How to Install WordPress with Nginx and Let’s Encrypt SSL on Ubuntu 22.04
WordPress is a free and open-source content management system mainly used to publish blogs on the internet. It is designed for those who don’t know how to code. WordPress makes it simple to create and maintain websites and blogs. Due to its popularity, more than a third of websites today are powered by WordPress. It is written in PHP and used MariaDB and MySQL as a database backend.
In this tutorial, we will show you how to install WordPress with Nginx and a free Let’s Encrypt SSL certificate on Ubuntu 22.04.
Install Nginx, MariaDB, and PHP
Before starting, the LEMP server must be installed on your server. If not installed, you can install it by running the following command:
apt-get install nginx mariadb-server php php-fpm php-curl php-mysql php-gd php-mbstring php-xml php-imagick php-zip php-xmlrpc -y
Once the LEMP server is installed, verify the PHP version using the following command:
php -v
You will get the PHP version in the following output:
PHP 8.1.2 (cli) (built: Apr 7 2022 17:46:26) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.1.2, Copyright (c) Zend Technologies
with Zend OPcache v8.1.2, Copyright (c), by Zend Technologies
Next, edit the PHP configuration file and tweak some default settings:
nano /etc/php/8.1/fpm/php.ini
Change the following lines:
cgi.fix_pathinfo=0
upload_max_filesize = 128M
post_max_size = 128M
memory_limit = 512M
max_execution_time = 120
Create a Database for WordPress
WordPress uses a database to store its content. So you will need to create a database and user for WordPress.
First, log in to the MariaDB shell with the following command:
mysql
Once you are logged in, create a database and user with the following command:
MariaDB [(none)]> CREATE DATABASE wpdb;
MariaDB [(none)]> CREATE USER 'wpuser'@'localhost' IDENTIFIED BY 'securepasssword';
Next, grant all the privileges to the WordPress database using the following command:
MariaDB [(none)]> GRANT ALL ON wpdb.* TO 'wpuser'@'localhost';
MariaDB [(none)]> EXIT;
Install WordPress on Ubuntu 22.04
First, navigate to the Nginx web root directory and download the latest version of WordPress using the following command:
cd /var/www/html
wget https://wordpress.org/latest.tar.gz
Once the WordPress is downloaded, extract the downloaded file with the following command:
tar -zxvf latest.tar.gz
Next, rename the WordPress sample configuration file.
mv /var/www/html/wordpress/wp-config-sample.php /var/www/html/wordpress/wp-config.php
Next, edit the WordPress configuration file and define your database settings:
nano /var/www/html/wordpress/wp-config.php
Define your database settings as shown below:
define( 'DB_NAME', 'wpdb' );
/** Database username */
define( 'DB_USER', 'wpuser' );
/** Database password */
define( 'DB_PASSWORD', 'securepasssword' );
/** Database hostname */
define( 'DB_HOST', 'localhost' );
For security reasons, you will also need to update the security keys in your wp-config file. First, go here to generate them. Then, add it as shown below:
define('AUTH_KEY', 'Y$I,-gafVeR>Z-8qy&jQ62L}{R)e|lK/#RBh.Y#f+p-P*.8,,hP-iX[q3*tVP-fu');
define('SECURE_AUTH_KEY', 'D)k6o`D G%<()-zXP5{T{v2)Zgo-c+8T-Un=+R3%n/X2=MLDb5$O]UHA%gK| .WR');
define('LOGGED_IN_KEY', 'eL|5#`ul|;MrKm#q$KVl/ky(i}Jc;xrH(Eb|Hwzb/?-.RLSUSX2X[4HD:U:UOP:Y');
define('NONCE_KEY', ']azQ+9f^#~l*r>uPMH5H>ck:?az4o[)*Txo:+MGjE5f&0kag3O9m85g3~VJ6YVWE');
define('AUTH_SALT', 'fAM5&`m4X+{+wSsF.!}-/8@Ce~~u%>}la1bCC,@#+R*t]uYf?[hph/>!Bw>v#oaQ');
define('SECURE_AUTH_SALT', '}|Z&dj_tFV2T$7y(O#O|bwwQ$sH6t!-zdE.MlOHLZ>4WDqG:_Qzn#Allm-UO1#7P');
define('LOGGED_IN_SALT', 'b9Uf~**E_xt@{KWknsAL^9D7Ix3CO.+PpFF~btd)-pG~pXPQ,ut3K%CS~7g.} *NztVlgZDr`?>wxJ+_VW-D_zif');
Save and close the file when you are finished. Next, set proper permission and ownership to the WordPress directory:
chown -R www-data:www-data /var/www/html/wordpress
chmod -R 755 /var/www/html/wordpress
Create an Nginx Virtual Host for WordPress
Next, you will need to create an Nginx virtual host configuration file to serve WordPress over the internet.
