Akeneo is a free, open source and enterprise Product Information Management platform based on the Symfony2 framework. It is simple, easy to use and highly customizable that allows us to collaborate and automate engaging experiences with customers and partners acrose multiple devices. Akeneo PIM comes with a simple yet extensible import engine that greatly simplifies data onboarding from virtually any source. You can easily edit your data. Define the attributes you need, complete product sheets, translate your information into as many languages as you want, add your media files, and keep track of any modifications directly in the product history.
In this tutorial, we will learn how to install Akeneo product management system (PIM) on Ubuntu 18.04 LTS (Bionic Beaver).
Install LAMP Server
Before starting, you will need to install Apache, PHP, and MariaDB to your system.
First, install Apache and MariaDB using the following command:
sudo apt-get install apache2 mariadb-server -y
Once Apache and MariaDB are installed, start Apache and MariaDB service and enable them to start on boot using the following command:
sudo systemctl start apache2
sudo systemctl enable apache2
sudo systemctl start mysql
sudo systemctl enable mysql
By default, the latest version of PHP not available in Ubuntu 18.04. So you will need to add PHP repository to your system. You can install Ondrej PHP repository using the following command:
sudo apt-get install software-properties-common -y
sudo add-apt-repository ppa:ondrej/php
Once the repository is installed, update the repository and install PHP7.1 using the following command:
sudo apt-get update -y
sudo apt-get install php7.1 libapache2-mod-php7.1 php7.1-apcu php7.1-bcmath php7.1-common php7.1-mbstring php7.1-xmlrpc php7.1-soap php7.1-gd php7.1-xml php7.1-intl php7.1-mysql php7.1-cli php7.1-mcrypt php7.1-ldap php7.1-zip php7.1-curl -y
Once PHP is installed, you will need to modify php.ini file. You can do this with the following command:
sudo nano /etc/php/7.1/apache2/php.ini
Make the following changes:
file_uploads = On
allow_url_fopen = On
short_open_tag = On
memory_limit = 256M
upload_max_filesize = 120M
max_execution_time = 300
max_input_vars = 1500
date.timezone = Asia/Kolkata
Save and close the file, when you are finished.
Configure MariaDB
By default, MariaDB installation is not secured. So you will need to secure it first. You can secure it by running the following command:
Answer all the questions as shwon below:
Set root password? [Y/n]: N
Once the MariaDB is secured, log in to MariaDB shell with the following command:
mysql -u root -p
Enter your root password when prompt, then create a database and user for Akeneo:
MariaDB [(none)]> CREATE DATABASE akeneodb;
MariaDB [(none)]> CREATE USER 'akeneouser'@'localhost' IDENTIFIED BY 'password';
Next, grant all privileges to Akeneo using the following command:
MariaDB [(none)]> GRANT ALL ON akeneodb.* TO 'akeneouser'@'localhost' IDENTIFIED BY 'password' WITH GRANT OPTION;
Next, flush the privileges using the following command:
Finally, exit from the MariaDB shell with the following command:
MariaDB [(none)]> exit
Install Akeneo
First, you will need to download the latest version of Akeneo from their official website. You can download it with the following command:
wget wget http://download.akeneo.com/pim-community-standard-v2.2-latest-icecat.tar.gz
Next, create a directory in Apache web root and extract the downloaded file inside it:
sudo mkdir /var/www/html/akeneo
sudo tar -xvzf pim-community-standard-v2.2-latest-icecat.tar.gz -C /var/www/html/akeneo
Next, change the directory to the akeneo and install Akeneo using the following command:
cd /var/www/html/akeneo/pim-community-standard
sudo php -d memory_limit=3G ../composer.phar install --optimize-autoloader --prefer-dist
Output:Trying to install assets as relative symbolic links.
Bundle Method / Error
? FOSJsRoutingBundle relative symlink
? OroAsseticBundle relative symlink
? OroConfigBundle relative symlink
? PimNavigationBundle relative symlink
? PimUserBundle relative symlink
? PimAnalyticsBundle relative symlink
? PimDashboardBundle relative symlink
? PimDataGridBundle relative symlink
? PimEnrichBundle relative symlink
? PimImportExportBundle relative symlink
? PimNotificationBundle relative symlink
? PimReferenceDataBundle relative symlink
? PimUIBundle relative symlink
[OK] All assets were successfully installed.
> SensioBundleDistributionBundleComposerScriptHandler::installRequirementsFile
> SensioBundleDistributionBundleComposerScriptHandler::removeSymfonyStandardFiles
> SensioBundleDistributionBundleComposerScriptHandler::prepareDeploymentTarget
> @php bin/console fos:js-routing:dump --target=web/js/routes.js
Dumping exposed routes.
[file+] web/js/routes.js
sudo php bin/console cache:clear --n-warmup --env=prod
Next, clear the cache using the following command:
sudo php bin/console cache:clear --no-warmup --env=prod
Output:
// Clearing the cache for the prod environment with debug false
[OK] Cache for the “prod” environment (debug=false) was successfully cleared.
sudo php bin/console pim:installer:assets --symlink --clean --env=prod
Next, give proper permissions to the akeneo directory:
sudo chown -R www-data:www-data /var/www/html/akeneo/
sudo chmod -R 755 /var/www/html/akeneo/
Configure Apache for Akeneo
Next, you will need to create an apache virtual host file for akeneo. You can do this with the following command:
sudo nano /etc/apache2/sites-available/akeneo.conf
ServerAdmin [email protected]
DocumentRoot /var/www/html/akeneo/pim-community-standard/web
ServerName example.com
<Directory /var/www/html/akeneo/pim-community-standard/web>
Options FollowSymlinks
Require all granted
ErrorLog ${APACHE_LOG_DIR}/akeneo_error.log
CustomLog ${APACHE_LOG_DIR}/akeneo_access.log combined
Save and close the file, when you are finished. Then, enable Akeneo virtual host file and Apache rewrite module using the following command:
sudo a2ensite akeneo.conf
sudo a2enmod rewrite
Finally, restart Apache service to apply all the changes:
That’s it!. Now open your web browser and type the URL http://example.com and complete the required step to install Akeneo.
