How to Install PowerDNS and PowerDNS-Admin on Ubuntu 22.04
PowerDNS is a free and open-source authoritative nameserver written in C++. It is cross-platform and can run on Unix, Linux, and macOS operating systems. It supports several databases such as MySQL, MariaDB, PostgreSQL, and Oracle to store zone files and records.
PowerDNS Admin is a web-based application that can be used for managing PowerDNS via a web browser. It allows you to create and manage DNS zones using the PowerDNS web interface. It offers very useful features, including IPv4 and IPv6 support, bulk domain, DNSSec support, AD, LDAP, SAML authentication, and more.
In this post, we will explain how to install PowerDNS and PowerDNS admin on Ubuntu 22.04 server.
Install and Configure MariaDB Server
First, you will need to install the MariaDB database server on your system.
apt-get install mariadb-server -y
Once the MariaDB has been installed, you will need to create a database and user for PowerDNS.
First, login to MariaDB with the following command:
mysql
Once login, create a database and user with the following command:
MariaDB [(none)]> create database pdns;
MariaDB [(none)]> grant all on pdns.* to pdnsadmin@localhost identified by 'password';
MariaDB [(none)]> exit;
Install PowerDNS
Before starting, you will need to disable the systemd-resolved service from your system. You can disable it with the following command:
systemctl disable --now systemd-resolved
Next, remove the default resolv.conf file and create a new file:
rm -rf /etc/resolv.conf
echo "nameserver 8.8.8.8" > /etc/resolv.conf
Next, install the PowerDNS server with the following command:
apt-get install pdns-server pdns-backend-mysql -y
Once the PowerDNS is installed, you can proceed to the next step.
Configure PowerDNS
First, import the PowerDNS database schema to the PowerDNS database with the following command:
mysql -u pdnsadmin -p pdns < /usr/share/pdns-backend-mysql/schema/schema.mysql.sql
Next, you will need to create a PowerDNS configuration file and define the PowerDNS database connection details:
nano /etc/powerdns/pdns.d/pdns.local.gmysql.conf
# MySQL Configuration
# Launch gmysql backend
launch+=gmysql
# gmysql parameters
gmysql-host=127.0.0.1
gmysql-port=3306
gmysql-dbname=pdns
gmysql-user=pdnsadmin
gmysql-password=password
gmysql-dnssec=yes
# gmysql-socket=
Save and close the file, then set proper permission to the file pdns.local.gmysql.conf:
chmod 640 /etc/powerdns/pdns.d/pdns.local.gmysql.conf
chown pdns:pdns /etc/powerdns/pdns.d/pdns.local.gmysql.conf
Next, stop the PowerDNS server and test the PowerDNS with the following command:
systemctl stop pdns
pdns_server --daemon=no --guardian=no --loglevel=9
Aug 06 10:43:47 gmysql Connection successful. Connected to database 'pdns' on '127.0.0.1'.
Aug 06 10:43:47 Done launching threads, ready to distribute questions
Next, start the PowerDNS server with the following command:
systemctl start pdns
You can now check the status of the PowerDNS using the following command:
systemctl status pdns
? pdns.service - PowerDNS Authoritative Server
Loaded: loaded (/lib/systemd/system/pdns.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2022-08-06 10:37:28 UTC; 8s ago
Docs: man:pdns_server(1)
man:pdns_control(1)
https://doc.powerdns.com
Main PID: 93982 (pdns_server)
Tasks: 8 (limit: 2242)
Memory: 43.1M
CPU: 166ms
CGroup: /system.slice/pdns.service
??93982 /usr/sbin/pdns_server --guardian=no --daemon=no --disable-syslog --log-timestamp=no --write-pid=no
Aug 06 10:37:28 ubuntu2204 pdns_server[93982]: UDP server bound to [::]:53
Aug 06 10:37:28 ubuntu2204 pdns_server[93982]: TCP server bound to 0.0.0.0:53
Aug 06 10:37:28 ubuntu2204 pdns_server[93982]: TCP server bound to [::]:53
Aug 06 10:37:28 ubuntu2204 pdns_server[93982]: PowerDNS Authoritative Server 4.5.3 (C) 2001-2021 PowerDNS.COM BV
Aug 06 10:37:28 ubuntu2204 pdns_server[93982]: Using 64-bits mode. Built using gcc 11.2.0.
Aug 06 10:37:28 ubuntu2204 pdns_server[93982]: PowerDNS comes with ABSOLUTELY NO WARRANTY. This is free software, and you are welcome to redi>
Aug 06 10:37:28 ubuntu2204 pdns_server[93982]: Creating backend connection for TCP
Aug 06 10:37:28 ubuntu2204 systemd[1]: Started PowerDNS Authoritative Server.
