How to Install OpenNMS Horizon Network Monitoring System on Debian 11
OpenNMS is a free, open-source, and one of the most powerful network monitoring and network management platforms used for monitoring remote devices from a central location. It supports many functionalities including, Provisioning, Services Monitoring, Event managing, chart support, and more. OpenNMS uses SNMP and JMX and gathers information from remote systems. It runs on Linux and Windows operating systems and provides a web-based interface to easy monitoring.
In this tutorial, I will show you how to install OpenNMS on Debian 11.
  • A server running Debian 11.
Install Java on Debian 11
OpenNMS is a Java-based application. So Java must be installed on your server. If not installed you can install it by running the following command:
apt-get install default-jdk -y
Once the Java is installed, verify the Java version using the command below:
java --version
You will get the Java version in the following output:
openjdk 11.0.13 2021-10-19
OpenJDK Runtime Environment (build 11.0.13+8-post-Debian-1deb11u1)
OpenJDK 64-Bit Server VM (build 11.0.13+8-post-Debian-1deb11u1, mixed mode, sharing)
Install OpenNMS on Debian 11
By default, OpenNMS is not included in the Debian 11 main repository. So you will need to add the OpenNMS official repository to the APT.
First, install all the required dependencies using the following command:
apt-get install curl gnupg2 wget -y
Once all the packages are installed, create an OpenNMS repository file using the command below:
nano /etc/apt/sources.list.d/opennms.list
deb https://debian.opennms.org stable main
deb-src https://debian.opennms.org stable main
Save and close the file then import the GPG key with the following command:
wget -O - https://debian.opennms.org/OPENNMS-GPG-KEY | apt-key add -
Connecting to debian.opennms.org (debian.opennms.org)|3.214.84.83|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1335 (1.3K)
Saving to: ‘STDOUT’
- 100%[=================================================================>] 1.30K --.-KB/s in 0s
2021-11-28 07:58:07 (16.0 MB/s) - written to stdout [1335/1335]
OK
Next, update the repository cache and install the OpenNMS with the following command:
apt-get install opennms -y
You will get the following error during the installation:
Failed to install iplike into the template1 or opennms databases. See /tmp/install_iplike.log for details. To skip this step and install manually, set the
environment variable SKIP_IPLIKE_INSTALL before installing this package. To install iplike into your database, use the /usr/sbin/install_iplike.sh script. See
`install_iplike.sh -h` for more details.
To resolve this error, you will need to create a database and user for OpenNMS in PostgreSQL.
Create a Database in PostgreSQL
PostgreSQL server installed automatically during the OpenNMS installation process.
First, start the PostgreSQL service using the following command:
systemctl start postgresql
Next, connect to the PostgreSQL instance using the following command:
su - postgres
Once you are connected, create a user for OpenNMS and set a password using the following command:
createuser opennms
psql -c "ALTER USER opennms WITH PASSWORD 'opennms';"
Next, create a database for OpenNMS and set a password for postgres user:
createdb -O opennms opennms
psql -c "ALTER USER postgres WITH PASSWORD 'securepassword';"
Next, exit from the PostgreSQL shell with the following command:
exit
Configure OpenNMS
Next, you will need to edit the OpenNMS data source file and define your database credentials:
nano /usr/share/opennms/etc/opennms-datasources.xml
Define your database credentials as shown below:
<jdbc-data-source name="opennms"
database-name="opennms"
class-name="org.postgresql.Driver"
url="jdbc:postgresql://localhost:5432/opennms"
user-name="opennms"
password="opennms" />
<jdbc-data-source name="opennms-admin"
database-name="template1"
url="jdbc:postgresql://localhost:5432/template1"
user-name="postgres"
password="securepassword" />
</datasource-configuration>
Save and close the file when you are finished then run the following command to detect of Java environment:
sudo -u opennms /usr/share/opennms/bin/runjava -s
runjava: Looking for an appropriate JVM...
runjava: Checking for an appropriate JVM in JAVA_HOME...
runjava: Skipping... JAVA_HOME not set.
runjava: Checking JVM in the PATH: "/etc/alternatives/java"...
runjava: Did not find an appropriate JVM in the PATH: "/etc/alternatives/java"
runjava: Searching for a good JVM...
runjava: Found a good JVM in "/usr/lib/jvm/java-11-openjdk-amd64/bin/java".
runjava: Value of "/usr/lib/jvm/java-11-openjdk-amd64/bin/java" stored in configuration file.
Next, run the following command to complete the OpenNMS setup:
sudo -u opennms /usr/share/opennms/bin/install -dis
Finished in 0 seconds
Processing RemotePollerServiceConfigMigratorOffline: Remove deprecated RemotePoller service entry from service-configuration.xml, see NMS-12684
- Running pre-execution phase
Creating backup of /usr/share/opennms/etc/service-configuration.xml
Zipping /usr/share/opennms/etc/service-configuration.xml
- Running execution phase
Current configuration: 32 services.
