Monitoring system resources using SAR on Ubuntu 20.04
SAR also know as a “System Activity Report” is a system resource monitoring tool for Linux operating systems. It is very useful for system administrators to collect the system performance report and improve system performance to handle more requests. With SAR, you can monitor CPU usage, Memory utilization, I/O devices consumption, battery performance, Plug and play devices, Disk usage, Processor performance, file system, and more.
In this tutorial, we will show you how to install and use SAR to monitor system performance.
Install SAR
By default, SAR package is available in the Ubuntu default repository. You can install it by just running the following command:
apt-get install sysstat -y
Once the installation is finished, start the SAR service and enable it to start at system reboot with the following command:
systemctl start sysstat
systemctl enable sysstat
Next, you can verify the installed version of SAR with the following command:
sar -V
You should get the SAR version in the following output:
sysstat version 12.2.0
(C) Sebastien Godard (sysstat orange.fr)
During the installation, SAR generates a Cron file for collecting and generating reports every 10 minutes. You can check it with the following command:
cat /etc/cron.d/sysstat
# The first element of the path is a directory where the debian-sa1
# script is located
PATH=/usr/lib/sysstat:/usr/sbin:/usr/sbin:/usr/bin:/sbin:/bin
# Activity reports every 10 minutes everyday
5-55/10 * * * * root command -v debian-sa1 > /dev/null && debian-sa1 1 1
# Additional run at 23:59 to rotate the statistics file
59 23 * * * root command -v debian-sa1 > /dev/null && debian-sa1 60 2
Monitor CPU Usage
You can run the following command to monitor CPU usage 4 times every 1 seconds.
sar 1 4
Linux 5.4.0-29-generic (ubuntu2004) 01/04/2021 _x86_64_ (2 CPU)
09:32:39 AM CPU %user %nice %system %iowait %steal %idle
09:32:40 AM all 0.00 0.00 0.00 0.00 0.00 100.00
09:32:41 AM all 0.00 0.00 0.00 0.00 0.00 100.00
09:32:42 AM all 0.00 0.00 0.00 0.00 0.00 100.00
09:32:43 AM all 0.00 0.00 0.00 0.00 0.00 100.00
Average: all 0.00 0.00 0.00 0.00 0.00 100.00
You can also save the generated output to a file using the -o option.
sar 1 4 -o cpu-report
You can see this report later using the -f option as shown below:
sar -f cpu-report
09:35:01 AM CPU %user %nice %system %iowait %steal %idle
09:35:02 AM all 0.50 0.00 1.00 0.00 0.00 98.50
09:35:03 AM all 0.00 0.00 0.50 0.00 0.00 99.50
09:35:04 AM all 0.00 0.00 0.00 0.00 0.00 100.00
09:35:05 AM all 0.50 0.00 0.50 0.00 0.00 99.00
Average: all 0.25 0.00 0.50 0.00 0.00 99.25
Monitor Memory Usage
You can use -r option to monitor the memory usage of your system.
To monitor Memory usage 4 times every 1 seconds, run the following command:
sar -r 1 4
09:37:29 AM kbmemfree kbavail kbmemused %memused kbbuffers kbcached kbcommit %commit kbactive kbinact kbdirty
09:37:30 AM 3609412 3733536 47556 1.18 24180 290460 102048 2.26 138240 206508 0
09:37:31 AM 3609412 3733536 47556 1.18 24180 290460 102048 2.26 138240 206508 0
09:37:32 AM 3609444 3733568 47524 1.18 24180 290460 102048 2.26 138240 206508 0
09:37:33 AM 3609444 3733568 47524 1.18 24180 290460 102048 2.26 138240 206508 0
Average: 3609428 3733552 47540 1.18 24180 290460 102048 2.26 138240 206508 0
Monitor Paging Statistics
You can use -B option to monitor the paging statistics of your system.
