Laravel is a free and open-source PHP web framework created by Taylor Otwell. It is based on Symfony and follows the model–view–controller architectural pattern. And, It is designed for building high-end web applications using its significant and graceful syntaxes. It has many built-in features that make developing web apps easier and faster. Laravel gained more popularity after releasing version 3, which includes handy features, including the Artisan command line and support database, and introduced a packaging system called bundles.
This tutorial will show you how to install Laravel PHP Framework with Nginx web server on Ubuntu 22.04.
Install LEMP Server
Before starting, you will need to install the Nginx web server, MariaDB database system, PHP, and other required dependencies on your server. You can install all of them by running the following command:
apt install -y nginx mariadb-server php php-fpm php-common php-cli php-gd php-mysqlnd php-curl php-intl php-mbstring php-bcmath php-xml php-zip wget git
Once all the packages are installed, verify the PHP version using the following command:
php -v
PHP 8.1.2 (cli) (built: Apr 7 2022 17:46:26) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.1.2, Copyright (c) Zend Technologies
with Zend OPcache v8.1.2, Copyright (c), by Zend Technologies
Install PHP Composer
Composer is a dependency manager for PHP used for managing PHP dependency. To install the Composer, you will need to install the curl package to your server.
apt install -y curl
Next, install the PHP Composer using the following command:
curl -sS https://getcomposer.org/installer | php -- --install-dir=/usr/bin --filename=composer
Once Composer is installed, you will get the following output:
All settings correct for using Composer
Downloading...Composer (version 2.3.5) successfully installed to: /usr/bin/composer
Use it: php /usr/bin/composer
Next, verify the Composer version using the following command:
composer --version
Composer version 2.3.5 2022-04-13 16:43:00
Install Laravel on Ubuntu 22.04
First, navigate to the Nginx web root directory and download the latest version of Laravel using the Composer command:
cd /var/www/html
composer create-project laravel/laravel laravel
55 package suggestions were added by new dependencies, use `composer suggest` to see details.
Generating optimized autoload files
> IlluminateFoundationComposerScripts::postAutoloadDump
> @php artisan package:discover --ansi
Discovered Package: laravel/sail
Discovered Package: laravel/sanctum
Discovered Package: laravel/tinker
Discovered Package: nesbot/carbon
Discovered Package: nunomaduro/collision
Discovered Package: spatie/laravel-ignition
Package manifest generated successfully.
78 packages you are using are looking for funding.
Use the `composer fund` command to find out more!
> @php artisan vendor:publish --tag=laravel-assets --ansi --force
No publishable resources for tag [laravel-assets].
Publishing complete.
> @php artisan key:generate --ansi
Application key set successfully.
Next, change the directory to the Laravel and launch the Laravel using the following command:
cd laravel
php artisan serve --host 0.0.0.0 --port 8000
Starting Laravel development server: http://0.0.0.0:8000
[Sun May 22 08:17:45 2022] PHP 8.1.2 Development Server (http://0.0.0.0:8000) started
Press CTRL+C to stop the Laravel. Next, change the ownership and permission of the Laravel:
chown -R www-data:www-data /var/www/html/laravel
chmod -R 0777 /var/www/html/laravel
Configure Nginx for Laravel
Next, create an Nginx virtual host configuration file for Laravel using the following command:
nano /etc/nginx/conf.d/laravel.conf
server_name laravel.example.com;
root /var/www/html/laravel/public;
add_header X-Frame-Options "SAMEORIGIN";
add_header X-XSS-Protection "1; mode=block";
add_header X-Content-Type-Options "nosniff";
index index.html index.htm index.php;
charset utf-8;
location = /favicon.ico { access_log off; log_not_found off; }
location = /robots.txt { access_log off; log_not_found off; }
error_page 404 /index.php;
location ~ .php$ {
fastcgi_pass unix:/var/run/php/php8.1-fpm.sock;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $realpath_root$fastcgi_script_name;
include fastcgi_params;
location ~ /.(?!well-known).* {
deny all;
Save and close the file when you are finished then verify the Nginx for any syntax error using the following command:
nginx -t
Next, restart the Nginx and PHP-FPM service to apply the changes:
systemctl restart php8.1-fpm nginx
You can also check the status of the Nginx using the following command:
systemctl status nginx
Active: active (running) since Sun 2022-05-22 08:19:20 UTC; 17s ago
Docs: man:nginx(8)
Process: 16865 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 16866 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Main PID: 16867 (nginx)
Tasks: 2 (limit: 2292)
Memory: 2.6M
CPU: 33ms
??16867 "nginx: master process /usr/sbin/nginx -g daemon on; master_process on;"
??16868 "nginx: worker process" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ""
May 22 08:19:20 ubuntu2204 systemd[1]: Starting A high performance web server and a reverse proxy server...
May 22 08:19:20 ubuntu2204 systemd[1]: Started A high performance web server and a reverse proxy server.
Access Laravel Web Interface
At this point, Laravel is installed and configured with Nginx. You can now access the Laravel Web UI using the URL http://laravel.example.com. You should see the Laravel Dashboard on the following page:
Secure Laravel with Let’s Encrypt
Next, you will need to install the Certbot client package to install and manage the Let’s Encrypt SSL.
First, install the Certbot with the following command:
apt-get install certbot python3-certbot-nginx -y
Once the installation is finished, run the following command to install the Let’s Encrypt SSL on your website:
certbot --nginx -d laravel.example.com
You will be asked to provide a valid email address and accept the term of service as shown below:- We were unable to subscribe you the EFF mailing list because your
e-mail address appears to be invalid. You can try again later by
visiting https://act.eff.org.
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for laravel.example.com
Waiting for verification...
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/nginx/conf.d/laravel.conf
Next, choose whether or not to redirect HTTP traffic to HTTPS as shown below:- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
Type 2 and hit Enter to finish the installation. You should see the following output:Redirecting all traffic on port 80 to ssl in /etc/nginx/conf.d/laravel.conf
Congratulations! You have successfully enabled https://laravel.example.com
https://www.ssllabs.com/ssltest/analyze.html?d=laravel.example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/laravel.example.com/fullchain.pem
/etc/letsencrypt/live/laravel.example.com/privkey.pem
Your cert will expire on 2022-08-22. To obtain a new or tweaked
Congratulations! You have successfully installed Laravel with Nginx on Ubuntu 22.04. You can now start developing high-performance PHP applications using the Laravel framework. Feel free to ask me if you have any questions.
