How to Manage NodeJS Versions with n in Ubuntu 20.04
If you are a Node.js developer who frequently switches between various applications and projects. Then you may need to find a tool that allows you to toggle between Node.js versions. In Linux, there are numerous utilities for managing several Node.js versions. Among these, the n Node version manager is a simple and useful tool for managing Node.js versions.
In this tutorial, we’ll show you how to use n to manage Node.js versions on Ubuntu 20.04.
First, it is recommended to update your system packages to the latest version. You can update all of them with the following command:
After updating all the packages, you may also need to install some required dependencies to your server. You can install all of them with the following command:
apt-get install curl git make -y
Once all the dependencies are installed, you can proceed to the next step.
Install n
There are several ways to install n on Linux. The simple and easiest way to install n is using npm.
Run the following command to install n:
npm install -g n
If npm is not installed in your system, you can install it by downloading the n script from GitHub:
curl -L https://raw.githubusercontent.com/tj/n/master/bin/n -o n
bash n lts
This will install Node.js, npm, and n to your system. By default, the above script does not install n in the system path. So you will need to add it to your user’s path.
nano ~/.bashrc
export N_PREFIX=$HOME/.n
export PATH=$N_PREFIX/bin:$PATH
Save and close the file then activate the path with the following command:
source ~/.bashrc
You can also install n using the n-install script. You can download and run the n-install script as shown below:
curl -L https://git.io/n-install | bash
Next, activate the n system path using the following command:
source ~/.bashrc
If you want to uninstall n from your system, run the following command:
n-uninstall
To update n to the latest version, run the following command:
n-update
To check the version of n, run the following command:
n --version
7.3.0
To check all options available with n, run the following command:
n --help
Usage: n [options] [COMMAND] [args]
Commands:
n Display downloaded Node.js versions and install selection
n latest Install the latest Node.js release (downloading if necessary)
n lts Install the latest LTS Node.js release (downloading if necessary)
n Install Node.js (downloading if necessary)
n install Install Node.js (downloading if necessary)
n run [args ...] Execute downloaded Node.js with [args ...] n run [args ...] Execute downloaded node with [args ...] n which Output path for downloaded node
n exec [args...] Execute command with modified PATH, so downloaded node and npm first
n rm Remove the given downloaded version(s)
n prune Remove all downloaded versions except the installed version
n --latest Output the latest Node.js version available
n --lts Output the latest LTS Node.js version available
n ls Output downloaded versions
n ls-remote [version] Output matching versions available for download
n uninstall Remove the installed Node.js
Options:
-V, --version Output version of n
-h, --help Display help information
-p, --preserve Preserve npm and npx during install of Node.js
-q, --quiet Disable curl output. Disable log messages processing "auto" and "engine" labels.
-d, --download Download only
-a, --arch Override system architecture
--all ls-remote displays all matches instead of last 20
--insecure Turn off certificate checking for https requests (may be needed from behind a proxy server)
--use-xz/--no-use-xz Override automatic detection of xz support and enable/disable use of xz compressed node downloads.
Manage Node.js Versions
To install the latest Node.js version, run the following command:
n latest
installing : node-v16.4.0
mkdir : /root/n/n/versions/node/16.4.0
fetch : https://nodejs.org/dist/v16.4.0/node-v16.4.0-linux-x64.tar.xz
installed : v16.4.0 (with npm 7.18.1)
Next, check the Node.js version using the following command:
node --version
v16.4.0
To install the Node.js lts version, run the following command:
n lts
installed : v14.17.1 (with npm 6.14.13)
To install the specific Node.js version, run the following command:
n 14.15.0
installing : node-v14.15.0
mkdir : /root/n/n/versions/node/14.15.0
fetch : https://nodejs.org/dist/v14.15.0/node-v14.15.0-linux-x64.tar.xz
installed : v14.15.0 (with npm 6.14.8)
To download the specific Node.js version, run the following command:
n -d 14.8.0
installing : node-v14.8.0
mkdir : /root/n/n/versions/node/14.8.0
fetch : https://nodejs.org/dist/v14.8.0/node-v14.8.0-linux-x64.tar.xz
To use the downloaded Node.js version, run the following command:
n run 14.8.0
Welcome to Node.js v14.8.0.
Type ".help" for more information.
Next, exit from the Node.js shell with the following command:
> .exit
To list all installed versions of Node.js, run the following command:
n ls
node/14.8.0
node/14.15.0
node/14.17.1
node/16.4.0
To list all available Node.js versions, run the following command:
n ls-remote
Listing remote... Displaying 20 matches (use --all to see all).
16.4.0
16.3.0
16.2.0
16.1.0
16.0.0
15.14.0
15.13.0
15.12.0
15.11.0
15.10.0
15.9.0
15.8.0
15.7.0
15.6.0
15.5.1
15.5.0
15.4.0
15.3.0
15.2.1
15.2.0
The above command will list only 20 available versions. If you want to list all available Node.js versions, run the following command:
n ls-remote --all
To find the location of a specific Node.js version, run the following command:
n which node/14.8.0
/root/n/n/versions/node/14.8.0/bin/node
To switch between different Node.js versions, run the following command:
n
You will be asked to select the Node.js version that you want to switch:
node/14.8.0
node/14.15.0
ο node/14.17.1
node/16.4.0
Use up/down arrow keys to select a version, return key to install, d to delete, q to quit
Select your desired Node.js version and hit Enter to set it as a default version.
Remove Node.js Version with n
To remove a specific Node.js version, run the following command:
n rm node/16.4.0
To remove all downloaded Node.js versions, run the following command:
n prune
To remove all installed Node.js versions, run the following command:
n uninstall
Do you wish to delete node and npm from /root/n? Y
Uninstalling node and npm
/root/n/bin/node
/root/n/bin/npm
/root/n/bin/npx
/root/n/include/node
/root/n/lib/node_modules/npm
/root/n/share/doc/node
/root/n/share/man/man1/node.1
/root/n/share/systemtap/tapset/node.stp
In the above guide, you learned how to install and manage Node.js versions using n. I hope this will helps you to easily switch between different projects and applications.
