the Rspamd GUI. You are free to choose the domain name, I will use rspamd.example.com here. You don’t have to enable any programming language or other options in that site, just leave everything at the defaults. Enabling SSL and Let’s encrypt is highly recommended though.
Add website for Rspamd GUI
Go to the Options tab of the website and enter the following configuration into the Apache Directives field. For Apache 2.2, use:
<Location /rspamd>
Order allow,deny
Allow from all
</Location>
RewriteEngine On
RewriteRule ^/rspamd$ /rspamd/ [R,L] RewriteRule ^/rspamd/(.*) http://127.0.0.1:11334/$1 [P]
For Apache 2.4, use this instead:
<Location /rspamd>
Require all granted
</Location>
RewriteEngine On
Now you can access the Rspamd GUI with a web browser https://rspamd.example.com/rspamd. You will get asked for a password, use the password that you generated during Rspamd installation.
Nginx
Log into ISPconfig and create a website which will get used for accessing the Rspamd GUI. You are free to choose the domain name, I will use rspamd.example.com here. You don’t have to enable any programming language or other options in that site, just leave everything at the defaults. Enabling SSL and Let’s encrypt is highly recommended though.
Add website on Nginx web server
Go to the Options tab of the website and enter the following configuration into the Nginx Directives field.
root /usr/share/rspamd/www/;
try_files $uri @proxy;
location @proxy {
proxy_pass http://127.0.0.1:11334;
Now you can access the Rspamd GUI with a web browser https://rspamd.example.com/. You will get asked for a password, use the password that you have set for Rspamd in ISPConfig.
Rspamd GUI
Now you can access the Rspamd GUI with a browser and get detailed statistics about the spam filter rate and throughput.
ISPConfig has been reconfigured to use Rspamd instead of Amavis to scan for spam emails. Rspamd is also used for Dkim Signing.
Disable Amavis
Finally, we stop and disable amavisd service:
systemctl stop amavisd-new
systemctl disable amavisd-new
Rspamd is a modern high-performance spam scan software for Linux servers which delivers very accurate filter results. ISPConfig supports Rspamd as spam scan unit since version 3.1.15. This tutorial shows how to replace amavisd.new with Rspamd on an ISPConfig 3.1 server.