Aug 06 10:37:28 ubuntu2204 pdns_server[93982]: About to create 3 backend threads for UDP
Aug 06 10:37:29 ubuntu2204 pdns_server[93982]: Done launching threads, ready to distribute questions
At this point, PowerDNS is started and listening on port 53. You can check it with the following command:
ss -alnp4 | grep pdns
udp UNCONN 0 0 0.0.0.0:53 0.0.0.0:* users:(("pdns_server",pid=93982,fd=5))
tcp LISTEN 0 128 0.0.0.0:53 0.0.0.0:* users:(("pdns_server",pid=93982,fd=7))
Install PowerDNS Admin
In this section, we will show you how to install PowerDNS admin with Nginx.
Install Required Dependencies
First, install all the dependencies required for PowerDNS admin with the following command:
apt-get install nginx python3-dev libsasl2-dev libldap2-dev libssl-dev libxml2-dev libxslt1-dev libxmlsec1-dev libffi-dev pkg-config apt-transport-https virtualenv build-essential libmariadb-dev git python3-flask libpq-dev -y
Once all the dependencies are installed, add the Node.js repository with the following command:
curl -sL https://deb.nodesource.com/setup_16.x | bash -
Next, install the Node.js with the following command:
apt-get install nodejs -y
Next, add the yarn repository with the following command:
curl -sS https://dl.yarnpkg.com/debian/pubkey.gpg | apt-key add -
echo "deb https://dl.yarnpkg.com/debian/ stable main" | tee /etc/apt/sources.list.d/yarn.list
Next, update the repository and install Yarn with the following command:
apt-get install yarn -y
At this point, all the required dependencies are installed, you can now proceed to the next step.
Download PowerDNS Admin
Next, download the latest version of PowerDNS admin from the Git repository to the Nginx root directory:
git clone https://github.com/ngoduykhanh/PowerDNS-Admin.git /var/www/html/pdns
Next, change the directory to the downloaded directory and create a Python virtual environment with the following command:
cd /var/www/html/pdns/
virtualenv -p python3 flask
Next, activate the virtual environment and install all Python dependencies with the following command:
source ./flask/bin/activate
pip install -r requirements.txt
Next, deactivate the Virtual environment with the following command:
deactivate
Configure Database Connection
Next, you will need to define the PowerDNS database connection details to the default_config.py file:
nano /var/www/html/pdns/powerdnsadmin/default_config.py
Change the following lines:
SALT = 'yoursecretekey'
SECRET_KEY = 'yoursecretekey'
BIND_ADDRESS = '0.0.0.0'
PORT = 9191
HSTS_ENABLED = False
OFFLINE_MODE = False
SQLA_DB_USER = 'pdnsadmin'
SQLA_DB_PASSWORD = 'password'
SQLA_DB_HOST = '127.0.0.1'
SQLA_DB_NAME = 'pdns'
SQLALCHEMY_TRACK_MODIFICATIONS = True
Save and close the file, then change the directory to the pdns and activate the virtual environment:
Next, update the database with the following command:
export FLASK_APP=powerdnsadmin/__init__.py
flask db upgrade
yarn install --pure-lockfile
flask assets build
Next, deactivate the virtual environment with the following command:
deactivate
Enable PowerDNS Admin API
PowerDNS admin uses JSON API for reading statistics and modifying zone content, metadata, and DNSSEC key material. You can enable it by editing the file pdns.conf:
nano /etc/powerdns/pdns.conf
api=yes
api-key=yoursecretekey
Save and close the file, then restart the PowerDNS service to apply the changes:
systemctl restart pdns
Configure Nginx as a Reverse Proxy for PowerDNS Admin
Next, you will need to configure the Nginx as a reverse proxy for the PowerDNS admin. To do so, create an Nginx virtual host configuration file with the following command:
nano /etc/nginx/conf.d/pdns-admin.conf
listen *:80;
server_name pdnsadmin.example.com;
index index.html index.htm index.php;
root /var/www/html/pdns;
access_log /var/log/nginx/pdnsadmin_access.log combined;
error_log /var/log/nginx/pdnsadmin_error.log;
client_max_body_size 10m;
client_body_buffer_size 128k;
proxy_redirect off;
proxy_connect_timeout 90;
proxy_send_timeout 90;
proxy_read_timeout 90;
proxy_buffers 32 4k;
proxy_buffer_size 8k;
proxy_set_header Host $host;
proxy_headers_hash_bucket_size 64;
location ~ ^/static/ {
include /etc/nginx/mime.types;
root /var/www/html/pdns/powerdnsadmin;
location ~* .(jpg|jpeg|png|gif)$ {
expires 365d;
location ~* ^.+.(css|js)$ {
expires 7d;
proxy_pass http://unix:/run/pdnsadmin/socket;
proxy_read_timeout 120;
proxy_connect_timeout 120;
proxy_redirect off;
Save and close the file, then check the Nginx for any syntax error with the following command:
nginx -t
Next, change the ownership of the pdns to www-data:
chown -R www-data:www-data /var/www/html/pdns
systemctl restart nginx
Create a Systemd Service File for PowerDNS Admin
Next, you will need to create a systemd service file to manage the PowerDNS service.