A service entry named 'OpenNMS:Name=PerspectivePoller' already exists.
Final configuration: 32 services.
- Saving the execution state
- Running post-execution phase
Removing backup /usr/share/opennms/etc/service-configuration.xml.zip
Upgrade completed successfully!
Start OpenNMS Service
After setting up OpenNMS, start the OpenNMS service and enable it to start at system reboot using the following command:
systemctl start opennms
systemctl enable opennms
You can verify the OpenNMS status using the following command:
systemctl status opennms
? opennms.service - OpenNMS server
Loaded: loaded (/lib/systemd/system/opennms.service; disabled; vendor preset: enabled)
Active: active (running) since Sun 2021-11-28 08:10:51 UTC; 16s ago
Process: 22990 ExecStart=/usr/share/opennms/bin/opennms -s start (code=exited, status=0/SUCCESS)
Main PID: 24106 (java)
Tasks: 68 (limit: 4679)
Memory: 559.2M
CPU: 48.083s
CGroup: /system.slice/opennms.service
??24105 bash /usr/share/opennms/bin/opennms -s start
??24106 /usr/lib/jvm/java-11-openjdk-amd64/bin/java --add-modules=java.base,java.compiler,java.datatransfer,java.desktop,java.in>
Nov 28 08:11:02 debian11 opennms[24106]: [DEBUG] System property 'opennms.library.jicmp' set to '/usr/lib/jni/libjicmp.so. Attempting to loa>
Nov 28 08:11:02 debian11 opennms[24106]: [INFO] Successfully loaded jicmp library.
Nov 28 08:11:02 debian11 opennms[24106]: [DEBUG] System property 'opennms.library.jicmp6' set to '/usr/lib/jni/libjicmp6.so. Attempting to l>
Nov 28 08:11:02 debian11 opennms[24106]: [INFO] Successfully loaded jicmp6 library.
Nov 28 08:11:07 debian11 opennms[24106]: Nov 28, 2021 8:11:07 AM org.hibernate.validator.internal.util.Version
Nov 28 08:11:07 debian11 opennms[24106]: INFO: HV000001: Hibernate Validator 4.3.2.Final
At this point, OpenNMS is started and listens on port 8980. You can check it with the following command:
ss -antpl | grep 8980
LISTEN 0 50 *:8980 *:* users:(("java",pid=24106,fd=1046))
Configure Nginx as a Reverse Proxy for OpenNMS
Next, it is recommended to install and configure the Nginx as a reverse proxy for OpenNMS. First, install the Nginx server with the following command:
apt-get install nginx -y
Once the Nginx is installed, create an Nginx virtual host configuration file:
nano /etc/nginx/conf.d/opennms.conf
Add the following configuration:
server_name opennms.example.com;
access_log /var/log/nginx/opennms.access.log;
error_log /var/log/nginx/opennms.error.log;
location /
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header X-OpenNMS-Server-URL https://nms.hacc.edu/;
proxy_pass http://server-ip:8980;
Save and close the file then verify the Nginx for any syntax configuration error:
nginx -t
Next, restart the Nginx service to apply the changes:
systemctl restart nginx
To check the Nginx running status, run the following command:
systemctl status nginx
Active: active (running) since Sun 2021-11-28 08:17:14 UTC; 6s ago
Docs: man:nginx(8)
Process: 25964 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 25965 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Main PID: 25967 (nginx)
Tasks: 3 (limit: 4679)
Memory: 3.2M
CPU: 53ms
??25967 nginx: master process /usr/sbin/nginx -g daemon on; master_process on;
??25968 nginx: worker process
??25969 nginx: worker process
Nov 28 08:17:14 debian11 systemd[1]: Starting A high performance web server and a reverse proxy server...
Nov 28 08:17:14 debian11 systemd[1]: Started A high performance web server and a reverse proxy server.
Access OpenNMS Dashboard
Now, open your web browser and access the OpenNMS web interface using the URL http://opennms.example.com. You should see the OpenNMS login page:
OpenNMS Horizon
Provide default username and password as admin and click on the Login button. You should see the OpenNMS dashboard on the following screen:
Horizon Dashboard
Now, click on the admin > Change Password to change the default admin password as shown below:
Change password
Change your default password and click on the Submit button. You should see the following screen:
Password changed
Congratulations! you have successfully installed OpenNMS with Nginx as a reverse proxy on Debian 11 server. You can now add the remote devices to OpenNMS and start monitoring them from the web browser. Feel free to ask me if you have any questions.
