How to Install Nextcloud with Apache and Let’s Encrypt SSL on Ubuntu 22.04 LTS
Nextcloud is a free and open-source, file sharing and syncing solution that helps you to store your personal documents, files, photos, and other in a central location. It is very similar to other cloud storage solutions like Dropbox, Google Drive, iCloud, etc. You should switch to NextCloud if you are worried about privacy because you can install Nextcloud on your own server. You can upload files and other docs to your Nextcloud server and then sync all of them to your desktop pc, laptop, or smartphone.
In this tutorial, we will show you how to install Nextcloud on Ubuntu 22.04 server.
- A valid domain name pointed to the server IP.
Install Apache, PHP, and MariaDB
Before starting, LAMP stack must be installed on your server. If not installed, you can install it with the following command:
apt install apache2 mariadb-server php php-cli php-fpm php-json php-intl php-imagick php-pdo php-mysql php-zip php-gd php-mbstring php-curl php-xml php-pear php-bcmath apache2 libapache2-mod-php -y
After installing all packages, edit the PHP configuration file and change some default settings:
nano /etc/php/8.1/apache2/php.ini
Change the following lines:
date.timezone = UTC
memory_limit = 512M
upload_max_filesize = 500M
post_max_size = 500M
max_execution_time = 300
Save and close the file then restart the Apache service to apply the changes:
systemctl restart apache2
Create a Database for Nextcloud
Nextcloud uses a MariaDB database as a database backend so you will need to create a database and user in MariaDB.
First, connect to the MariaDB shell with the following command:
mysql
Once you are connected to the MariaDB, create a database and user with the following command:
CREATE DATABASE nextcloud;
CREATE USER 'nextcloud'@'localhost' identified by 'password';
Next, grant all the privileges to the Nextcloud database with the following command:
GRANT ALL PRIVILEGES ON nextcloud.* TO 'nextcloud'@'localhost';
FLUSH PRIVILEGES;
QUIT;
Download Nextcloud
At the time of writing the article, the latest version of Nextcloud is 24.0.1. You can download it with the following command:
wget https://download.nextcloud.com/server/releases/nextcloud-24.0.1.zip
unzip nextcloud-24.0.1.zip
Next, move the extracted directory to the Apache web root with the following command:
mv nextcloud /var/www/html/
Next, change the ownership and permission of the Nextcloud directory using the following command:
chown -R www-data:www-data /var/www/html/nextcloud
chmod -R 775 /var/www/html/nextcloud
Create an Apache Virtual Host for Nextcloud
Next, you will need to create an Apache virtual host configuration file for Nextcloud. You can create it with the following command:
nano /etc/apache2/sites-available/next.conf
ServerAdmin [email protected]
DocumentRoot /var/www/html/nextcloud
ServerName next.example.com
ErrorLog /var/log/apache2/nextcloud-error.log
CustomLog /var/log/apache2/nextcloud-access.log combined
<Directory /var/www/html/nextcloud>
Options +FollowSymlinks
Require all granted
SetEnv HOME /var/www/html/nextcloud
SetEnv HTTP_HOME /var/www/html/nextcloud
<IfModule mod_dav.c>
Dav off
</IfModule>
Save and close the file then activate the Apache virtual host and other required Apache modules with the following command:
a2ensite next
a2enmod rewrite dir mime env headers
Next, restart the Apache service to apply the changes:
You can also check the status of the Apache with the following command:
systemctl status apache2
You will get the Apache status in the following output:
Active: active (running) since Fri 2022-06-17 15:04:27 UTC; 4s ago
Process: 16746 ExecStart=/usr/sbin/apachectl start (code=exited, status=0/SUCCESS)
Main PID: 16750 (apache2)
Tasks: 6 (limit: 2292)
Memory: 14.7M
CPU: 98ms
??16750 /usr/sbin/apache2 -k start
??16751 /usr/sbin/apache2 -k start
??16752 /usr/sbin/apache2 -k start
??16753 /usr/sbin/apache2 -k start
??16754 /usr/sbin/apache2 -k start
??16755 /usr/sbin/apache2 -k start
Jun 17 15:04:27 ubuntu2204 systemd[1]: Starting The Apache HTTP Server...
Access Nextcloud Web Interface
Now, open your web browser and access the Nextcloud web UI using the URL http://next.example.com. You should see the following screen:
Define your admin username, password, database, and click on the Install button. Once the Nextcloud is installed, you should see the following screen:
Click on the Install recommended apps to install all required applications. You should see the following screen:
Click on the All files. You should see the Nextcloud storage manager on the following screen:
Click on the Your photos. You should see the Nextcloud photo manager on the following screen:
Enable SSL on Nextcloud
It is also recommended to enable SSL on the Nextcloud domain for secure communication. First, install the Certbot package with the following command:
apt-get install python3-certbot-apache -y
Once installed, run the following command to secure your website with Let’s Encrypt SSL:
certbot --apache -d next.example.com
You will be asked to provide your email and accept the term of service as shown below:
Plugins selected: Authenticator standalone, Installer None
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for next.example.com
Enabled Apache rewrite module
Waiting for verification...
Cleaning up challenges
Created an SSL vhost at /etc/apache2/sites-available/next-le-ssl.conf
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Deploying Certificate to VirtualHost /etc/apache2/sites-available/next-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/next-le-ssl.conf
Next, select whether or not to redirect HTTP traffic to HTTPS as shown below:
Type 2 and hit Enter to install the Let’s Encrypt SSL for your website:
Redirecting vhost in /etc/apache2/sites-enabled/next.conf to ssl vhost in /etc/apache2/sites-available/next-le-ssl.conf
Congratulations! You have successfully enabled https://next.example.com
https://www.ssllabs.com/ssltest/analyze.html?d=next.example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/next.example.com/fullchain.pem
/etc/letsencrypt/live/next.example.com/privkey.pem
Your cert will expire on 2022-09-21. To obtain a new or tweaked
Congratulations! you have successfully installed Nextcloud with Apache and Let’s Encrypt SSL on Ubuntu 22.04. You can now upload your files, docs, and photos, and sync them with your computer, laptop, and mobile devices.
