How to Install Moodle with Nginx and Let’s Encrypt SSL on Ubuntu 20.04
Moodle is a free and open-source Learning Management System written in PHP. It provides a way for tutors and instructors to create courses for their students or learners. Moodle provides a robust and secure integrated system and comes with a custom dashboard that helps users to access current, past or future courses, as well as review pending work. It is used by many schools, universities, and organizations across the globe and provides a better learning experience. It provides a rich set of features including, wiki, grading, assignment submission, online quizzes, discussion boards, and more.
In this tutorial, we will show you how to install Moodle with Nginx web server and Let’s Encrypt SSL on Ubuntu 20.04.
Before starting, you will need to update your system packages to the latest version. You can update them using the following command:
Once your server is updated, you can proceed to the next step.
Install LEMP
First, you will need to install the Apache, MariaDB, PHP and other PHP libraries to your system. You can install all of them using the following command:
apt-get install nginx mariadb-server php-fpm php-common php-mysql php-gmp php-curl php-intl php-mbstring php-soap php-xmlrpc php-gd php-xml php-cli php-zip unzip git curl -y
Once all the packages are installed, edit the php.ini file and change some settings:
nano /etc/php/7.4/fpm/php.ini
Change the following lines:
memory_limit = 256M
cgi.fix_pathinfo = 0
upload_max_filesize = 100M
max_execution_time = 360
date.timezone = America/Chicago
Save and close the file then restart the PHP-FPM service to apply the changes:
systemctl restart php7.4-fpm
Create a Database
Moodle uses a MySQL or MariaDB as a database backend so you will need to create a database and user for Moodle.
First, connect to the MySQL shell with the following command:
mysql
Once login, create a database and user with the following command:
CREATE DATABASE moodledb;
CREATE USER 'moodle'@'localhost' IDENTIFIED BY 'password';
Next, grant all the privileges to the Moodle database with the following command:
GRANT ALL ON moodledb.* TO 'moodle'@'localhost' WITH GRANT OPTION;
Next, flush the privileges and exit from the MySQL with the following command:
FLUSH PRIVILEGES;
EXIT;
Next, edit the MariaDB default configuration file and define the innodb_file_format:
Add the following lines inside the [mysqld] section:
[mysqld]
innodb_file_format = Barracuda
innodb_file_per_table = 1
innodb_large_prefix = ON
Save the file then restart the MariaDB service to apply the changes:
systemctl restart mariadb
Install Moodle
First, change the directory to the Apache root directory and download the latest version of the Moodle with the following command:
cd /var/www/html
git clone -b MOODLE_38_STABLE git://git.moodle.org/moodle.git moodle
Once the download is completed, edit the Moodle config.php and define the database type:
nano /var/www/html/moodle/config.php
Find the following line:
$CFG->dbtype = 'mysqli';
And, replaced it with the following line:
$CFG->dbtype = 'mariadb';
Save and close the file then create a Moodle data directory set proper ownership and permission with the following command:
mkdir -p /var/www/html/moodledata
chown -R www-data:www-data /var/www/html/moodle
chmod -R 755 /var/www/html/*
chown www-data:www-data /var/www/html/moodledata
Configure Nginx for Moodle
Next, you will need to create an Nginx virtual host configuration file to host Moodle:
nano /etc/nginx/conf.d/moodle.conf
root /var/www/html/moodle;
server_name moodle.example.com;
client_max_body_size 100M;
autoindex off;
try_files $uri $uri/ =404;
location /dataroot/ {
internal;
alias /var/www/html/moodledata/;
location ~ [^/].php(/|$) {
fastcgi_pass unix:/run/php/php7.4-fpm.sock;
include fastcgi_params;
Save and close the file then verify the Nginx for any syntax error with the following command:
nginx -t
systemctl restart nginx
At this point, Nginx is configured to host Moodle. You can now proceed to the next step.
Access Moodle Web Interface
Now, open your web browser and access the Moodle web interface using the URL http://moodle.example.com. You should see the Moodle installation page:
Select your language and click on the Next. You should see the following page:
Provide your Moodle web address, directory path, data directory path and click on the Next. You should see the following page:
Select your database driver type and click on the Next. You should see the following page:
Provide your database host, database name, username, password and click on the Next. You should see the following page:
Click on the Continue to confirm all conditions. You should see the following page:
Makesure all required PHP extensions are installed then click on the Continue. You should see the following page:
Click on the Continue. You should see the following page:
Provide your admin username, password, email, country, timezone, and click on the Update profile. You should see the following page:
Provide your front page settings and click on the Save changes button to save the changes.
Secure Moodle with Let’s Encrypt SSL
Next, you will need to install the Certbot tool to download Let’s Encrypt SSL and configure Nginx to use this SSL.
First, install the Certbot with the following command:
apt-get install python3-certbot-nginx -y
Once installed, run the following command to download all SSL and configure Nginx to use it:
certbot --nginx -d moodle.example.com
You will be asked to provide a valid email address and accept the term of service as shown below:
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for moodle.example.com
Waiting for verification...
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/nginx/conf.d/moodle.conf
Next, choose whether or not to redirect HTTP traffic to HTTPS as shown below:
Type 2 and hit Enter to continue. You should see the following output:
Redirecting all traffic on port 80 to ssl in /etc/nginx/conf.d/moodle.conf
Congratulations! You have successfully enabled https://moodle.example.com
https://www.ssllabs.com/ssltest/analyze.html?d=moodle.example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/moodle.example.com/fullchain.pem
/etc/letsencrypt/live/moodle.example.com/privkey.pem
Your cert will expire on 2021-05-23. To obtain a new or tweaked
- We were unable to subscribe you the EFF mailing list because your
e-mail address appears to be invalid. You can try again later by
visiting https://act.eff.org.
You can now access the Moodle website using the URL http://moodle.example.com
Congratulations! you have successfully installed Moodle with Nginx and Let’s Encrypt SSL on Ubuntu 20.04. You can now create your own Learning Management System with Moodle easily.
