How to use Cloudformation to create a VPC on AWS
Using Cloudformation, we can create and manage AWS resources very easily. Cloudformation can be used to manage all AWS resources using a text file. Cloudformation allows us to create and model our infrastructure and applications without having to perform actions manually. Cloudformation helps us to manage our complete infrastructure in a text file, or template. Cloudformation template is a formatted text file in JSON or YAML language that describes our AWS infrastructure.
In this article, we will see a Cloudformation to create a VPC with 2 Public and 2 Private Subnets.
- Basic understanding of Cloudformation Templates.
What we will do?
- Login to AWS.
- Create a template.
- Create a Cloudformation Stack
Login to AWS
- Click here to go to AWS Login Page.
Create a template
Before we proceed with creating a stack, we should have a template that will be used to create a VPC. Copy the following code and save in on a local machine.
AWSTemplateFormatVersion: 2010-09-09
Description: >
This Templates creates a VPC with 3 public and 3 private subnets.
Parameters:
VpcCIDR:
Type: String
Description: VPC CIDR (Do Not Change if no customization is required).
Default: 10.10.0.0/16
PrivateAZ1SubnetCIDR:
Type: String
Description: Subnet CIDR for 1st Availability Zone (Do Not Change if no customization is required).
Default: 10.10.80.0/21
PrivateAZ2SubnetCIDR:
Type: String
Description: Subnet CIDR for 2nd Availability Zone (Do Not Change if no customization is required).
Default: 10.10.88.0/21
PrivateAZ3SubnetCIDR:
Type: String
Description: Subnet CIDR for 3rd Availability Zone (Do Not Change if no customization is required).
Default: 10.10.96.0/21
PublicAZ1SubnetCIDR:
Type: String
Default: 10.10.0.0/21
PublicAZ2SubnetCIDR:
Type: String
Default: 10.10.8.0/21
PublicAZ3SubnetCIDR:
Type: String
Default: 10.10.16.0/21
Metadata:
AWS::CloudFormation::Interface:
ParameterGroups:
- Label:
default: VPC
Parameters:
- VpcCIDR
- Label:
default: Availabilty Zone 1
Parameters:
- PublicAZ1SubnetCIDR
- PrivateAZ1SubnetCIDR
- Label:
Parameters:
- PublicAZ2SubnetCIDR
- PrivateAZ2SubnetCIDR
- Label:
Parameters:
- PublicAZ3SubnetCIDR
- PrivateAZ3SubnetCIDR
Resources:
Vpc:
Type: AWS::EC2::VPC
Properties:
CidrBlock: !Ref VpcCIDR
Tags:
- Key: Name
Value: !Sub ${AWS::StackName}
InternetGateway:
Type: AWS::EC2::InternetGateway
Properties:
Tags:
- Key: Name
VPCGatewayAttachment:
Type: AWS::EC2::VPCGatewayAttachment
Properties:
InternetGatewayId: !Ref InternetGateway
VpcId: !Ref Vpc
# Public Subnets - Route Table
PublicRouteTable:
Type: AWS::EC2::RouteTable
Properties:
VpcId: !Ref Vpc
Tags:
- Key: Name
Value: !Sub ${AWS::StackName}-public
- Key: Type
Value: public
PublicSubnetsRoute:
Properties:
RouteTableId: !Ref PublicRouteTable
DestinationCidrBlock: 0.0.0.0/0
DependsOn: VPCGatewayAttachment
# Public Subnets
PublicAZ1Subnet:
Type: AWS::EC2::Subnet
Properties:
VpcId: !Ref Vpc
CidrBlock: !Ref PublicAZ1SubnetCIDR
AvailabilityZone: !Select [0, !GetAZs ""] MapPublicIpOnLaunch: true
Tags:
- Key: Name
Value: !Sub
- ${AWS::StackName}-public-${AZ}
- { AZ: !Select [0, !GetAZs ""] }
- Key: Type
Value: public
PublicAZ1SubnetRouteTableAssociation:
Type: AWS::EC2::SubnetRouteTableAssociation
Properties:
SubnetId: !Ref PublicAZ1Subnet
PublicAZ2Subnet:
Properties:
VpcId: !Ref Vpc
CidrBlock: !Ref PublicAZ2SubnetCIDR
AvailabilityZone: !Select [1, !GetAZs ""] MapPublicIpOnLaunch: true
Tags:
- Key: Name
Value: !Sub
- { AZ: !Select [1, !GetAZs ""] }
- Key: Type
Value: public
PublicAZ2SubnetRouteTableAssociation:
