How to Install Pydio Cells on Debian 12
Pydio Cells is a self-hosted Document Sharing and Collaboration platform. It also gives you full control of your document-sharing environment. The Pydio Cells is a fast performance, can handle huge file transfer sizes, and provides advanced workflow automation.
In the following guide, I will walk you through the installation of Pydio Cells as a file-sharing and collaboration tool on a Debian 12 server. You will install Pydio Cells with the MariaDB database server and Apache2 reverse proxy. You’ll also secure the installation with SSL/TLS certificates that you will generate via Certbot and Letsencrypt.
Before moving on, gathers the following:
  • A Debian 12 server.
  • A domain name pointed to the server IP address.
Installing Dependencies
The Pydio Cells is an open-source file sharing, management, and collaboration. Before installing it, you must install dependencies such as MariaDB for the database server and Apache2 for the reverse proxy. You will also install Certbot for generating SSL/TLS certificates to secure your installation.
First, refresh your Debian package index using the following apt update command.
Now install dependencies via the apt install command below. You will install the MariaDB server that will be used as the database for Pydio Cells, the Apache2 web server as a reverse proxy, and Certbot for generating SSL/TLS certificates from Letsencrypt.
sudo apt install mariadb-server apache2 certbot wget
Type y to confirm the installation and press ENTER.
install dependnecies
Once dependencies are installed, verify the apache2 service using the following systemctl command. Ensure that the apache2 service is enabled and running.
sudo systemctl status apache2
The following output indicates that apache2 is enabled and running.
checking apache2
Lastly, verify the mariadb service via the following systemctl command.
sudo systemctl status mariadb
The output should be similar, which indicates the mariadb service is running and enabled.
checking mariadb
Configuring MariaDB Server
In the following step, you will be securing your MariaDB server installation via the mariadb-secure-installation utility. Then, you will create a new database and user for Pydio Cells.
Execute the mariadb-secure-installation command below to start configuring the MariaDB server.
The setup process will require you to input Y to confirm the new settings or n for no. Below are some of the MariaDB server configurations you will be asked for:
  • Switch local authentication to unix_socket? Input n.
  • Set up the new MariaDB root password? Input y to confirm, then type the new password for your MariaDB server deployment.
  • Remove anonymous user? Input y to confirm.
  • Remove the default database test from the deployment?. Input y to confirm.
  • Disallow MariaDB root login from remote connections? Input y to confirm.
  • Reload table privileges and apply the changes? Input y and press ENTER.
After the MariaDB is secured, you will create a new database and user for the Pydio Cells installation. To do that, you must log in to the MariaDB server.
Execute the following mariadb command to log in to the MariaDB server. Input your MariaDB root password when prompted.
sudo mariadb -u root -p
Once logged in, run the following queries to create a new database cells, a user pydio with the password p4ssw0rd. Then, allow user pydio to access the database cells.
CREATE DATABASE cells;
CREATE USER 'pydio'@'localhost' IDENTIFIED BY 'p4ssw0rd';
GRANT ALL PRIVILEGES ON cells.* to 'pydio'@'localhost';
FLUSH PRIVILEGES;
create database and user
Next, run the following query to ensure the user pydio can access the database cells.
SHOW GRANTS FOR 'pydio'@'localhost';
The following output shows you the user pydio has privileges to access and manage the database cells.
check grants
Type quit to exit from the MariaDB server.
Installing Pydio Cells
After configuring the MariaDB server, you will install the Pydio Cells via static binary file. And before that, you must prepare your system by creating a new dedicated user, setting up a data directory, and creating some system environment variables that are needed by Pydio Cells.
Setting Up User and Environment Variables
First, create a new user pydio using the following command.
sudo useradd -m -s /bin/bash pydio
Now create a new data directory /var/cells for your Pydio Cells installation and change the ownership to the user pydio.
sudo mkdir -p /opt/pydio/bin /var/cells
sudo chown -R pydio: /opt/pydio /var/cells
Next, run the following command to create new environment variables configuration /etc/profile.d/cells-env.sh and change the permission to 0755 to make it executable. The environment variable CELLS_WORKING_DIR for the data directory, CELLS_BIND to determine which IP address and port Pydio Cells will be running, and the CELLS_EXTERNAL is the domain name of your Pydio Cells installation.
