How to install Sysdig to Monitor System Load on Ubuntu 20.04
Sysdig is an open-source and comprehensive activity monitoring tool for Linux. It is used to capture and analyze application logs and helps you to troubleshoot system-related issues. It displays a complete overview of CPU usage, Memory usage, Users, IO in a command-line interface. It is available for Linux, OS X, and Windows operating systems.
In this post, we will show you how to install and use the Sysdig monitoring tool on Linux.
Install Sysdig
For Debian based operating systems like, Ubuntu and Debian, install the Sysdig with the following command:
apt-get install gnupg software-properties-common curl -y
curl -s https://s3.amazonaws.com/download.draios.com/stable/install-sysdig | bash
For RPM-based operating systems like CentOS, RHEL, and Fedora, install the Sysdig with the following command:
rpm --import https://s3.amazonaws.com/download.draios.com/DRAIOS-GPG-KEY.public
curl -s -o /etc/yum.repos.d/draios.repo https://s3.amazonaws.com/download.draios.com/stable/rpm/draios.repo
yum install sysdig -y
After installing Sysdig, verify the installed version of Sysdig using the following command:
sysdig --version
sysdig version 0.27.1
Working with Sysdig
You can run the csysdig command to display the running processes, CPU usage, and memory usage:
csysdig
You should see the following screen:
csysdig
Now press F2 to open the other menu as shown below:
processes
From here, you can arrow key to choose any things that you want to monitor in the left pane and hit Enter. For example, select the connections and hit Enter. You should see all incoming connections on the following screen:
connections
To view Processes and CPU information, select Processes CPU and hit Enter. You should see the following page:
CPU processes
If you want to monitor all network connections directly from the command-line interface, run the following command:
sysdig -c netstat
sysdig netstat
You can see the HTTP request log using the following command:
sysdig -c httplog
You should see all incoming HTTP requests in the following output:
2021-07-24 15:23:26.228051410 < method=GET url=69.87.220.62/ response_code=200 latency=1ms size=3138B
2021-07-24 15:23:53.139933688 < method=GET url=69.87.220.62/ response_code=200 latency=1ms size=3138B
To monitor the process as per the CPU usage, run the following command:
sysdig -c topprocs_cpu
Run the following command to see all options available with sysdig command:
sysdig -cl
sysdig -cl
You can use sysdig with spy_users to display interactive user activity.
sysdig -c spy_users
13133 15:38:03 root) free -m
13133 15:38:22 root) df -h
In the above guide, we explained how to install and use Sysdig to monitor the system activity in real-time. I hope this will help you to troubleshoot system-related issues.
