How to run Python Scripts with Apache and mod_wsgi on Ubuntu 18.04
mod-wsgi
mod_wsgi is an Apache module that can be used for serving Python scripts over HTTP via Apache web server. You can easily deploy applications written with frameworks and tools like Django, Web.py, Werkzug, Chery.py, TurboGears, and Flask using mod_wsgi.
In this tutorial, we will learn how to install and set up of mod_wsgi with the Apache server on Ubuntu 18.04 LTS (Bionic Beaver) server.
  • A server running Ubuntu 18.04 server.
  • A static IP address 192.168.43.229 configure on your server.
Install Apache and mod_wsgi
Before starting, you will need to install some required packages to your system.
You can install all of them by running the following command:
sudo apt-get install python libexpat1 apache2 apache2-utils ssl-cert -y
Once all the required packages are installed, you can proceed to install with the following command:
sudo apt-get install libapache2-mod-wsgi -y
Configure Apache for mod_wsgi
Next, you will need to create a python script inside the Apache web root directory to serve via mod_wsgi Apache module.
You can do this with the following command:
sudo nano /var/www/html/wsgy.py
def application(environ,start_response):
    status = '200 OK'
    html = '<html>n'
    '<body>n'
    '<div style="width: 100%; font-size: 40px; font-weight: bold; text-align: center;">n'
    'Welcome to mod_wsgi Test Pagen'
    '</div>n'
    '</body>n'
    '</html>n'
    response_header = [('Content-type','text/html')]
    start_response(status,response_header)
    return [html]
Save and close the file. Then, give proper permissions to wsgi.py file:
sudo chown www-data:www-data /var/www/html/wsgy.py
sudo chmod 755 /var/www/html/wsgy.py
Next, you will need to configure Apache to serve this file over HTTP protocol. You can do this by creating wsgi.conf file:
sudo nano /etc/apache2/conf-available/wsgi.conf
WSGIScriptAlias /wsgi /var/www/html/wsgy.py
Then, enable mod-wsgi configuration and restart Apache service with the following command:
sudo a2enconf wsgi
Test Python scripts in Apache with mod-wsgi
Now, open your web browser and type the URL http://example.com/wsgi. You will be redirected to the following page:
