How to Install Wiki.js on Ubuntu 22.04 LTS
Wiki.js is an open-source, lightweight wiki software. It is built on the Node.js JavaScript framework. It can be used to write documentation, wiki, and web content using a Markdown editor for developers and a WYSIWYG editor for non-technical people. It supports multiple content types including UML diagrams, Math expressions using Tex or MathML syntax, and code. It includes multiple modules for various functions including analytics, authentication, logging, third-party search engines, and multiple storage services to sync your content to.
In this tutorial, you will learn to install Wiki.js on a Ubuntu 22.04 server using the PostgreSQL database and Nginx server for proxying.
  • A fully qualified domain name (FQDN) pointing to your server. For our purposes, we will use wiki.example.com as the domain name.
  • Make sure everything is updated.
    $ sudo apt update && sudo apt upgrade
  • Install basic utility packages. Some of them may already be installed.
    $ sudo apt install wget curl ca-certificates gnupg gnupg2 nano unzip lsb-release ubuntu-keyring -y
Step 1 – Configure Firewall
Before installing any packages, the first step is configuring the firewall to allow HTTP and HTTPS connections.
$ sudo ufw status
Status: active
To Action From
OpenSSH ALLOW Anywhere
Allow HTTP and HTTPs ports.
$ sudo ufw allow http
$ sudo ufw allow https
$ sudo ufw status
Status: active
To Action From
80/tcp ALLOW Anywhere
443 ALLOW Anywhere
443 (v6) ALLOW Anywhere (v6)
Step 2 – Install PostgreSQL and Utilities
Ubuntu 22.04 ships with an older version of PostgreSQL. We will install Postgres 14 for our tutorial.
Install the repository for PostgreSQL.
$ sudo sh -c 'echo "deb http://apt.postgresql.org/pub/repos/apt $(lsb_release -cs)-pgdg main" > /etc/apt/sources.list.d/pgdg.list'
Import PostgreSQL GPG key.
$ curl https://www.postgresql.org/media/keys/ACCC4CF8.asc | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/apt.postgresql.org.gpg >/dev/null
$ sudo apt update
Install PostgreSQL 14 server.
$ sudo apt install -y postgresql-14
$ sudo systemctl status postgresql
Loaded: loaded (/lib/systemd/system/postgresql.service; enabled; vendor preset: enabled)
Active: active (exited) since Tue 2022-10-25 06:24:24 UTC; 10min ago
Main PID: 4032 (code=exited, status=0/SUCCESS)
CPU: 1ms
Oct 25 06:24:24 wiki systemd[1]: Starting PostgreSQL RDBMS...
Oct 25 06:24:24 wiki systemd[1]: Finished PostgreSQL RDBMS.
Step 3 – Configure PostgreSQL
Log in to the PostgreSQL shell.
$ sudo -i -u postgres psql
Create a new database for Wiki.js.
postgres=# CREATE DATABASE wikidb;
Create a new database user with a strong password.
postgres=# CREATE USER wikiuser WITH ENCRYPTED PASSWORD 'wikipassword';
Grant the rights to the user to use the database.
postgres=# GRANT ALL PRIVILEGES ON DATABASE wikidb TO wikiuser;
Exit the Postgres Shell.
postgres=# q
Step 4 – Install Node.js
Wiki.js supports Node v16 at the moment of writing this tutorial.
Install the Node repository using the following command.
$ curl -fsSL https://deb.nodesource.com/setup_16.x | sudo -E bash -
Install Node.
$ sudo apt install nodejs -y
Verify Node installation.
$ node --version
v16.18.0
Step 5 – Download Wiki.js
Create a folder to install Wiki.js.
$ sudo mkdir -p /var/www/wikijs
Set the currently logged-in user as the owner of the folder.
$ sudo chown $USER:$USER /var/www/wikijs
Switch to the directory and download the Wiki.js code archive.
$ cd /var/www/wikijs && wget https://github.com/Requarks/wiki/releases/latest/download/wiki-js.tar.gz
Extract the downloaded archive.
$ tar xzf wiki-js.tar.gz
Delete the archive.
