How to Manage Systemd Services with Systemctl on Linux
Systemd a standard process for managing start-up services in Linux operating systems. It is used for controlling which programs run when the Linux system boots up. It is a system manager and has become the new standard for Linux operating systems. Systemd allows you to create a custom systemd service to run and manage any process. In this tutorial, we will explain how to manage services with systemd on Linux.
  • A server running Linux with Systemd, I will use Ubuntu 20.04 server here.
  • A root password is configured the server.
Verify Systemd
By default, Systemd comes pre-installed in all major operating systems. You can verify the installed version of Systemd with the following command:
systemctl --version
systemd 245 (245.4-4ubuntu3)
+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid
You can find the location of the Systemd with the following command:
whereis systemd
systemd: /usr/bin/systemd /usr/lib/systemd /etc/systemd /usr/share/systemd /usr/share/man/man1/systemd.1.gz
To find systemctl location, run the following command:
whereis systemctl
systemctl: /usr/bin/systemctl /usr/share/man/man1/systemctl.1.gz
You can also verify whether the Systemd is running or not with the following command:
ps -eaf | grep systemd
root 269 1 0 09:57 ? 00:00:01 /lib/systemd/systemd-journald
root 294 1 0 09:57 ? 00:00:00 /lib/systemd/systemd-udevd
systemd+ 297 1 0 09:57 ? 00:00:00 /lib/systemd/systemd-networkd
message+ 319 1 0 09:57 ? 00:00:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
root 329 1 0 09:57 ? 00:00:00 /lib/systemd/systemd-logind
systemd+ 382 1 0 09:57 ? 00:00:00 /lib/systemd/systemd-resolved
root 1128 1 0 10:47 ? 00:00:00 /lib/systemd/systemd --user
root 1177 1152 0 10:48 pts/0 00:00:00 grep --color=auto systemd
You can also analyze the time taken by each process at system boot with the following command:
systemd-analyze blame
3.662s csm.service
1.899s apt-daily-upgrade.service
1.798s dev-sda1.device
1.400s systemd-logind.service
1.336s fstrim.service
1.207s systemd-networkd.service
1.131s systemd-resolved.service
856ms man-db.service
842ms systemd-journald.service
415ms e2scrub_reap.service
320ms keyboard-setup.service
295ms networkd-dispatcher.service
239ms systemd-udev-trigger.service
To analyze the critical chain at boot with the following command:
systemd-analyze critical-chain
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @4.948s
??multi-user.target @4.946s
??csm.service @1.282s +3.662s
??basic.target @1.277s
??sockets.target @1.276s
??dbus.socket @1.274s
??sysinit.target @1.257s
??systemd-update-utmp.service @1.247s +8ms
??systemd-tmpfiles-setup.service @1.228s +17ms
??systemd-journal-flush.service @1.201s +24ms
??systemd-journald.service @356ms +842ms
??systemd-journald.socket @313ms
??system.slice @225ms
??-.slice @225ms
Manage Services with Systemd
Systemctl provides an easier way to manage the systemd services.
To start the Apache service, run the following command:
systemctl start apache2
To restart the Apache service, run the following command:
systemctl restart apache2
To stop the Apache service, run the following command:
systemctl stop apache2
To reload the Apache service, run the following command:
systemctl reload apache2
To enable the Apache service to start after system reboot, run the following command:
systemctl enable apache2
To remove the Apache service from the system start up, run the following command:
systemctl disable apache2
To kill the Apache service, run the following command:
systemctl kill apache2
To mask the Apache service, run the following command:
systemctl mask apache2
To unmask the Apache process, run the following command:
systemctl unmask apache2
To check whether the Apache service is enabled or not, run the following command:
systemctl is-enabled apache2
To check the status of the Apache service, run the following command:
systemctl status apache2
If the service is running, you should get the following output:
Active: active (running) since Sat 2021-01-09 10:53:12 UTC; 26s ago
Main PID: 1708 (apache2)
Tasks: 55 (limit: 2353)
Memory: 5.8M
??1708 /usr/sbin/apache2 -k start
??1709 /usr/sbin/apache2 -k start
??1710 /usr/sbin/apache2 -k start
Jan 09 10:53:12 ubuntu2004 systemd[1]: Starting The Apache HTTP Server...
After renaming or deleting any systemd file, you will need to reload it to apply the changes. To reload the systemd service file, run the following command:
systemctl daemon-reload
Manage Systemd Unit Files
The above commands will be useful for managing single services. However, it can not used to find the current state of the system. There are lot of other commands that are useful for providing this information.
To see a list of all available units, run the following command:
systemctl list-unit-files
You should see a list of all unit files in the following output:
UNIT FILE STATE VENDOR PRESET
proc-sys-fs-binfmt_misc.automount static enabled
-.mount generated enabled
dev-hugepages.mount static enabled
dev-mqueue.mount static enabled
proc-sys-fs-binfmt_misc.mount disabled enabled
sys-fs-fuse-connections.mount static enabled
sys-kernel-config.mount static enabled
sys-kernel-debug.mount static enabled
sys-kernel-tracing.mount static enabled
acpid.path enabled enabled
ntp-systemd-netif.path enabled enabled
systemd-ask-password-console.path static enabled
systemd-ask-password-wall.path static enabled
session-2.scope transient enabled
acpid.service disabled enabled
apt-daily-upgrade.service static enabled
apt-daily.service static enabled
[email protected] enabled enabled
console-getty.service disabled disabled
console-setup.service enabled enabled
[email protected] static enabled
cron.service enabled enabled
cryptdisks-early.service masked enabled
cryptdisks.service masked enabled
csm.service enabled enabled
dbus-org.freedesktop.hostname1.service static enabled
dbus-org.freedesktop.locale1.service static enabled
To see a list of all active units, run the following command:
systemctl list-units
UNIT LOAD ACTIVE SUB DESCRIPTION >
proc-sys-fs-binfmt_misc.automount loaded active waiting Arbitrary Executable Fil>
sys-devices-pci0000:00-0000:00:03.0-virtio0-net-eth0.device loaded active plugged Virtio network device >
sys-devices-pci0000:00-0000:00:04.0-virtio1-net-eth1.device loaded active plugged Virtio network device >
sys-devices-pci0000:00-0000:00:05.0-virtio2-host2-target2:0:0-2:0:0:0-block-sda-sda1.device loaded active plugged QEMU_HARDDISK 1 >
sys-devices-pci0000:00-0000:00:05.0-virtio2-host2-target2:0:0-2:0:0:0-block-sda.device loaded active plugged QEMU_HARDDISK >
sys-devices-platform-serial8250-tty-ttyS1.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS10.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS11.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS12.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS13.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS14.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS15.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS16.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS17.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS18.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS19.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS2.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS20.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS21.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS22.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS23.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS24.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS25.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS26.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS27.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS28.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS29.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS3.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS30.device loaded active plugged /sys/devices/platform/se>
sys-devices-platform-serial8250-tty-ttyS31.device loaded active plugged /sys/devices/platform/se>
To see a list of all failed units, run the following command:
systemctl --failed
To list all services including enabled and disabled services, run the following command:
systemctl list-unit-files --type=service
apache-htcacheclean.service disabled enabled
[email protected] disabled enabled
apache2.service enabled enabled
dbus-org.freedesktop.login1.service static enabled
dbus-org.freedesktop.resolve1.service enabled enabled
dbus-org.freedesktop.timedate1.service static enabled
dbus-org.freedesktop.timesync1.service masked enabled
dbus.service static enabled
debug-shell.service disabled disabled
dmesg.service enabled enabled
e2scrub_all.service static enabled
e2scrub_reap.service enabled enabled
emergency.service static enabled
fstrim.service static enabled
getty-static.service static enabled
You can see the properties of SSH unit, run the following command:
systemctl show sshd.service
Id=sshd.service
Names=sshd.service
Requires=basic.target
Wants=system.slice
WantedBy=multi-user.target
Conflicts=shutdown.target
Before=shutdown.target multi-user.target
After=syslog.target network.target auditd.service systemd-journald.socket basic.target system.slice
Description=OpenSSH server daemon
Manage Sockets with Systemctl
You can also manage sockets using the Systemctl command.
To list all available system sockets, run the following command:
systemctl list-unit-files --type=socket
acpid.socket enabled enabled
dbus.socket static enabled
ssh.socket disabled enabled
syslog.socket static disabled
systemd-fsckd.socket static enabled
systemd-initctl.socket static enabled
systemd-journald-audit.socket static enabled
systemd-journald-dev-log.socket static enabled
systemd-journald.socket static enabled
systemd-networkd.socket disabled enabled
systemd-rfkill.socket static enabled
systemd-udevd-control.socket static enabled
systemd-udevd-kernel.socket static enabled
To start the SSH socket, run the following command:
systemctl start ssh.socket
To stop the SSH socket, run the following command:
systemctl stop ssh.socket
To restart the SSH socket, run the following command:
systemctl restart ssh.socket
To check the status of the SSH socket, run the following command:
systemctl status ssh.socket
To enable and disable the SSH socket at boot time, run the following command:
systemctl enable ssh.socket
systemctl disable ssh.socket
Systemctl Additional Commands
You can perform several tasks using the systemctl command. If you want to put the system into single-user mode, run the following command:
systemctl rescue
To halt the system, run the following command:
systemctl halt
To shutdown the system, run the following command:
systemctl poweroff
To restart the system, run the following command:
systemctl reboot
In the above guide, you learned how to manage and control systemd service on Linux. I hope this will helps you to interact with and control your systemd instance. Feel free to ask me if you have any questions.
