How to Install MediaWiki with Nginx and Let’s Encrypt SSL on Ubuntu 20.04
MediaWiki is an open-source wiki software written in PHP. It allows you to create your own self-hosted wiki website on the server. It is one of the most popular wiki platforms due to its simplicity and customizability. Currently, it is used by many companies to manage their wiki pages. It provides a versatile and free tool for publishing content on the internet.
In this tutorial, we will show you how to install MediaWiki with Nginx web server and Let’s Encrypt SSL on Ubuntu 20.04.
First, update the system packages to the updated version by running the following command:
Install Nginx, MariaDB and PHP
MediaWiki requires Nginx web server, MariaDB database server, PHP, and other extensions. You can install all of them with the following command:
apt-get install nginx mariadb-server php php-fpm php-mbstring php-xml php-json php-mysql php-curl php-intl php-gd php-mbstring texlive imagemagick unzip -y
Once all the packages are installed, install the Composer with the following command:
apt-get install composer -y
Next, edit the php.ini file and change the default settings:
nano /etc/php/7.4/fpm/php.ini
Change the following lines:
memory_limit = 512M
post_max_size =32M
upload_max_filesize = 32M
date.timezone = Asia/Kolkata
Save and close the file then restart the PHP-FPM to apply the changes:
systemctl restart php7.4-fpm
Create a MariaDB Database
MediaWiki uses MariaDB as a database backend so you will need to create a database and user for MediaWiki.
First, connect to the MariaDB with the following command:
mysql
Once you are connected, create a database and user with the following command:
MariaDB [(none)]> CREATE DATABASE mediadb;
MariaDB [(none)]> GRANT ALL PRIVILEGES ON mediadb.* TO 'mediauser'@'localhost' IDENTIFIED BY 'password';
MariaDB [(none)]> EXIT;
Download MediaWiki
First. go to the MediaWiki website and pick the latest version of the MediaWiki. Then, run the following command to download it to your server:
wget https://releases.wikimedia.org/mediawiki/1.35/mediawiki-1.35.2.zip
unzip mediawiki-1.35.2.zip
Next, move the extracted directory to the Nginx web root directory with the following command:
mv mediawiki-1.35.2 /var/www/html/mediawiki
Next, change the directory to the MediaWiki and install all PHP dependencies with the following command:
cd /var/www/html/mediawiki
composer install --no-dev
Once all the dependencies are installed, set proper permission and ownership with the following command:
chown -R www-data:www-data /var/www/html/mediawiki
chmod -R 755 /var/www/html/mediawiki
Configure Nginx for MediaWiki
Next, you will need to create an Nginx virtual host configuration file for MediaWiki. You can create it with the following command:
nano /etc/nginx/conf.d/wiki.conf
server_name wiki.example.com;
root /var/www/html/mediawiki;
index index.php;
error_log /var/log/nginx/mediawiki.error;
access_log /var/log/nginx/mediawiki.access;
try_files $uri $uri/ /index.php;
location ~ /.ht {
deny all;
location ~ .php$ {
fastcgi_pass unix:/run/php/php7.4-fpm.sock;
include fastcgi_params;
Save and close the file then verify the Nginx for any syntax error with the following command:
nginx -t
Next, restart the Nginx service to apply the changes:
systemctl restart nginx
You can also verify the status of the Nginx with the following command:
systemctl status nginx
Active: active (running) since Wed 2021-06-02 05:06:48 UTC; 3s ago
Docs: man:nginx(8)
Process: 24594 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 24605 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Main PID: 24606 (nginx)
Tasks: 2 (limit: 2353)
Memory: 2.8M
??24606 nginx: master process /usr/sbin/nginx -g daemon on; master_process on;
??24607 nginx: worker process
Jun 02 05:06:48 ubuntu2004 systemd[1]: Starting A high performance web server and a reverse proxy server...
Jun 02 05:06:48 ubuntu2004 systemd[1]: Started A high performance web server and a reverse proxy server.
Access MediaWiki Web UI
Now, open your web browser and type the URL http://wiki.example.com. You will be redirected to the following page:
Now, click on the set up the wiki button. You should see the following page:
Here, choose your wiki language and click on the Continue button. You should see the following page:
Now, click on the Continue button. You should see the following page:
Now, provide your database details and click on the Continue button. You should see the following page:
Select use the same account as for installation and click on the Continue button. You should see the following page:
Now, provide your wiki site name, username, and password. Then, click on the Continue button. You should see the following page:
Click on the Continue button to start the installation. You should see the following page:
Click on the Continue button. Once the installation is finished, you should see the following page:
Now, click on the download button to download the LocalSettings.php file to your system. Then, copy this file to your server inside the MediaWiki root directory and set proper permission with the following command:
chown www-data:www-data /var/www/html/mediawiki/LocalSettings.php
Next, go back to your web browser and click on enter your wiki. You should see the MediaWiki dashboard on the following page:
Secure MediaWiki with Let’s Encrypt SSL
Next, you will need to install the Certbot client package to install the manage the Let’s Encrypt SSL.
First, install the Certbot with the following command:
apt-get install python3-certbot-nginx -y
Once the installation is finished, run the following command to install the Let’s Encrypt SSL on your website:
certbot --nginx -d wiki.example.com
You will be asked to provide a valid email address and accept the term of service as shown below:
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for wiki.example.com
Waiting for verification...
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/nginx/conf.d/wiki.conf
Next, choose whether or not to redirect HTTP traffic to HTTPS as shown bellow:
Type 2 and hit Enter to finish the installation. You should see the following output:
Redirecting all traffic on port 80 to ssl in /etc/nginx/conf.d/wiki.conf
Congratulations! You have successfully enabled https://wiki.example.com
https://www.ssllabs.com/ssltest/analyze.html?d=wiki.example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/wiki.example.com/fullchain.pem
/etc/letsencrypt/live/wiki.example.com/privkey.pem
Your cert will expire on 2021-12-30. To obtain a new or tweaked
- We were unable to subscribe you the EFF mailing list because your
e-mail address appears to be invalid. You can try again later by
visiting https://act.eff.org.
Now, your website is secured with Let’s Encrypt SSL. You can access it securely using the URL https://wiki.example.com.
Congratulations! you have successfully installed MediaWiki with Nginx and Let’s Encrypt SSL on Ubuntu 20.04. You can now easily host your own wiki site with MediaWiki.