$ rm wiki-js.tar.gz
Step 6 – Configure and Run Wiki.js
Create the configuration file from the sample.
$ cp config.sample.yml config.yml
Open the configuration file for editing.
$ nano config.yml
Find the following database settings and update their values with the ones configured in step 3.
# PostgreSQL / MySQL / MariaDB / MS SQL Server only:
host: localhost
port: 5432
user: wikiuser
pass: wikipassword
db: wikidb
ssl: false
Find the line bindIP: 0.0.0.0 and update it as follows.
bindIP: 127.0.0.1
This will make WIki.js listen on the loopback address because we will be using the Nginx proxy to access it from the outside.
Run Wiki.js by using the following command.
$ node server
You will receive a similar output confirming a successful install.
Loading configuration from /var/www/wikijs/config.yml... OK
2022-10-25T06:40:46.294Z [MASTER] info: =======================================
2022-10-25T06:40:46.296Z [MASTER] info: = Wiki.js 2.5.289 =====================
2022-10-25T06:40:46.296Z [MASTER] info: =======================================
2022-10-25T06:40:46.296Z [MASTER] info: Initializing...
2022-10-25T06:40:46.962Z [MASTER] info: Using database driver pg for postgres [ OK ] 2022-10-25T06:40:46.974Z [MASTER] info: Connecting to database...
2022-10-25T06:40:47.067Z [MASTER] info: Database Connection Successful [ OK ] 2022-10-25T06:40:47.345Z [MASTER] warn: DB Configuration is empty or incomplete. Switching to Setup mode...
2022-10-25T06:40:47.345Z [MASTER] info: Starting setup wizard...
2022-10-25T06:40:47.510Z [MASTER] info: Starting HTTP server on port 3000...
2022-10-25T06:40:47.511Z [MASTER] info: HTTP Server on port: [ 3000 ] 2022-10-25T06:40:47.515Z [MASTER] info: HTTP Server: [ RUNNING ] 2022-10-25T06:40:47.515Z [MASTER] info: .......................................................................
2022-10-25T06:40:47.516Z [MASTER] info: Browse to http://YOUR-SERVER-IP:3000/ to complete setup!
2022-10-25T06:40:47.516Z [MASTER] info: ........................................................................
Press Ctrl + C to stop the process.
Step 7 – Setup a Systemd Service
The above process to keep Wiki.js running is temporary. To make the process permanent, we will need to create a systemd service for Wiki.js to run it as a background service. This will allow Wiki.js to run across system reboots.
Create a systemd service file for Wiki.js and open it for editing.
$ sudo nano /etc/systemd/system/wikijs.service
Paste the following code in it. Replace the value of the variable User with the name of your system user.
[Unit] Description=Wiki.js
After=network.target
[Service] Type=simple
ExecStart=/usr/bin/node server
Restart=always
User=navjot
Environment=NODE_ENV=production
WorkingDirectory=/var/www/wikijs
[Install] WantedBy=multi-user.target
Reload the system daemon.
$ sudo systemctl daemon-reload
Enable the Wiki.js service.
$ sudo systemctl enable wikijs
Step 8 – Install Nginx
Ubuntu 22.04 ships with an older version of Nginx. You need to download the official Nginx repository to install the latest version.
Import the official Nginx key.
Set up the official repository for Nginx.
$ echo "deb [signed-by=/usr/share/keyrings/nginx-archive-keyring.gpg] http://nginx.org/packages/ubuntu `lsb_release -cs` nginx"
Pin the repository to give preference to the official repo over Ubuntu one.
$ echo -e "Package: *nPin: origin nginx.orgnPin: release o=nginxnPin-Priority: 900n"
| sudo tee /etc/apt/preferences.d/99nginx
$ sudo apt update
Install the Nginx server.
$ sudo apt install nginx -y
Verify the installation.
$ nginx -v
nginx version: nginx/1.22.1
Start the Nginx server.
