How to Install OSClass with Nginx on Ubuntu 18.04 LTS
OSClass is a free and open source PHP script that can be used to create your own classifieds site. It is used by thousands of users for creating job listings, sales listing, real estate, and other similar listing websites. OSClass provides lots of features like built-in plugins, themes, multi-language, CAPTCHA, dashboard, SEO friendly and many more.
In this tutorial, we will learn how to install OSClass on Ubuntu 18.04 server.
  • A root password is setup to your server.
apt-get upgrade -y
Install LEMP Server
Before starting, you will need to install Nginx, MariaDB, PHP and other required packages to your server. You can install all of them with the following command:
apt-get install nginx mariadb-server php7.2 php7.2-cli php7.2-fpm php7.2-common php7.2-mysql php7.2-gd php7.2-xml unzip -y
Once all the packages are installed, start Nginx and MariaDB service and enable them to start on boot time with the following command:
systemctl start nginx
systemctl start mariadb
systemctl enable nginx
systemctl enable mariadb
Configure Database for OSClass
By default, MariaDB is not secured. So, you will need to secure it. You can do this by running the mysql_secure_installation script:
Set root password? [Y/n]: N
Once the MariaDB is secured, log in to MariaDB shell with the following command:
mysql -u root -p
Enter your root password when prompt. Then, create a database and user for OSClass using the following command:
MariaDB [(none)]> CREATE DATABASE osclassdb;
MariaDB [(none)]> GRANT ALL PRIVILEGES ON osclassdb.* TO 'osclass'@'localhost' IDENTIFIED BY 'password';
MariaDB [(none)]> EXIT;
Once your database is configured, you can proceed to the next step.
Install OSClass
First, you will need to download the latest version of OSClass from their website. You can download it with the following command:
wget https://static.osclass.org/download/osclass.3.8.0.zip
Once the download is completed, extract the downloaded file to the Nginx root directory with the following command:
unzip osclass.3.8.0.zip -d /var/www/html/osclass
Next, change the directory to osclass and copy sample config file with the following command:
cd /var/www/html/osclass
cp config-sample.php config.php
Next, open config.php file and define your database settings:
nano config.php
Make the following changes:
* The base MySQL settings of Osclass
define('MULTISITE', 0);
/** MySQL database name for Osclass */
define('DB_NAME', 'osclassdb');
/** MySQL database username */
define('DB_USER', 'osclass');
/** MySQL database password */
define('DB_PASSWORD', 'password');
/** MySQL hostname */
define('DB_HOST', 'localhost');
/** Database Table prefix */
define('DB_TABLE_PREFIX', 'oc_');
define('REL_WEB_URL', 'rel_here');
define('WEB_PATH', 'http://localhost');
Save and close the file. Then, give proper permissions to the osclass directory with the following command:
chown -R www-data:www-data /var/www/html/osclass
chmod -R 755 /var/www/html/osclass
Configure Nginx for OSClass
Next, you will need to create an Nginx virtual host file for OSClass. You can create it with the following command:
nano /etc/nginx/sites-available/osclass.conf
listen [::]:80;
server_name example.com;
root /var/www/html/osclass;
index index.php index.html;
location ~ .php$ {
fastcgi_pass unix:/var/run/php/php7.2-fpm.sock; # Check this
Save and close the file, when you are finished. Then, enable Nginx virtual host file with the following command:
ln -s /etc/nginx/sites-available/osclass.conf /etc/nginx/sites-enabled/
Next, check Nginx for any configuration error with the following command:
nginx -t
Next, restart Nginx service to apply all the changes with the following command:
systemctl restart nginx
You can also verify the Nginx service with the following command:
systemctl status nginx
Active: active (running) since Thu 2019-03-28 15:19:49 UTC; 22min ago
Docs: man:nginx(8)
Main PID: 15044 (nginx)
Tasks: 2 (limit: 1113)
??15044 nginx: master process /usr/sbin/nginx -g daemon on; master_process on;
??15050 nginx: worker process
Mar 28 15:19:49 ubuntu1804 systemd[1]: Starting A high performance web server and a reverse proxy server...
Mar 28 15:19:49 ubuntu1804 systemd[1]: nginx.service: Failed to parse PID from file /run/nginx.pid: Invalid argument
Mar 28 15:19:49 ubuntu1804 systemd[1]: Started A high performance web server and a reverse proxy server.
Once Nginx has been configured, you can proceed to the next step.
Access OSClass Web Interface
Start OSClass installation
Now, click on the Install button. You should see the following page:
Prerequisites are met
Make sure all the required dependencies have been installed, then click on the Run the install button. You should see the following page:
Database connection
Now, provide your database details like database name, username, and password. Then, click on the Next button. you should see the following page:
Set admin user details
Now, provide your admin username and password, Web title and email address. Then, click on the Next button. You should see the following page:
Installation overview
Now, click on the Finish and go to the administration panel button. You should see the following page:
Login to OSClass admin dashboard
Now, provide your admin username and password. Then, click on the login button. You should see the OSClass default dashboard in the following page:
OSClass Dashboard
OSClass has been successfully installed.
