MKVToolNix 14.0.0 Released with New Features and Bug Fixes
Mkvmerge GUI
Mkvmerge GUI
MKVToolNix 14.0.0, a new release of the free and open source Matroska libraries and tools, was release a day ago with new features, enhancements, and various bug-fixes.
New features and enhancements in MKVToolNix 14.0.0:
  • mkvmerge: AAC: implemented support for AAC with 960 samples per frame.
  • mkvmerge: identification: if the encoding/character set of a text subtitle track is known (e.g. because a byte order mark is present in the file), then it will be output during identification as the encoding property.
  • mkvmerge: WAV reader: added support for Wave64 files.
  • mkvmerge, mkvpropedit, MKVToolNix GUI (chapter editor): added support for chapters in WebM files that is spec-compliant by removing all tag elements not supported by the WebM spec.
  • mkvpropedit: added support for tags in WebM files that is spec-compliant by removing all tag elements not supported by the WebM spec.
  • MKVToolNix GUI: multiplexer: if the encoding/character set of a subtitle track cannot be changed, the GUI will deactivate the “subtitle character set” drop-down box and ignore changes to it when multiple tracks are selected. Additionally, if the track’s encoding is known and cannot be changed (e.g. due to a byte order mark in the file), that encoding will be selected in the drop-down box automatically. Both changes signal to the user that she doesn’t have to take care of the encoding herself.
  • MKVToolNix GUI: chapter editor: added a function to the “additional modifications” dialog for calculating and setting the end timestamps.
  • MKVToolNix GUI: changed the shortcuts for switching between the various tools from Alt+number (e.g. Alt+1 for the multiplexer tool) to Ctrl+Alt+number in order to avoid clashing with Windows’ input method for arbitrary characters (pressing and holding Alt and typing the codepoint on the number pad).
  • MKVToolNix GUI: added a “Window” menu and entries with shortcuts for selecting the next (Ctrl+F6) respectively previous tab (Ctrl+Shift+F6) in the current tool.
  • MKVToolNix GUI: on Windows the GUI will now determine the default font to use by querying Windows for the default UI/message box font instead of using the hardcoded Segoe UI.
The new release also adds a Romanian translation, and fixes various bugs. See the release note for details.
How to Install MKVToolNix 14.0.0 in Ubuntu:
For Ubuntu 16.04, Ubuntu 17.04, and their derivatives, you can install the 14.0.0 release via the official MKVToolNix repository by doing following steps.
1. Open terminal via Ctrl+Alt+T and run command to add the repository for Ubuntu 16.04, Linux Mint 18.x:
sudo sh -c 'echo "deb http://www.bunkus.org/ubuntu/xenial/ ./" >> /etc/apt/sources.list.d/mkvtoolnix.list'
Replace xenial in the code with zesty for Ubuntu 17.04. And input your password when it prompts and hit Enter.
mkvtoolnix-repo
2. If you have a previous release installed, upgrade the software via Software Updater utility:
upgrade mkvtoolnix
Or run commands to install or upgrade the software packages:
sudo apt update && sudo apt install mkvtoolnix-gui
Uninstall MKVToolNix:
To remove the software repository, launch Software & Updates utility and navigate to Other Software tab. To remove the software run command:
sudo apt remove --autoremove mkvtoolnix mkvtoolnix-gui