nano /etc/nginx/conf.d/wordpress.conf
Add the following configuration:
root /var/www/html/wordpress;
server_name wordpress.example.com;
client_max_body_size 500M;
location = /favicon.ico {
log_not_found off;
access_log off;
location ~* .(js|css|png|jpg|jpeg|gif|ico)$ {
expires max;
log_not_found off;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location ~ .php$ {
fastcgi_pass unix:/var/run/php/php8.1-fpm.sock;
include fastcgi_params;
Save and close the file then verify the Nginx configuration using the following command:
nginx -t
Next, restart the Nginx and PHP-FPM services to apply the changes.
systemctl restart nginx
systemctl restart php8.1-fpm
You can also check the status of the Nginx using the following command:
systemctl status nginx
Active: active (running) since Thu 2022-05-05 11:36:28 UTC; 10s ago
Docs: man:nginx(8)
Process: 16880 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 16882 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Main PID: 16883 (nginx)
Tasks: 3 (limit: 4630)
Memory: 3.4M
CPU: 49ms
??16883 "nginx: master process /usr/sbin/nginx -g daemon on; master_process on;"
??16884 "nginx: worker process" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ""
??16885 "nginx: worker process" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ""
May 05 11:36:28 ubuntu2204 systemd[1]: Starting A high performance web server and a reverse proxy server...
May 05 11:36:28 ubuntu2204 systemd[1]: Started A high performance web server and a reverse proxy server.
Complete WordPress Web Installation
Now, open your web browser and access the WordPress installation wizard using the URL http://wordpress.example.com. You will be redirected to the following page:
Select your language and click on the Continue button. You should see the WordPress Site configuration page:
Provide your website name, admin username, password, email, and click on the Install WordPress button. Once the WordPress is installed, you should see the following page:
Click on the Log in button. You should see the WordPress login page:
Provide your admin username, password, and click on the Login button. You should see the WordPress dashboard on the following page:
Enable HTTPS on WordPress
To enable HTTPS on your site, you will need to install the Certbot Let’s Encrypt client to your system. You can install it by running the following command:
apt-get install python3-certbot-nginx -y
Once the Certbot client is installed, run the following command to enable the HTTPS on your website:
certbot --nginx -d wordpress.example.com
You will be asked to provide a valid email address and accept the term of service as shown below:
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for wordpress.example.com
Waiting for verification...
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/nginx/conf.d/wordpress.conf
Next, choose whether or not to redirect HTTP traffic to HTTPS as shown below:
Type 2 and hit Enter to finish the installation. You should see the following output:
Redirecting all traffic on port 80 to ssl in /etc/nginx/conf.d/wordpress.conf
Congratulations! You have successfully enabled https://wordpress.example.com
https://www.ssllabs.com/ssltest/analyze.html?d=wordpress.example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/wordpress.example.com/fullchain.pem
/etc/letsencrypt/live/wordpress.example.com/privkey.pem
Your cert will expire on 2023-02-08. To obtain a new or tweaked
- We were unable to subscribe you the EFF mailing list because your
e-mail address appears to be invalid. You can try again later by
visiting https://act.eff.org.
Congratulations! you have successfully installed WordPress with Nginx and Let’s Encrypt SSL on Ubuntu 22.04. You can now install your preferred themes, and plugins and start building your own website.
