How to Setup OpenNMS Network Monitoring Solution on Ubuntu 20.04 LTS
OpenNMS is a free, open-source, and enterprise-grade network management system used for monitoring unlimited devices from the central location. It works by discovering all devices in the network and monitor services automatically. It is based on Java and designed to monitor critical services on remote machines by using SNMP and JMX. It can be installed on all major operating systems including, Windows, Linux/Unix, Mac and Solaris. It offers a rich set of features including, Provisioning, Service Monitoring, Event Management, Charting support and Performance Measurement.
Currently, OpenNMS is available in two editions Horizon and Meridian. Horizon is designed for monitoring and managing IT environments while the Meridian is designed for companies who are looking for stability and long-term support.
In this tutorial, we will explain how to install OpenNMS with Docker on Ubuntu 20.04.
  • A root password is set up on your server.
Before starting, it is always a good idea to update your system packages to the latest version. You can update them with the following command:
apt-get upgrade -y
After updating all packages, install other required dependencies using the following command:
apt-get install apt-transport-https ca-certificates curl gnupg-agent software-properties-common -y
Once all the dependencies are installed, you can proceed to the next step.
Install Docker and Docker Compose
By default, the latest version of Docker is not available in the Ubuntu 20.04 default repository. So it is recommended to install the Docker from Docker’s official repository.
First, download and add the GPT key with the following command:
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | apt-key add -
Next, add the Docker repository to your system using the following command:
add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable"
Once the repository is added, install the Docker and Docker compose by running the following command:
apt-get install docker-ce docker-ce-cli containerd.io docker-compose -y
Once both are installed, verify the status of the Docker using the following command:
systemctl status docker
Active: active (running) since Sat 2020-07-04 04:43:52 UTC; 19s ago
TriggeredBy: ? docker.socket
Docs: https://docs.docker.com
Main PID: 38468 (dockerd)
Tasks: 10
Memory: 36.3M
??38468 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
To check the Docker version, run the following command:
docker -v
Docker version 19.03.12, build 48a66213fe
To check the Docker compose version, run the following command:
docker-compose -v
docker-compose version 1.25.0, build unknown
Install OpenNMS
Next, create a project directory for OpenNMS with the following command:
mkdir opennms
Next, change the directory to opennms and create a new docker-compose.yml file to install OpenNMS.
cd opennms
nano docker-compose.yml
version: '3'
volumes:
data-postgres: {}
data-opennms: {}
services:
database:
image: postgres:12
container_name: database
environment:
- TZ=Europe/Berlin
- POSTGRES_USER=postgres
- POSTGRES_PASSWORD=postgres
volumes:
- data-postgres:/var/lib/postgresql/data
healthcheck:
test: [ "CMD-SHELL", "pg_isready -U postgres" ] interval: 10s
timeout: 30s
retries: 3
horizon:
image: opennms/horizon:26.1.1
container_name: horizon
environment:
- TZ=Europe/Berlin
- POSTGRES_HOST=database
- POSTGRES_PORT=5432
- OPENNMS_DBNAME=opennms
- OPENNMS_DBUSER=opennms
- OPENNMS_DBPASS=opennms
volumes:
- data-opennms:/opt/opennms/share/rrd
- ./overlay:/opt/opennms-overlay
command: ["-s"] ports:
- "8980:8980/tcp"
- "8101:8101/tcp"
- "61616:61616/tcp"
healthcheck:
test: [ "CMD", "curl", "-f", "-I", "http://localhost:8980/opennms/login.jsp" ] interval: 1m
timeout: 5s
retries: 3
Save and close the file when you are finished. Then, download and build the container for OpenNMS with the following command:
docker-compose up -d
Once the OpenNMS container is downloaded, you can verify the running container with the following command:
docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
1537b3a43c92 postgres:12 "docker-entrypoint.s…" 9 seconds ago Up 6 seconds (health: starting) 5432/tcp database
7e00f3877d13 opennms/horizon:26.1.1 "/entrypoint.sh -s" 9 seconds ago Up 6 seconds (health: starting) 0.0.0.0:8101->8101/tcp, 1162/udp, 0.0.0.0:8980->8980/tcp, 10514/udp, 0.0.0.0:61616->61616/tcp horizon
Access OpenNMS Web Interface
At this point, OpenNMS is running and listening on port 8980. You can access it using the URL http://your-server-ip:8980. You will be redirected to the OpenNMS login page as shown below:
Provide the default username and password as admin/admin and click on the Login button. You should see the OpenNMS dashboard in the following screen:
OpenNMS Dashboard
Now, click on the + icon on the right pane to add new server node for monitoring. You should see the following screen:
Add Node to OpenNMS
Provide a name and click on the OK button. You should see the following screen:
Node attributes
Node Authentication settings
Now, provide the IP address of the server that you want to monitor, community string, username and password of the server, Access method and click on the Provision button. Once the provision is success, you should see the following screen:
Successfully provisioned a node
Click on the OK button to continue, then go to Info => Nodes, you should see the client1 node status, notification, and events in the following screen:
OpenNMS Server Monitoring
Congratulations! you have successfully installed OpenNMS on Ubuntu 20.04 server. You can now add more devices to OpenNMS and start monitoring through the web browser. Feel free to ask me if you have any questions.
