How to Install phpMyAdmin with Nginx and Let’s Encrypt SSL on Ubuntu 20.04 LTS
phpMyAdmin is a free and open-source application that can be used to manage MySQL and MariaDB database through a web-based interface. With phpMyAdmin, you can perform several tasks including, manage user accounts and privileges, import and export data, execute SQL-statements, and much more. It comes with a wide range of documentation that helps you to perform various operations.
In this tutorial, we will explain how to install phpMyAdmin with Nginx on Ubuntu 20.04 and secure it with a free Let’s Encrypt SSL Certificate.
- A valid domain name pointed with your server.
Install Nginx, MariaDB and PHP
First, you will need to install the Nginx web server, MariaDB, PHP and other required PHP extensions in your server. You can install all of them with the following command:
googletag.cmd.push(function() { googletag.display(‘div-gpt-ad-1527185271042-6’); });
apt-get install nginx mariadb-server php php-cli php-mysql php-mbstring php-zip php-gd php-json php-curl php-fpm -y
Install phpMyAdmin
By default, phpMyAdmin package is available in the Ubuntu 20.04 default repository. You can install it by just running the following command:
apt-get install phpmyadmin -y
During the installation, you will be asked to select the web server as shown below:
Since we are using the Nginx web server, you can just hit TAB, and then ENTER to bypass this prompt. You will be asked to configure a database for phpMyAdmin to use.
Select Yes and hit Enter to continue. You will be asked to choose and confirm a password for the phpMyAdmin application as shown below:
Provide your desired password and hit Enter to finish the installation.
Configure MariaDB Database
By default, the MariaDB is not secured. So secure the MariaDB and set the MariaDB root password with the following command:
mysql_secure_installation
Set root password? [Y/n] Y
New password:
Re-enter new password:
After securing the MariaDB, it is recommended to create a separate user to connect the phpMyAdmin and manage the database.
To do so, log in to the MariaDB shell with the following command:
mysql -u root -p
Provide your root password when prompt then create a new user with the following command:
MariaDB [(none)]> create user admin@localhost identified by 'password';
Next, grant all the privileges to the user with the following command:
MariaDB [(none)]> grant all privileges on *.* to admin@localhost with grant option;
Next, flush the privileges and exit from the MariaDB shell using the following command:
MariaDB [(none)]> exit;
Configure Nginx for phpMyAdmin
You can create a new Nginx virtual host configuration file for phpMyAdmin using the following command:
nano /etc/nginx/sites-available/phpmyadmin
listen [::]:80;
server_name phpmyadmin.linuxbuz.com;
root /usr/share/phpmyadmin/;
index index.php index.html index.htm index.nginx-debian.html;
access_log /var/log/nginx/phpmyadmin_access.log;
error_log /var/log/nginx/phpmyadmin_error.log;
try_files $uri $uri/ /index.php;
location ~ ^/(doc|sql|setup)/ {
deny all;
location ~ .php$ {
fastcgi_pass unix:/run/php/php7.4-fpm.sock;
include fastcgi_params;
location ~ /.ht {
deny all;
Save and close the file when you are finished. Then, create a symbolic link to the /etc/nginx/sites-enabled/ directory:
ln -s /etc/nginx/sites-available/phpmyadmin /etc/nginx/sites-enabled/
Next, set the hash_bucket_size in Nginx default configuration file:
nano /etc/nginx/nginx.conf
Add the following line below the line “http {“:
Save and close the file. Then, check the Nginx for any syntax error with the following command:
nginx -t
systemctl restart nginx
You can also check the status of the Nginx service with the following command:
systemctl status nginx
Active: active (running) since Fri 2020-05-15 06:24:03 UTC; 2s ago
Docs: man:nginx(8)
Process: 107736 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 107737 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Main PID: 107738 (nginx)
Tasks: 3 (limit: 2282)
Memory: 3.7M
??107738 nginx: master process /usr/sbin/nginx -g daemon on; master_process on;
??107739 nginx: worker process
??107740 nginx: worker process
May 15 06:24:03 ubuntu2004 systemd[1]: Starting A high performance web server and a reverse proxy server...
May 15 06:24:03 ubuntu2004 systemd[1]: Started A high performance web server and a reverse proxy server.
Secure phpMyAdmin with Let’s Encrypt SSL
Before starting, you will need to install the Certbot client to download and install Let’s Encrypt SSL.
First, add the Certbot repository with the following command:
add-apt-repository ppa:ahasenack/certbot-tlssni01-1875471
Next, update the repository and install the Certbot client using the following command:
apt-get install certbot python3-certbot-nginx -y
Once the Certbot has been installed, run the following command to download and install the Let’s Encrypt SSL for your domain:
certbot --nginx -d phpmyadmin.linuxbuz.com
You will be asked to provide your email and accept the term of service as shown below:
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for phpmyadmin.linuxbuz.com
Waiting for verification...
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/nginx/sites-enabled/phpmyadmin
Next, select whether or not to redirect HTTP traffic to HTTPS:
Type 2 and hit Enter to finish the installation.
Redirecting all traffic on port 80 to ssl in /etc/nginx/sites-enabled/phpmyadmin
Congratulations! You have successfully enabled https://phpmyadmin.linuxbuz.com
https://www.ssllabs.com/ssltest/analyze.html?d=phpmyadmin.linuxbuz.com
IMPORTANT NOTES:
/etc/letsencrypt/live/phpmyadmin.linuxbuz.com/fullchain.pem
/etc/letsencrypt/live/phpmyadmin.linuxbuz.com/privkey.pem
Your cert will expire on 2020-08-12. To obtain a new or tweaked
Access phpMyAdmin
Now, open your web browser and type the URL https://phpmyadmin.linuxbuz.com. You will be redirected to the phpMyAdmin login page:
Provide your admin username, password, and click on the Go button. You should see the phpMyAdmin default dashboard in the following page:
Congratulations! you have successfully installed phpMyAdmin and secure it with Let’s Encrypt SSL on Ubuntu 20.04. You can now interact with MariaDB and perform several tasks through the web browser.