Properties:
SubnetId: !Ref PublicAZ2Subnet
PublicAZ3Subnet:
Properties:
VpcId: !Ref Vpc
CidrBlock: !Ref PublicAZ3SubnetCIDR
AvailabilityZone: !Select [2, !GetAZs ""] MapPublicIpOnLaunch: true
Tags:
- Key: Name
Value: !Sub
- { AZ: !Select [2, !GetAZs ""] }
- Key: Type
Value: public
PublicAZ3SubnetRouteTableAssociation:
Properties:
SubnetId: !Ref PublicAZ3Subnet
# Private Subnets - NAT Gateways
AZ1NatGatewayEIP:
Type: AWS::EC2::EIP
Properties:
Domain: vpc
AZ1NatGateway:
Type: AWS::EC2::NatGateway
Properties:
AllocationId: !GetAtt AZ1NatGatewayEIP.AllocationId
AZ2NatGatewayEIP:
Type: AWS::EC2::EIP
Properties:
Domain: vpc
AZ2NatGateway:
Properties:
AllocationId: !GetAtt AZ2NatGatewayEIP.AllocationId
AZ3NatGatewayEIP:
Type: AWS::EC2::EIP
Properties:
Domain: vpc
AZ3NatGateway:
Properties:
AllocationId: !GetAtt AZ3NatGatewayEIP.AllocationId
# Private Subnets
PrivateAZ1Subnet:
Properties:
VpcId: !Ref Vpc
CidrBlock: !Ref PrivateAZ1SubnetCIDR
AvailabilityZone: !Select [0, !GetAZs ""] Tags:
- Key: Name
Value: !Sub
- ${AWS::StackName}-private-${AZ}
- Key: Type
Value: private
PrivateAZ1RouteTable:
Properties:
VpcId: !Ref Vpc
Tags:
- Key: Name
Value: !Sub
- Key: Type
Value: private
PrivateAZ1Route:
Properties:
RouteTableId: !Ref PrivateAZ1RouteTable
NatGatewayId: !Ref AZ1NatGateway
PrivateAZ1RouteTableAssociation:
Properties:
SubnetId: !Ref PrivateAZ1Subnet
PrivateAZ2Subnet:
Properties:
VpcId: !Ref Vpc
CidrBlock: !Ref PrivateAZ2SubnetCIDR
AvailabilityZone: !Select [1, !GetAZs ""] Tags:
- Key: Name
Value: !Sub
- Key: Type
Value: private
PrivateAZ2RouteTable:
Properties:
VpcId: !Ref Vpc
Tags:
- Key: Name
Value: !Sub
- Key: Type
Value: private
PrivateAZ2Route:
Properties:
RouteTableId: !Ref PrivateAZ2RouteTable
NatGatewayId: !Ref AZ2NatGateway
PrivateAZ2RouteTableAssociation:
Properties:
SubnetId: !Ref PrivateAZ2Subnet
PrivateAZ3Subnet:
Properties:
VpcId: !Ref Vpc
CidrBlock: !Ref PrivateAZ3SubnetCIDR
AvailabilityZone: !Select [2, !GetAZs ""] Tags:
- Key: Name
Value: !Sub
- Key: Type
Value: private
PrivateAZ3RouteTable:
Properties:
VpcId: !Ref Vpc
Tags:
- Key: Name
Value: !Sub
- Key: Type
Value: private
PrivateAZ3Route:
Properties:
RouteTableId: !Ref PrivateAZ3RouteTable
NatGatewayId: !Ref AZ3NatGateway
PrivateAZ3RouteTableAssociation:
Properties:
SubnetId: !Ref PrivateAZ3Subnet
Outputs:
VpcId:
Description: VPC Id
Value: !Ref Vpc
Export:
Name: !Sub "${AWS::StackName}-VPC-ID"
To create a Cloudformation Stack, click on “Services” in the top left and search for “Cloudformation”.
On the main dashboard, click on “Create stack” -> “With new resorces(standard)”.
The stack needs a template file which can be a local file or an object file in the S3 Bucket. Since we will be having a local template, click on “Template is ready” -> “Upload a template file”, click on “Choose file” and select the local template file and proceed further.
Give a name to the stack, keep all other parameters unchanged.
Give Tags if required.
Scroll down the page and click on “Create stack”
This will take some time, wait till then.
You can see the status or event taking place under “Events” tab.
Now, you can go to VPC and check for the VPC that got created. To go to VPC, click on “Services” at the top and left search for VPC.
In the main dashboard, you can see the number of VPC, Subnets, Route Tables, Internet Gateway, Nat Gateway which got created.
You can delete the VPC by just deleting the Stack if you no more need it.
In this article, we saw the steps to create a Cloudformation Stack to create a VPC with 2 Public and 2 Private Subnet.