$ sudo systemctl start nginx
$ sudo systemctl status nginx
Active: active (running) since Tue 2022-10-25 06:50:05 UTC; 2s ago
Process: 5522 ExecStart=/usr/sbin/nginx -c /etc/nginx/nginx.conf (code=exited, status=0/SUCCESS)
Main PID: 5523 (nginx)
Tasks: 2 (limit: 1030)
Memory: 1.8M
CPU: 4ms
??5523 "nginx: master process /usr/sbin/nginx -c /etc/nginx/nginx.conf"
??5524 "nginx: worker process" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ""
Oct 25 06:50:05 wiki systemd[1]: Starting nginx - high performance web server...
Step 9 – Install SSL
We need to install Certbot to generate the SSL certificate. You can either install Certbot using Ubuntu’s repository or grab the latest version using the Snapd tool. We will be using the Snapd version.
Ubuntu 22.04 comes with Snapd installed by default. Run the following commands to ensure that your version of Snapd is up to date.
$ sudo snap install core
$ sudo snap refresh core
Install Certbot.
Run the following command to issue the certificate.
$ sudo certbot certonly --nginx --agree-tos --no-eff-email --staple-ocsp --preferred-challenges http -m [email protected] -d wiki.example.com
The above command will download a certificate to the /etc/letsencrypt/live/wiki.example.com directory on your server.
$ sudo systemctl list-timers
Tue 2022-10-25 00:00:00 UTC 17h left Tue 2022-10-25 04:49:20 UTC 2h ago logrotate.timer logrotate.service
Tue 2022-10-25 02:39:09 UTC 20h left Tue 2022-10-25 06:47:33 UTC 12min ago apt-daily.timer apt-daily.service
Tue 2022-10-25 06:02:00 UTC 8h left n/a n/a snap.certbot.renew.timer snap.certbot.renew.service
Step 10 – Configure Nginx
Create and open the file /etc/nginx/conf.d/wikijs.conf for editing.
$ sudo nano /etc/nginx/conf.d/wikijs.conf
# enforce HTTPS
listen [::]:80;
server_name wiki.example.com;
listen 443 ssl http2;
listen [::]:443 ssl http2;
root /var/www/wikijs;
access_log /var/log/nginx/wiki.access.log;
error_log /var/log/nginx/wiki.error.log;
http2_push_preload on; # Enable HTTP/2 Server Push
ssl_certificate /etc/letsencrypt/live/wiki.example.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/wiki.example.com/privkey.pem;
ssl_trusted_certificate /etc/letsencrypt/live/wiki.example.com/chain.pem;
ssl_session_timeout 1d;
# Enable TLS versions (TLSv1.3 is required upcoming HTTP/3 QUIC).
# Enable TLSv1.3's 0-RTT. Use $ssl_early_data when reverse proxying to
# prevent replay attacks.
# @see: https://nginx.org/en/docs/http/ngx_http_ssl_module.html#ssl_early_data
ssl_early_data on;
ssl_ciphers 'ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384';
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:50m;
# OCSP Stapling ---
# fetch OCSP records from URL in ssl_certificate and cache them
ssl_stapling on;
ssl_stapling_verify on;
add_header X-Early-Data $tls1_3_early_data;
proxy_http_version 1.1;
proxy_pass http://127.0.0.1:3000;
# This block is useful for debugging TLS v1.3. Please feel free to remove this
# and use the `$ssl_early_data` variable exposed by NGINX directly should you
# wish to do so.
map $ssl_early_data $tls1_3_early_data {
"~." $ssl_early_data;
default "";
Replace the root location in the above file with the directory on your server.
$ sudo nginx -t
If you see no errors, it means you are good to go.
Start the Wiki.js service.
$ sudo systemctl start wikijs
Reload the Nginx server.
$ sudo systemctl reload nginx
Step 11 – Finish the Installation
Visit the URL https://wiki.example.com to finish the installation.
Wiki.js Setup Page
Fill in your administrator account details and the URL. Disable Telemetry by unchecking the Allow Telemetry option. You can disable it from the Administration panel as well. Click the Install button to proceed.
You will be taken to the login page.
Wiki.js Login Page
Enter your account details and click the Log in button to proceed to the administration page.
Wiki.js Administration Page
You can now start using Wiki.js.
This concludes our tutorial, where you learned how to install Wiki.js on a Ubuntu 22.04 server. If you have any questions, post them in the comments below.