Run the following command to display paging statistics.
sar -B 1 4
09:39:03 AM pgpgin/s pgpgout/s fault/s majflt/s pgfree/s pgscank/s pgscand/s pgsteal/s %vmeff
09:39:04 AM 0.00 0.00 4.00 0.00 1.00 0.00 0.00 0.00 0.00
09:39:05 AM 0.00 0.00 1.00 0.00 8.00 0.00 0.00 0.00 0.00
09:39:06 AM 0.00 0.00 0.00 0.00 8.00 0.00 0.00 0.00 0.00
09:39:07 AM 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Average: 0.00 0.00 1.25 0.00 4.25 0.00 0.00 0.00 0.00
Monitor Block Device Statistics
You can use -d option with SAR command to display the block device statistics report. You can also use -p option to display output in more readable format:
sar -d -p 1 4
09:41:15 AM DEV tps rkB/s wkB/s dkB/s areq-sz aqu-sz await %util
09:41:16 AM sda 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
09:41:17 AM sda 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
09:41:18 AM sda 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
09:41:19 AM sda 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Average: sda 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Monitor Network Statistic
You can use -n option with SAR command to monitor network statistics in your system. You can use DEV, EDEV, NFS, NFSD, SOCK, IP, EIP, ICMP, EICMP, TCP, ETCP, UDP, SOCK6, IP6, EIP6, ICMP6, EICMP6 & UDP6 with -n option to monitor specific device. You can also use the option ALL to monitor all network devices.
To monitor all network devices, run the following command:
sar -n ALL 1 4
To monitor statistic of all network interface, run the following command:
sar -n DEV 1 4
09:51:18 AM IFACE rxpck/s txpck/s rxkB/s txkB/s rxcmp/s txcmp/s rxmcst/s %ifutil
09:51:19 AM lo 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
09:51:19 AM eth1 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
09:51:19 AM eth0 12.00 2.00 0.91 0.23 0.00 0.00 0.00 0.00
09:51:19 AM IFACE rxpck/s txpck/s rxkB/s txkB/s rxcmp/s txcmp/s rxmcst/s %ifutil
09:51:20 AM lo 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
09:51:20 AM eth1 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
09:51:20 AM eth0 16.00 12.00 1.13 2.22 0.00 0.00 0.00 0.00
09:51:20 AM IFACE rxpck/s txpck/s rxkB/s txkB/s rxcmp/s txcmp/s rxmcst/s %ifutil
09:51:21 AM lo 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
09:51:21 AM eth1 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
09:51:21 AM eth0 6.00 12.00 0.46 3.02 0.00 0.00 0.00 0.00
09:51:21 AM IFACE rxpck/s txpck/s rxkB/s txkB/s rxcmp/s txcmp/s rxmcst/s %ifutil
09:51:22 AM lo 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
09:51:22 AM eth1 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
09:51:22 AM eth0 9.00 22.00 0.66 3.49 0.00 0.00 0.00 0.00
Average: IFACE rxpck/s txpck/s rxkB/s txkB/s rxcmp/s txcmp/s rxmcst/s %ifutil
Average: lo 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Average: eth1 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Average: eth0 10.75 12.00 0.79 2.24 0.00 0.00 0.00 0.00
Monitor Swap Usage
You can use -S optio to monitor swap usage statistics.
sar -S 1 4
09:54:18 AM kbswpfree kbswpused %swpused kbswpcad %swpcad
09:54:19 AM 483800 0 0.00 0 0.00
09:54:20 AM 483800 0 0.00 0 0.00
09:54:21 AM 483800 0 0.00 0 0.00
09:54:22 AM 483800 0 0.00 0 0.00
Average: 483800 0 0.00 0 0.00
Monitor I/O Operations
To monitor details about I/O operations like transaction per second, read per second, write per second, run the following command:
sar -b 1 4
09:56:58 AM tps rtps wtps dtps bread/s bwrtn/s bdscd/s
09:56:59 AM 0.00 0.00 0.00 0.00 0.00 0.00 0.00
09:57:00 AM 0.00 0.00 0.00 0.00 0.00 0.00 0.00
09:57:01 AM 0.00 0.00 0.00 0.00 0.00 0.00 0.00
09:57:02 AM 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Average: 0.00 0.00 0.00 0.00 0.00 0.00 0.00
In the above post, you learned how to install and use SAR command line tool to monitor your system performance. I hope this will helps you to improve your system performance.
