Install and Configure Drupal 8 with Nginx and Let’s Encrypt on CentOS 8
Drupal is a free, open-source and scalable content management system that can be used by individuals to create and manage any types of websites. It is written in PHP and uses MySQL/MariaDB to store its data. Drupal provides a rich set of features that can be extended by thousands of add-ons. Drupal supports a lot of web servers including, Apache, Nginx, IIS, Lighttpd and databases MySQL, MariaDB, MongoDB, SQLite, PostgreSQL, and MS SQL server. Drupal comes with a simple and user-friendly web UI that allows you to create web sites without any coding knowledge.
In this tutorial, we will show you how to install Drupal 8 on CentOS 8 server and secure it with Let’s Encrypt free SSL.
  • A server running CentOS 8.
  • A valid domain name pointed with your server IP
Install Nginx, MariaDB and PHP
Before starting, you will need to install the LEMP server on your server. You can install it by running the following command:
dnf install nginx mariadb-server php php-fpm php-cli php-mbstring php-gd php-xml php-curl php-mysqlnd php-pdo php-json php-opcache -y
Once installed, start Nginx, MariaDB and php-fpm service and enable them to start after system reboot using the following command:
systemctl start nginx
systemctl start php-fpm
systemctl start mariadb
systemctl enable nginx
systemctl enable php-fpm
systemctl enable mariadb
Configure Database
By default, MariaDB is not secured so you will need to secure it. You can secure it by running the following command:
mysql_secure_installation
Set root password? [Y/n] Y
New password:
Re-enter new password:
Once you are done, log in to MariaDB shell with the following command:
mysql -u root -p
Provide your root password when prompt then create a database and user for Drupal with the following command:
MariaDB [(none)]> CREATE DATABASE drupaldb CHARACTER SET utf8mb4 COLLATE utf8mb4_general_ci;
MariaDB [(none)]> CREATE USER drupal@localhost IDENTIFIED BY "password";
Next, grant all the privileges to drupaldb with the following command:
MariaDB [(none)]> GRANT ALL ON drupaldb.* TO drupal@localhost IDENTIFIED BY "password";
MariaDB [(none)]> EXIT;
Download Drupal
First, you will need to download the latest version of the Drupal from their official website. You can download it with the following command:
wget https://ftp.drupal.org/files/projects/drupal-8.7.10.tar.gz
Once downloaded, extract the downloaded file with the following command:
tar -xvzf drupal-8.7.10.tar.gz
Next, move the extracted directory to the Nginx web root directory with the following command:
mv drupal-8.7.10 /var/www/html/drupal
Next, create a directory to store website files and rename the default.settings.php file as shown below:
mkdir /var/www/html/drupal/sites/default/files
cp /var/www/html/drupal/sites/default/default.settings.php /var/www/html/drupal/sites/default/settings.php
Next, change the ownership of the Drupal directory to nginx as shown below:
chown -R nginx:nginx /var/www/html/drupal/
Configure Nginx for Drupal
First, create a php-fpm configuration file for Drupal with the following command:
nano /etc/php-fpm.d/drupal.conf
[drupal] user = nginx
group = nginx
listen.owner = nginx
listen.group = nginx
listen = /run/php-fpm/drupal.sock
pm = ondemand
pm.max_children = 50
pm.process_idle_timeout = 10s
pm.max_requests = 500
chdir = /
Save and close the file when you are finished. Then, create an Nginx virtual host configuration file for Drupal:
nano /etc/nginx/conf.d/drupal.conf
server_name example.com;
root /var/www/html/drupal;
access_log /var/log/nginx/example.com.access.log;
error_log /var/log/nginx/example.com.error.log;
location = /favicon.ico {
log_not_found off;
access_log off;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location ~ ..*/.*.php$ {
return 403;
location ~ ^/sites/.*/private/ {
return 403;
# Block access to scripts in site files directory
location ~ ^/sites/[^/]+/files/.*.php$ {
deny all;
location ~ (^|/). {
return 403;
try_files $uri /index.php?$query_string;
location @rewrite {
rewrite ^/(.*)$ /index.php?q=$1;
location ~ /vendor/.*.php$ {
deny all;
return 404;
location ~ '.php$|^/update.php' {
fastcgi_split_path_info ^(.+?.php)(|/.*)$;
include fastcgi_params;
# Block httpoxy attacks. See https://httpoxy.org/.
fastcgi_param HTTP_PROXY "";
fastcgi_param QUERY_STRING $query_string;
fastcgi_intercept_errors on;
fastcgi_pass unix:/run/php-fpm/drupal.sock;
location ~ ^/sites/.*/files/styles/ { # For Drupal >= 7
try_files $uri @rewrite;
# Handle private files through Drupal. Private file's path can come
# with a language prefix.
location ~ ^(/[a-z-]+)?/system/files/ { # For Drupal >= 7
location ~* .(js|css|png|jpg|jpeg|gif|ico|svg)$ {
expires max;
log_not_found off;
Save and close the file. Then, restart php-fpm and Nginx service to apply the changes:
systemctl restart php-fpm
systemctl restart nginx
By default, SELinux is enabled in CentOS 8. So you will need to configure SELinux for Drupal to work correctly.
First, allows Drupal to write to the public and private files directories with the following command:
semanage fcontext -a -t httpd_sys_rw_content_t "/var/www/html/drupal(/.*)?"
semanage fcontext -a -t httpd_sys_rw_content_t '/var/www/html/drupal/sites/default/settings.php'
semanage fcontext -a -t httpd_sys_rw_content_t '/var/www/html/drupal/sites/default/files'
restorecon -Rv /var/www/html/drupal
restorecon -v /var/www/html/drupal/sites/default/settings.php
restorecon -Rv /var/www/html/drupal/sites/default/files
Next, allows Drupal to send outbound emails with the following command:
setsebool -P httpd_can_sendmail on
Next, you will need to create a firewall rule to allow HTTP and HTTPS service from external networks. You can allow it with the following command:
firewall-cmd --reload
Secure Drupal with Let’s Encrypt SSL
Drupal is now installed and configured. It’s time to secure it with Let’s Encrypt free SSL.
To do so, you will need to download the certbot client on your server. You can download and set correct permission by running the following command:
Now, run the following command to obtain and install an SSL certificate for your Drupal website.
certbot-auto --nginx -d example.com
The above command will first install all the required dependencies on your server. Once installed, you will be asked to provide an email address and accept the term of service as shown below:
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for example.com
Waiting for verification...
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/nginx/conf.d/drupal.conf
Next, you will need to choose whether or not to redirect HTTP traffic to HTTPS as shown below:
Type 2 and hit Enter to continue. Once the installation has been finished, you should see the following output:
Redirecting all traffic on port 80 to ssl in /etc/nginx/conf.d/drupal.conf
Congratulations! You have successfully enabled https://example.com
https://www.ssllabs.com/ssltest/analyze.html?d=example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/example.com/fullchain.pem
/etc/letsencrypt/live/example.com/privkey.pem
Your cert will expire on 2020-03-23. To obtain a new or tweaked
Access Drupal Website
Now, open your web browser and type the URL https://example.com. You will be redirected to the following page:
Choose language
Select your desired language and click on the Save and continue button. You should see the following page:
Select installation profile
Choose your installation profile and click on the Save and continue button. You should see the following page:
Database configuration
Provide your database details and click on the Save and continue button. You should see the following page:
Configure web site
Provide your site name, admin username, password and click on the Save and continue button. You should see your Drupal dashboard in the following page:
Welcome to your Drupal site
Congratulations! you have successfully installed and secured Drupal on CentOS 8 server.