sudo tee -a /etc/profile.d/cells-env.sh << EOF
export CELLS_WORKING_DIR=/var/cells
export CELLS_BIND=https://127.0.0.1:8080
export CELLS_EXTERNAL=https://cells.hwdomain.io
EOF
sudo chmod 0755 /etc/profile.d/cells-env.sh
setup system
Now log in as the user pydio and verify environment variables CELLS_WORKING_DIR, CELLS_BIND, and CELLS_EXTERNAL.
su - pydio
echo $CELLS_WORKING_DIR
echo $CELLS_BIND
echo $CELLS_EXTERNAL
If successful, you should see each environment variable will be matched with the file /etc/profile.d/cells-env.sh.
checking env
Downloading and Installing Pydio Cells
Execute the following command to download the binary static file of Pydio Cells to /opt/pydio/bin/cells.
export distribId=cells
wget -O /opt/pydio/bin/cells https://download.pydio.com/latest/${distribId}/release/{latest}/linux-amd64/${distribId}
Once the Pydio Cells are downloaded, make it executable using the following command. Then, type exit to log out from user pydio.
chmod a+x /opt/pydio/bin/cells
exit
Now run the following command to allow cells to bind in the privileged ports. Then, create a symlink for the /opt/pydio/bin/cells command to /usr/local/bin/cells.
sudo setcap 'cap_net_bind_service=+ep' /opt/pydio/bin/cells
sudo ln -s /opt/pydio/bin/cells /usr/local/bin/cells
Now log in again as a pydio user and check the binary file of cells. Then, verify your current cells version.
su - pydio
which cells
cells version
You should see the cells binary file is located at /usr/local/bin/cells and the cells version that was installed is 4.2.5.
checking pydio version
Configuring Pydio Cells
With the Pydio Cells binary file installed, you will start configuring it, which can be done via CLI (command-line interface) or web browser. As for this case, you will configure Pydio Cells from the command-line terminal, you will set up the database, create the admin user, then will create a new systemd service file to run Pydia Cells in the background.
Run the cells command below to start configuring the Pydio Cells installation. The parameter –cli allow you to configure Pydio Cells from your terminal with an interactive environment.
cells configure --cli
Below some configurations that you will be asked for:
  • For the database configuration, select via TCP and input the database host as localhost, port with default 3306, database name cells, the user pydio, and the password.
  • Input n when prompted about the MongoDB configuration for high-availability Cells installation.
  • Input the new admin user and password for your Pydio Cells installation.
  • For the storage configuration, select the option /var/cells/data.
When the configuration process is finished, you should get an output Installation Finished like the following:
configuring cells
Now that you’ve configured Pydio Cells, the next step you will set up cells to run in the background as a systemd service. This makes you easier to manage cells via the systemctl command utility.
Use the following nano editor command to create a new systemd service file /etc/systemd/system/cells.service.
sudo nano /etc/systemd/system/cells.service
Insert the following configuration and be sure to change some environment variables CELLS_WORKING_DIR, CELLS_BIND, and CELLS_EXTERNAL within the below configuration.
[Unit]Description=Pydio Cells
Documentation=https://pydio.com
Wants=network-online.target
After=network-online.target
AssertFileIsExecutable=/opt/pydio/bin/cells
[Service]User=pydio
Group=pydio
PermissionsStartOnly=true
AmbientCapabilities=CAP_NET_BIND_SERVICE
ExecStart=/opt/pydio/bin/cells start
Restart=on-failure
StandardOutput=journal
StandardError=inherit
LimitNOFILE=65536
TimeoutStopSec=5
KillSignal=INT
SendSIGKILL=yes
SuccessExitStatus=0
WorkingDirectory=/home/pydio
# Add environment variables
Environment=CELLS_WORKING_DIR=/var/cells
Environment=CELLS_BIND=https://127.0.0.1:8080
Environment=CELLS_EXTERNAL=https://cells.hwdomain.io
[Install]WantedBy=multi-user.target
When finished, save the file and exit the editor.
