Install TaskBoard with Apache and let’s Encrypt SSL on Debian 11
TaskBoard is a free and open-source Kanban application used to keep track of things that need to get done. It is a PHP-based and self-hosted application that helps you to keep track of all tasks. It provides a simple and user-friendly web interface for managing all your tasks. It is used by teams or organizations to represent work and its path towards completion.
Features
- Free and open-source
- Unlimited boards
- Simple and easy to install
- Easy customization
- RESTful API
- Basic User management
In this tutorial, I will show you how to install Taskboard on Debian 11.
- A server running Debian 11.
Before starting, it is a good idea to update your system packages to the updated version. You can update all of them by running the following command:
Install Apache, PHP, and Sqlite
First, you will need to install the Apache web server, PHP, SQLite, and other required dependencies to your server. You can install all of them by running the following command:
apt-get install apache2 sqlite3 php libapache2-mod-php php-cli php-common php-json php-readline php-sqlite3 libaio1 libapr1 libhtml-template-perl libaprutil1-dbd-sqlite3 libaprutil1-ldap libaprutil1 libdbi-perl libterm-readkey-perl curl libwrap0 unzip wget -y
Once all the packages are installed, start the Apache service and enable it to start at system reboot:
systemctl start apache2
systemctl enable apache2
Download Taskboard
First, download the latest version of Taskboard using the following command:
curl -s https://api.github.com/repos/kiswa/TaskBoard/releases/latest |grep browser_download_url | cut -d '"' -f 4 | wget -i -
Once the download is completed, extract the downloaded file to the Apache web root directory with the following command:
unzip TaskBoard_v*.zip -d /var/www/html/taskboard
Next, set proper ownership and permission on the Taskboard directory:
chown -R www-data:www-data /var/www/html/taskboard
chmod -R 775 /var/www/html/taskboard
Configure Apache for Taskboard
Next, you will need to create an Apache virtual host configuration file for Taskboard. You can create it by running the following command:
nano /etc/apache2/sites-available/taskboard.conf
ServerAdmin [email protected]
DocumentRoot "/var/www/html/taskboard"
ServerName taskboard.example.com
<Directory "/var/www/html/taskboard">
Options Indexes FollowSymLinks
Require all granted
ErrorLog "/var/log/apache2/taskboard-error_log"
CustomLog "/var/log/apache2/taskboard-access_log" combined
Save and close the file when you are finished then enable the Apache virtual host with the following command:
a2ensite taskboard.conf
Next, enable the Apache rewrite module and restart the Apache web service with the following command:
a2enmod rewrite
systemctl restart apache2
You can now check the status of the Apache service using the following command:
systemctl status apache2
Active: active (running) since Sat 2021-11-06 14:46:54 UTC; 5s ago
Process: 23704 ExecStart=/usr/sbin/apachectl start (code=exited, status=0/SUCCESS)
Main PID: 23709 (apache2)
Tasks: 6 (limit: 4679)
Memory: 15.3M
CPU: 110ms
??23709 /usr/sbin/apache2 -k start
??23710 /usr/sbin/apache2 -k start
??23711 /usr/sbin/apache2 -k start
??23712 /usr/sbin/apache2 -k start
??23713 /usr/sbin/apache2 -k start
??23714 /usr/sbin/apache2 -k start
Nov 06 14:46:54 debian11 systemd[1]: Starting The Apache HTTP Server...
Access Taskboard
At this point, Taskboard is installed and configured. Now, open your web browser and access the Taskboard using the URL http://taskboard.example.com. You will be redirected to the Taskboard login page:
Provide default admin username and password admin/admin and click on the Sign In button. You should see the Taskboard dashboard on the following page:
Now, click on the Settings button to change the Taskboard default admin password. You should see the following page:
Provide your new admin password and click on the Change Password button to apply the changes.
Secure Taskboard with Let’s Encrypt SSL
If you want to secure your Taskboard with Let’s Encrypt SSL, you will need to install the Certbot client package and manage the Let’s Encrypt SSL for your Taskboard.
You can install it by running the following command:
apt-get install python3-certbot-apache -y
Once the Certbot package is installed, run the following command to download and install the Let’s Encrypt SSL for your Taskboard website.
certbot --apache -d taskboard.example.com
You will be asked to provide your email and accept the term of service as shown below:
Plugins selected: Authenticator standalone, Installer None
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for taskboard.example.com
Enabled Apache rewrite module
Waiting for verification...
Cleaning up challenges
Created an SSL vhost at /etc/apache2/sites-available/taskboard-le-ssl.conf
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Deploying Certificate to VirtualHost /etc/apache2/sites-available/taskboard-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/taskboard-le-ssl.conf
Next, select whether or not to redirect HTTP traffic to HTTPS as shown below:
Type 2 and hit Enter to install the Let’s Encrypt SSL for your website:
Redirecting vhost in /etc/apache2/sites-enabled/taskboard.conf to ssl vhost in /etc/apache2/sites-available/taskboard-le-ssl.conf
Congratulations! You have successfully enabled https://taskboard.example.com
https://www.ssllabs.com/ssltest/analyze.html?d=taskboard.example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/taskboard.example.com/fullchain.pem
/etc/letsencrypt/live/taskboard.example.com/privkey.pem
Your cert will expire on 2022-02-7. To obtain a new or tweaked
Now, you can access your website securely using the URL https://taskboard.example.com.
Congratulations! you have successfully installed Taskboard with Apache and Let’s Encrypt SSL. You can now create your board, add users, assign tasks and manage all from the central dashboard. Feel free to ask me if you have any questions.
