Node.js is an open-source cross-platform JavaScript (JS) runtime environment. It is used for building fast and scalable network applications. In addition to offering various JS modules, it is also lightweight, efficient and supports consistent and integrated development.
Node Package Manager (NPM) is Node’s official package manager, used for installing and managing package dependencies.
In this tutorial, learn three (3) different options for installing Node.js and NPM on Ubuntu 18.04 or Ubuntu 20.04.
Note: The process of updating Node.js is similar to installing, but with a few minor differences. To find out more, read How to Update Node.js on Linux.
- Ubuntu 18.04 or 20.04
- A user with sudo privileges. Read this to create a sudo user on Ubuntu
- Access to a terminal/command line
3 Ways to Install Node.js and NPM on Ubuntu
Below you will find instructions on how to install Node.js and NPM on Ubuntu using the Ubuntu repository, NVM, and NodeSource repository.
Option 1: Install Node.js and NPM from Ubuntu Repository
The easiest way to install Node.js and NPM is from the Ubuntu repository.
First, update the cache repository to ensure you install the latest versions of Node.js and NPM.
1. Type the command:
2. Then, install Node.js with the command:
sudo apt install nodejs
3. Confirm that the installation was successful by checking the available version:
nodejs -v
4. Install the Node.js package manager (npm):
sudo apt install npm
5. Verify the installed version:
npm -v
Option 2: Install Node.js and NPM with NVM
Another way to install Node.js and NPM is with the Node Version Manager (NVM). NVM is a tool practical for managing multiple Node.js versions.
1. To install NVM, download the installation script from GitHub. For that, you use the curl command line.
If you do not have curl, install it by running:
sudo apt install curl
Press y to confirm the installation and hit Enter.
2. Now, download the NVM installation script with the command:
curl -o- https://raw.githubusercontent.com/creationix/nvm/v0.33.11/install.sh | bash
Note: This command downloads the script for NVM version 0.33.11. Check out the NVM GitHub page to find the latest stable version and replace the section v0.33.11 in the command with the wanted release.
After it automatically clones the NVM repository and adds the NVM path to ZSH or Bash, you receive the following output:
3. Then, source the bash file by running:
source ~/.bashrc
4. Check whether the installation was successful by verifying nvm version:
nvm --version
5. Once you have installed nvm, you can find a list of all the available Node.js versions with the command:
nvm ls-remote
This lists all available versions of Node.js, including the latest LTS version, like in the image below:
Note: LTS stands for long-term support and is used for software that is maintained for an extended period and is recommended as being the most stable.
6. To install a particular version, use the command nvm install and add the number of the version. For example:
nvm install 10.15.2
To view all installed versions on your manager, use the command:
nvm ls
This lists all installed Node.js versions as well as the default and stable versions.
To check which version you are currently using, run the command:
node -v
To switch versions of Node.js (if you have already installed it on the NVM) enter the command:
nvm use 8.11.1
Option 3: Install Node.js from NodeSource Repository
Alternatively, you may want to install Node.js and NPM from the NodeSource repository by adding its PPA (Personal Package Archive) for Ubuntu.
To enable the NodeSource repository, you have to use a curl command.
1. If you do not have curl on your system, run the following command to install it:
2. Now use the following sudo bash script to enable NodeSource:
curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
To install another version, replace setup_12.x with the wanted version.
3. Next, install both Node.js and NPM with one command:
4. Verify the installation by checking the versions of Node.js and NPM.
Run the commands:
nodejs --version
npm –version
If npm is not recognized or not installed properly, the terminal will print npm: command not found.
Note: When installing NodeSource, it is necessary to specify which version of Node.js you will install. In the example above, the Node.js version is 10, but other versions are also available.
Installing Development Tools
Once you have Node.js and NPM setup, install the development tools. This automation tool kit allows compiling and installing native add-ons from the NPM.
To install development tools run the command:
sudo apt install build-essential
Remove Or Uninstall Node.js on Ubuntu
To remove a specific version of Node.js, run the nvm uninstall command appended by the version number.
For example, to uninstall version 8.11.1 run the command:
nvm uninstall 8.11.1
To uninstall Node.js, but keep its configuration files, type:
sudo apt remove nodejs
To uninstall Node.js and remove any of its configuration files, use the command:
sudo apt purge nodejs
Note: Learn how to build a Node.js app with Docker.
In this tutorial, you learned how to install Node.js and NPM on Ubuntu. We also covered how to remove or uninstall Node.js, and how to install development tools.