Now run the following systemctl command to reload the systemd manager and apply the new systemd service.
sudo systemctl daemon-reload
Start and enable the cells service using the systemctl command below. This command will add the cells service to start automatically at system boot.
sudo systemctl start cells
sudo systemctl enable cells
cells systemd
Verify the cells service status using the command below. The Pydio Cells should be running on 127.0.0.1 with port 8080, as defined within the CELLS_BIND environment variable.
sudo systemctl status cells
If running, you should get an output such as active (running).
cells is running
Configuring Apache2 as a Reverse Proxy
At this point, the Pydio Cells are up and running in the background on localhost with default port xxx. And this step, you will be configuring Apache2 as a reverse proxy for your Pydio Cells application. Also, you will generate new SSL/TLS certificates for your domain name, so be sure that you’ve prepared the domain name and pointed to the server IP address.
First, execute the a2enmod command below to enable some Apache2 extensions that will be used as a reverse proxy.
sudo a2enmod rewrite proxy proxy_http proxy_wstunnel http2 proxy_http2
Then run the following command to create a new directory /var/www/html/cells/public_html and change the ownership to www-data user. This directory will be used for the verification when generating Letsencrypt certificates.
sudo mkdir -p /var/www/html/cells/public_html
sudo chown -R www-data:www-data /var/www/html/cells/public_html
After that, run the certbot command below to generate new SSL/TLS certificates for your Pydio Cells domain name. Be sure to change the email address and the domain name with your information.
sudo certbot certonly --agree-tos --email [email protected] --no-eff-email --webroot -w /var/www/html/cells/public_html -d cells.hwdomain.io
When the process is complete, your SSL/TLS certificates will be available at the /etc/letsencrypt/live/domain.com directory.
Next, create a new Apache2 virtual host configuration /etc/apache2/sites-available/cells.conf using the following nano editor command.
sudo nano /etc/apache2/sites-available/cells.conf
Insert the following configuration and be sure to change the domain name and the path of SSL/TLS certificates with your information.
    ServerName cells.hwdomain.io
    RewriteEngine On
    RewriteCond %{HTTPS} off
    RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
    RewriteCond %{SERVER_NAME} =cells.hwdomain.io
    RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]</VirtualHost>
<VirtualHost *:443>
    AllowEncodedSlashes On
    RewriteEngine On
    # be aware of this
    # Allow reverse proxy via self-signed certificates
    SSLProxyEngine On
    SSLProxyVerify none
    SSLProxyCheckPeerCN off
    SSLProxyCheckPeerName off
    SSLProxyCheckPeerExpire off
    ## The order of the directives matters.
    # If Cells is not running with https, consider using ws instead of wss
    ProxyPassMatch "/ws/(.*)" wss://localhost:8080/ws/$1 nocanon
    ## This rewrite condition is required if using Cells-Sync
    # RewriteCond %{HTTP:Content-Type} =application/grpc [NC]    # RewriteRule /(.*) h2://localhost:8080/$1 [P,L]
    ProxyPass "/" "https://127.0.0.1:8080/"
    ProxyPassReverse "/" "https://127.0.0.1:8080/"
    SSLCertificateFile /etc/letsencrypt/live/cells.hwdomain.io/fullchain.pem
    SSLCertificateKeyFile /etc/letsencrypt/live/cells.hwdomain.io/privkey.pem
    #Include /etc/letsencrypt/options-ssl-apache.conf
Now run the command below to activate the virtual host file cells.conf and verify Apache syntax for error. If you have proper Apache2 syntax, you should get an output Syntax OK.
sudo a2ensite cells.conf
sudo apachectl configtest
Lastly, run the following systemctl command to restart the apache2 service and apply the changes. With this, your Pydio Cells should be accessible via a secure HTTPS connection of Apache2 reverse proxy.
Accessing Pydio Cells Installation
Launch your web browser and visit the domain name of the Pydio Cells installation, such as https://cells.hwdomain.io/. If everything goes well, you should be redirected to the Pydio Cells login page.
Input the admin user and password that you’ve created during the configuration process, then click Enter.
login to pydio
If successful, you should see the Pydio Cells user dashboard like this:
pydio dashboard
Click on the Personal Files workspace and you should get the Pydio Cells file manager. Click the New button and upload a new file to ensure that you can upload files to Pydio Cells.
test upload
Following this guide, you’ve installed Pydio Cells on the Debian 12 server. You’ve installed Pydio Cells with MariaDB database server and Apache2 reverse proxy, and on top of that, you’ve also secured your Pydio Cells installation with SSL/TLS certificates generated from Letsencrypt. From here, you can now use Pydio Cells for your document and file management, collaboration, and sharing.