First, create a pdns service file with the following command:
nano /etc/systemd/system/pdnsadmin.service
[Unit]
Description=PowerDNS-Admin
Requires=pdnsadmin.socket
After=network.target
User=pdns
Group=pdns
WorkingDirectory=/var/www/html/pdns
ExecStart=/var/www/html/pdns/flask/bin/gunicorn --pid /run/pdnsadmin/pid --bind unix:/run/pdnsadmin/socket 'powerdnsadmin:create_app()'
ExecReload=/bin/kill -s HUP $MAINPID
ExecStop=/bin/kill -s TERM $MAINPID
PrivateTmp=true [Install] WantedBy=multi-user.target
Save and close the file, then create a pdnsadmin sockt file with the following command:
nano /etc/systemd/system/pdnsadmin.socket
[Unit]
Description=PowerDNS-Admin socket
Save and close the file, then create the required files and directories with the following command:
echo "d /run/pdnsadmin 0755 pdns pdns -" >> /etc/tmpfiles.d/pdnsadmin.conf
mkdir /run/pdnsadmin/
chown -R pdns: /run/pdnsadmin/
chown -R pdns: /var/www/html/pdns/powerdnsadmin/
Next, reload the systemd daemon with the following command:
systemctl daemon-reload
Next, enable the pdnsadmin service to start at system reboot with the following command:
systemctl enable --now pdnsadmin.service pdnsadmin.socket
Next, verify the status of both service using the following command:
systemctl status pdnsadmin.service pdnsadmin.socket
? pdnsadmin.service - PowerDNS-Admin
Loaded: loaded (/etc/systemd/system/pdnsadmin.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2022-08-06 10:52:44 UTC; 9s ago
TriggeredBy: ? pdnsadmin.socket
Main PID: 98696 (gunicorn)
Tasks: 2 (limit: 2242)
Memory: 63.1M
CPU: 913ms
CGroup: /system.slice/pdnsadmin.service
??98696 /var/www/html/pdns/flask/bin/python /var/www/html/pdns/flask/bin/gunicorn --pid /run/pdnsadmin/pid --bind unix:/run/pdns>
??98697 /var/www/html/pdns/flask/bin/python /var/www/html/pdns/flask/bin/gunicorn --pid /run/pdnsadmin/pid --bind unix:/run/pdns>
Aug 06 10:52:44 ubuntu2204 systemd[1]: Started PowerDNS-Admin.
Aug 06 10:52:44 ubuntu2204 gunicorn[98696]: [2022-08-06 10:52:44 +0000] [98696] [INFO] Starting gunicorn 20.0.4
Aug 06 10:52:44 ubuntu2204 gunicorn[98696]: [2022-08-06 10:52:44 +0000] [98696] [INFO] Listening at: unix:/run/pdnsadmin/socket (98696)
Aug 06 10:52:44 ubuntu2204 gunicorn[98696]: [2022-08-06 10:52:44 +0000] [98696] [INFO] Using worker: sync
Aug 06 10:52:44 ubuntu2204 gunicorn[98697]: [2022-08-06 10:52:44 +0000] [98697] [INFO] Booting worker with pid: 98697
? pdnsadmin.socket - PowerDNS-Admin socket
Loaded: loaded (/etc/systemd/system/pdnsadmin.socket; enabled; vendor preset: enabled)
Triggers: ? pdnsadmin.service
Listen: /run/pdnsadmin/socket (Stream)
CGroup: /system.slice/pdnsadmin.socket
Aug 06 10:52:44 ubuntu2204 systemd[1]: Listening on PowerDNS-Admin socket.
Access PowerDNS Admin
You can now open your web browser and access the PowerDNS admin web interface using the URL http://pdnsadmin.example.com. You will be redirected to the following page:
Click on the Create an account button. You should see the following screen:
Provide your admin user details and click on the Register button to create an account. You should see the PowerDNS admin web interface on the following screen:
Provide the PowerDNS API URL to connect to PowerDNS and manage it. Then, click on the Update button to save the changes. You should see the following page:
Click on the Dashboard button. You should see the PowerDNS admin dashboard on the following screen:
Congratulations! you have successfully installed and configured PowerDNS and PowerDNS admin with Nginx on Ubuntu 22.04 server. You can now create zones and add records through the PowerDNS admin web interface then test it. Feel free to ask me if you have any questions
