How to List, Display, & View all Current Cron Jobs in Linux
Cron is a Linux utility for scheduling scripts and commands. This guide will show you several options to view current cron jobs scheduled in the crontab list.
how to display cron jobs in linux
  • A user account with sudo privileges
  • Access to a terminal window / command line (Ctrl+Alt+T, Ctrl+Alt+F2)
Listing Cron Jobs in Linux
How to List all Active Cron Jobs Running
To list all scheduled cron jobs for the current user, enter:
crontab -l
Cron jobs are typically located in the spool directories. They are stored in tables called crontabs. You can find them in /var/spool/cron/crontabs. The tables contain the cron jobs for all users, except the root user.
The root user can use the crontab for the whole system.
To display contents of the root user’s crontab, use the less command:
less /etc/crontab
The system returns an output like the following:
# /etc/crontab: system-wide crontab
# Unlike any other crontab you don't have to run the `crontab'
# command to install the new version when you edit this file
# and files in /etc/cron.d. These files also have username fields,
# that none of the other crontabs do.
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
# m h dom mon dow user  command
17 *    * * *   root    cd / && run-parts --report /etc/cron.hourly
25 6    * * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
47 6    * * 7   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
52 6    1 * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
The /etc/crontab file can be edited using a text editor like nano:
sudo nano /etc/crontab
In RedHat-based systems, this file is located at /etc/cron.d.
The /etc/ directory has additional cron subdirectories to organize hourly, daily, weekly, and monthly tasks. The ls (list) command displays files and directories. Use the -la option to list all entries in long format.
View Cron Jobs by User
To list cron jobs that belong to a specific user, run the following command:
sudo crontab -u [username] -l
Replace [username] with the actual username you’re viewing.
How to List Hourly Cron Jobs
To list hourly cron jobs enter the following in the terminal window:
ls -la /etc/cron.hourly
The output should appear similar to this:
output of list hourly cron jobs
How to List Daily Cron Jobs
To list daily cron jobs, enter the command:
ls -la /etc/cron.daily
The results will look similar to the following output:
a listing of daily cron jobs currently running
How to Display Weekly Cron Jobs
To display weekly cron jobs:
ls -la /etc/cron.weekly
The results will look something like the following:
total 28
drwxr-xr-x  2 root root 4096 Apr 24 20:46 .
drwxr-xr-x 96 root root 4096 May 19 17:12 ..
-rw-r--r--  1 root root  102 Feb  9  2013 .placeholder
-rwxr-xr-x  1 root root  730 Feb 23  2014 apt-xapian-index
-rwxr-xr-x  1 root root  427 Apr 16  2014 fstrim
-rwxr-xr-x  1 root root  771 Sep 23  2014 man-db
-rwxr-xr-x  1 root root  211 Mar 27  2017 update-notifier-common
How to List Monthly Cron Jobs
To display monthly cron jobs use the ls command in this format:
ls -la /etc/cron.monthly
The results appear as:
total 12
drwxr-xr-x  2 root root 4096 Apr 24 20:44 .
View Software Specific Cron Jobs
To view software specefic cron tasks, start by viewing a list of cron tasks:
cd /etc/cron/daily
ls -l
Use the cat command to display the contents of update-notifier-common:
cat update-notifier-common
The results will look similar to:
#!/bin/sh
set -e
[ -x /usr/lib/update-notifier/package-data-downloader ] || exit 0
# Try to rerun any package data downloads that failed at package install time.
Note: You should also learn more about Linux at command, another useful tool for scheduling jobs.
Now you know how to navigate through the cron jobs on your machine. Cron is a helpful utility for scheduling tasks such as running a job at reboot. Use the commands from this guide to sort and display tasks scheduled through the cron tool.
