How to Use Linux Cat Command (With Examples)
If you have worked in Linux, you surely have seen a code snippet that uses the cat command. Cat is short for concatenate. This command displays the contents of one or more files without having to open the file for editing.
In this article, learn how to use the cat command in Linux.
cat command in Linux with examples
  • A system running Linux
  • Access to a terminal window / command line
cat Command Syntax
To use the cat command, follow the format:
cat [options] filename(s)
[options] – This lets you issue additional instructions to the cat command. For example, to display the contents of a file with each line numbered, use the –n option:
cat –n filename
filename(s) – Specify the name of the file (or files) that you want to display. If you use more than one filename, each file will be displayed.
Linux Cat Command Examples
This article includes 15 cat commands and examples of how to use them. To try out the commands, create a couple of sample files, and test the cat commands listed below.
1. Create a New File
You can create new files and add content to them using the cat command.
Create test1.txt and test2.txt, which you can use as sample files to test out the other commands.
1. Open a terminal window and create the first file:
cat >test1.txt
2. The cursor moves to a new line where you can add the wanted text. Type a simple sentence such as:
This is test file #1.
3. To exit the prompt and write the changes to the file, hold the Ctrl key and press d.
Create a new file using the cat command.
4. Repeat the process to create test2.txt. Run:
cat >test2.txt
5. Type:
This is test file #2.
6. Press Ctrl+d.
Creating a sample file with the cat command.
2. Display Contents of a Single File
To display the contents of test1.txt using the cat command run:
cat test1.txt
The output displays the content as in the image below.
Display the content of a file using the cat command.
3. Display Contents of Multiple Files
To display the contents of both files, run the command:
cat test1.txt test2.txt
Use the cat command to show content of multiple files.
4. Redirect Contents of a Single File
Instead of displaying the contents of a file on the screen, cat can put them in a file.
cat test1.txt > test3.txt
If the destination filename doesn’t exist, it will be created. If you run cat on test3.txt, you should see the contents from test1.txt:
cat test3.txt
The output displays:
Redirect file contents using the cat command.
If a file is exported that already exists, this will overwrite the contents of the file:
cat test2.txt > test3.txt
cat test3.txt
The test3.txt file now has the following content:
Overwrite the content of an existing file using the cat command.
5. Redirect Contents of Multiple Files
You can redirect the contents of multiple file into one single file:
cat test1.txt test2.txt > test3.txt
Display the content of test3.txt with:
cat test3.txt
The output shows the contents of both files, as in the image below.
Redirect content of multiple files using the cat command.
6. Display the Contents in Reverse Order
The cat command can display the content of a file in reverse order (by lines). To do this, use tac (cat in reverse):
tac test3.txt
Display contents of file in reverse order.
7. Append File Contents to Another File
The cat command can add the contents of a file to the end of another file. Instead of using a single > sign, use a double >> sign:
cat test1.txt >> test3.txt
Open the test3 file by running:
cat test3.txt
The content of test3 followed by test1 should display.
Append file content content to another file.
Note: If you want to remove the sample files, take a look at how to remove files and directories using the Linux command line.
8. Append Text to Existing File
You can use a similar command to append text to an existing file:
cat >> test1.txt
Add a new line to the file:
This is the second line in test file #1.
Hold Ctrl and hit d.
Check the content of the test1.txt file:
cat test1.txt
Append text to existing file using the cat command.
9. Combine Operations
The functions of the cat command can be combined. For example, to combine the output of two files, and store the result in a new file:
cat test1.txt test2.txt > test4.txt
cat test4.txt
Combining cat operations into one command
Alternately, you can append multiple files to the end of an existing file:
cat test2.txt test1.txt >> test4.txt
cat test4.txt
Append multiple files to an existing file using the cat command.
Note that the order specified is the order the files in which they are added to the destination file.
Note: Once you have created multiple files, you may want to group them in a single directory. Take a look at how to use mkdir command to make or create a Linux directory.
10. More and Less Options (Manage Large Files)
If you use cat on a very large file, you’ll end up with a huge string of data that’s hard to read. You can break it into pages using | more:
cat test4.txt | more
This displays a single page of the file. When you press a key, it will scroll to the next page.
If you’d like the ability to scroll forward and backward through the display, use | less.
cat test4.txt | less
Note: Learn how to use the Linux split command to easily manage text files with many lines.
11. Show Line Numbering
You may find it useful to have line numbers in the output, especially for large files. To enable line numbering, add the -n option to the cat command:
cat –n test1.txt
The output should appear as in the image below:
Show line numbering with cat command.
12. Show the End of Line
You can instruct cat to highlight the end of each line and spaces between lines with $.
To do so, use the command:
cat -e test1.txt
Since the sample file test1.txt has only one line, the output shows one $ at the end of it.
Show highlight at the end of line with the cat command.
13. Show TAB Separated Lines
The cat command has the option of displaying the file content along with the tab space within the text.
To show tab separated lines for a sample run:
cat -t test4.txt
The tab space within the text is represented by ^I.
14. Remove Blank Lines
To omit blank lines from the output of cat with the –s option:
cat -t test4.txt
15. List All CAT Commands
If you have trouble remembering the options, use the --help command:
cat ––help
List all cat commands.
Note: Learn how to concatenate strings in Bash.
You should now have a good understanding of how to use the cat command in Linux.
Want to master more Linux commands? Check out our list of Linux Commands All Users Should Know.
