How to Install Phorum with Nginx on CentOS 7
Phorum is a PHP and MySQL based Open Source forum software. In this guide, we will guide you step-by-step through the Phorum installation process on the CentOS 7 operating system using Nginx as the web server, MariaDB as the database, and acme.sh and Let’s Encrypt for HTTPS.
Requirements for running Phorum are:
- Nginx
- PHP version 5.2 or greater
- MySQL/MariaDB version 5.0 or greater
- A CentOS 7 operating system.
- A non-root user with
sudoprivileges.
Initial steps
Check your CentOS version:
cat /etc/centos-release
# CentOS Linux release 7.6.1810 (Core)
Set up the timezone:
timedatectl list-timezones
sudo yum update -y
Install some essential packages that are necessary for basic administration of the CentOS operating system:
sudo yum install -y curl wget vim git unzip socat bash-completion epel-release
Step 1 – Install PHP
sudo yum install -y php php-cli php-fpm php-common php-mysql
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.2.10-0ubuntu0.18.04.1 (cli) (built: Sep 13 2018 13:45:02) ( NTS )
# with Zend OPcache v7.2.10-0ubuntu0.18.04.1, Copyright (c) 1999-2018, by Zend Technologies
Step 2 – Install MariaDB and create a database
Install MariaDB database server:
sudo yum install -y mariadb-server
Check the MariaDB version:
mysql --version
Start and enable MariaDB service:
Run mysql_secure installation script to improve MariaDB security and set the password for MariaDB root user:
Answer each of the questions:
Would you like to setup VALIDATE PASSWORD plugin? N
Re-enter new password: your_secure_password
Connect to MariaDB shell as the root user:
sudo mysql -u root -p
# Enter password
Create an empty MariaDB database and user and remember the credentials:
MariaDB> CREATE DATABASE dbname;
MariaDB> GRANT ALL ON dbname.* TO 'username' IDENTIFIED BY 'password';
MariaDB> FLUSH PRIVILEGES;
Exit from MariaDB:
MariaDB> exit
Step 3 – Install acme.sh client and obtain Let’s Encrypt certificate (optional)
Securing your forum with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain TLS certificate from Let’s Encrypt we will use acme.sh client. Acme.sh is a pure UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
./acme.sh --install --accountemail [email protected]
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.0
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging flag to the above commands.
- For RSA:
/home/username/example.comdirectory. - For ECC/ECDSA:
/home/username/example.com_eccdirectory.
acme.sh --list
Create a directory to store your certs. We will use /etc/letsencrypt directory.
mkdir -p /etc/letsecnrypt/example.comsudo mkdir -p /etc/letsencrypt/example.com_ecc
# RSA
# ECC/ECDSA
exit
Step 4 – Install and configure NGINX
Install NGINX:
sudo yum install -y nginx
Check the NGINX version:
sudo nginx -v
# nginx version: nginx/1.12.2
Start and enable Nginx service:
Configure NGINX for Phorum. Run sudo vim /etc/nginx/conf.d/phorum.conf and add the following configuration.
listen 443 ssl;
server_name example.com;
root /var/www/phorum;
index index.php index.html;
location ~ .php$ {
try_files $fastcgi_script_name =404;
set $path_info $fastcgi_path_info;
fastcgi_param PATH_INFO $path_info;
fastcgi_index index.php;
include fastcgi.conf;
fastcgi_pass 127.0.0.1:9000;
sudo nginx -t
Reload NGINX service:
Step 4 – Install Phorum
Create a document root directory for Phorum:
sudo mkdir -p /var/www/phorum
Change ownership of the /var/www/phorum directory to [jour_user]:
sudo chown -R [your_user]:[your_user] /var/www/phorum
cd /var/www/phorum
Download the latest stable Phorum distribution from the official website:
wget https://www.phorum.org/downloads/phorum-5.2.23.tar.gz
Unpack the downloaded archive and move files to the document root:
tar xvzf phorum-5.2.23.tar.gz
rm phorum-5.2.23.tar.gz
mv Core-phorum_5_2_23/* . && mv Core-phorum_5_2_23/.* .
rmdir Core-phorum_5_2_23
Configure the database access:
cp include/db/config.php.sample include/db/config.php
Configure database settings by editing include/db/config.php file:
vim include/db/config.php
Change the ownership of the /var/www/phorum directory to nginx:
sudo chown -R nginx:nginx /var/www/phorum
Run sudo vim /etc/php-fpm.d/www.conf and set user and group to nginx:
# user = nginx
# group = nginx
Restart PHP-FPM service:
To finish the installation, run the web-based installer by visiting http://forum.example.com/admin.php in your web browser.
