How to run Python Scripts with Apache and mod_wsgi on Ubuntu 22.04
The Apache module mod_wsgi provides an interface for hosting Python-based web applications. It is a good choice for professional hosting systems as it provides a high-performance solution, but works equally well for small sites. Deployment of applications written with Python frameworks like Django, Web.py, Werkzug, Chery.py, TurboGears, and Flask is easy with mod_wsgi.
In this tutorial, I will show you how to install and configure mod_wsgi using the Apache web server on Ubuntu 22.04 LTS. This guide is an updated version of the Apache WSGI guide for Ubuntu 20.04 from Hitesh Jethva.
  • Ubuntu 22.04 Server or Desktop
  • You must be the system administrator and either have root or sudo permission to install and configure this software.
Before starting, it is a good idea to update your system with the latest version. You can update your system with the following command:
sudo apt update -y
sudo apt upgrade -y
After updating the system, restart it to implement the changes.
Install Python programming language
By default, Python comes pre-installed on Ubuntu 22.04. in case Python is not installed yet, then you can install it with this command:
sudo apt install python3 libexpat1 -y
The screenshot below shows the output of the command when python is already installed.
Install python
Now proceed with the next step.
Install Apache web server and the mod_wsgi module
In this step, we will install the Apache web server and the mod_wsgi Python module. Execute the following command to install both applications. The dependent software packages will get installed automatically.
sudo apt install apache2 apache2-utils ssl-cert libapache2-mod-wsgi-py3 -y
Install Apache WSGI Module
WSGI module configuration in Apache
Next, you need to create a new Python script inside Apache default web root directory to serve it via WSGI Apache module. We will use a small ‘Hello World’ script here for demonstration purposes.
You can create the python script with the following command:
sudo nano /var/www/html/wsgitest.py
def application(environ, start_response):
    status = '200 OK'
    output = b'Hello Howtoforge!n'
    response_headers = [('Content-type', 'text/plain'),
                        ('Content-Length', str(len(output)))]    start_response(status, response_headers)
    return [output]
Save and close the file. Then, change the ownership of the file to www-data with the following command:
sudo chown www-data:www-data /var/www/html/wsgitest.py
sudo chmod 775 /var/www/html/wsgitest.py
Next, edit the Apache virtual host configuration file to serve this file over HTTP protocol.
sudo nano /etc/apache2/sites-enabled/000-default.conf
Add the following line:
WSGIScriptAlias /wsgi /var/www/html/wsgitest.py
right before the line
The complete virtual host file looks like this:
# The ServerName directive sets the request scheme, hostname and port that
# the server uses to identify itself. This is used when creating
# redirection URLs. In the context of virtual hosts, the ServerName
# specifies what hostname must appear in the request's Host: header to
# match this virtual host. For the default virtual host (this file) this
# value is not decisive as it is used as a last resort host regardless.
# However, you must set it for any further virtual host explicitly.
#ServerName www.example.com
ServerAdmin webmaster@localhost
DocumentRoot /var/www/html
# Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the loglevel for particular
# modules, e.g.
#LogLevel info ssl:warn
# For most configuration files from conf-available/, which are
# enabled or disabled at a global level, it is possible to
# include a line for only one particular virtual host. For example the
# following line enables the CGI configuration for this host only
# after it has been globally disabled with "a2disconf".
#Include conf-available/serve-cgi-bin.conf
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
Save changes in the text editor and close the editor. The next step is to restart the apache webserver to apply the changes.
systemctl restart apache2
Test the Python 3 WSGI script
Now Apache HTTP server is configured to serve our Python file over the HTTP protocol.
Open a web browser and enter the URL http://your-server-ip/wsgi. replace your-server-ip with the IP address of the server. You will get a white page with the words “Hello Howtoforge!”.
That’s all, you now have a properly configured Apache web server to run Python applications using mod_wsgi. The next step is to deploy your python web application into the directory /var/www/html/ and alter the WSGIScriptAlias line in the /etc/apache2/sites-enabled/000-default.conf file to match the start script of your application. Then restart Apache again to apply the configuration change.
Download as a virtual machine
This setup is available as a virtual machine download in ova/ovf format (compatible with VMWare and Virtualbox) for howtoforge subscribers.
Log in details for the VM
  • The password for the user ‘admininstrator’ is: ‘howtoforge’. The administrator user has sudo permissions.
Please change all passwords on the first login.
  • The IP address of the VM is 192.168.0.100
