How to Install MERN Stack for JS based applications on Debian 11
MERN stack consists of four key technologies MongoDB, Express, React, and Node. It is specially designed for easier and faster deployment of full-stack web applications. It is one of the most popular and user-friendly development structures that helps you to improve your applications to a great extent. The MERN stack allows you to build a 3-tier architecture (frontend, backend, database) entirely using JavaScript and JSON.
In this tutorial, we will show you how to install the MERN stack on Debian 11.
- A server running Debian 11.
Before starting, it is recommended to update your system’s package cache to the latest version. You can update it using the following command:
After updating the package cache, install other required dependencies using the following command:
apt-get install gnupg2 curl -y
Once all the required dependencies are installed, you can proceed to the next step.
Installing MongoDB Server
MongoDB is a NoSql and object-oriented database technology used in large data storage. By default, MongoDB is not included in the Debian 11 default repository. So you will need to add the MongoDB repository to APT.
First, download and add the MongoDB GPG key with the following command:
wget -qO - https://www.mongodb.org/static/pgp/server-4.4.asc | apt-key add -
Next, add the MongoDB repository to APT with the following command:
echo "deb http://repo.mongodb.org/apt/debian buster/mongodb-org/4.4 main" | tee /etc/apt/sources.list.d/mongodb-org-4.list
Next, update the repository and install the MongoDB server package using the following command:
apt-get install mongodb-org -y
After the installation, start the MongoDB service and enable it to start at system reboot.
systemctl start mongod
systemctl enable mongod
You can verify the MongoDB version using the following command:
mongod --version
db version v4.4.8
Build Info: {
"version": "4.4.8",
"gitVersion": "83b8bb8b6b325d8d8d3dfd2ad9f744bdad7d6ca0",
"openSSLVersion": "OpenSSL 1.1.1k 25 Mar 2021",
"modules": [],
"allocator": "tcmalloc",
"environment": {
"distmod": "debian10",
"distarch": "x86_64",
"target_arch": "x86_64"
After installing MongoDB, you can proceed to install Node.js.
Installing Node.js
Node.js allows you to run JavaScript on the server-side and outside of the browser. It uses an event-driven model that makes it lightweight for applications that run across distributed devices.
To install the latest version of Node.js, you will need to add the NodeSource repository to your system.
curl -sL https://deb.nodesource.com/setup_16.x | bash -
Once the repository is installed, run the following command to install the Node.js version 16 to your system:
apt-get install nodejs -y
Once the installation is completed, verify the Node.js version with the following command:
node --version
v16.8.0
Installing React.JS
React is an open-source JavaScript library and used to develop front-end web applications. It allows you to make reusable components for a single-page user interface.
You can install the create-react-app tool using the NPM as shown below:
npm install -g create-react-app
After the installation, create a React app with the following command:
create-react-app reactapp
Success! Created reactapp at /root/reactapp
Inside that directory, you can run several commands:
npm start
Starts the development server.
npm run build
Bundles the app into static files for production.
npm test
Starts the test runner.
npm run eject
Removes this tool and copies build dependencies, configuration files
and scripts into the app directory. If you do this, you can’t go back!
We suggest that you begin by typing:
cd reactapp
npm start
Happy hacking!
Now, change the directory to reactapp and start the application using the following command:
cd reactapp
npm start 0.0.0.0
> [email protected] start
> react-scripts start "0.0.0.0"
Compiled successfully!
You can now view reactapp in the browser.
http://localhost:3000
Note that the development build is not optimized.
To create a production build, use npm run build.
Now, open your web browser and test your React application using the URL http://your-server-ip:3000. You should see the React default page:
Press CTRL+C to stop the application.
Installing Express
Express is a Node.js framework used for the rapid development of node-based web applications.
You can install it using the NPM command as shown below:
npm install -g express-generator
After the installation, create an Express application with the following command:
express mearnapp
create : mearnapp/
create : mearnapp/public/
create : mearnapp/public/javascripts/
create : mearnapp/public/images/
create : mearnapp/public/stylesheets/
create : mearnapp/public/stylesheets/style.css
create : mearnapp/routes/
create : mearnapp/routes/index.js
create : mearnapp/routes/users.js
create : mearnapp/views/
create : mearnapp/views/error.jade
create : mearnapp/views/index.jade
create : mearnapp/views/layout.jade
create : mearnapp/app.js
create : mearnapp/package.json
create : mearnapp/bin/
create : mearnapp/bin/www
change directory:
$ cd mearnapp
install dependencies:
$ npm install
run the app:
$ DEBUG=mearnapp:* npm start
Now, change the directory to your application directory and install all application dependencies using the following command:
cd mearnapp
npm install
Next, start the application using the following command:
npm start 0.0.0.0
> node ./bin/www "0.0.0.0"
Now, open your web browser and access your Express application using the URL http://your-server-ip:3000. You should see the following page:
In the above guide, you learned how to install the MERN stack on Debian 11. You can now use this framework for the rapid development of web and mobile applications.
