How to Install Matomo (Piwik) Web Analytics on CentOS 8
JS Tracking code for Piwik
Matomo formerly known as Piwik is an open-source analytics application for the Linux operating system. It is very similar to Google Analytics that helps you to tracks and display the location of user visits. It was developed by a team of international developers that runs on a PHP/MySQL webserver. It offers a lot of features, some of them are listed below:
  • Flexibility, Reliability & security
  • Self-hosted, Simple, and easy to use
  • 100% Data Ownership
  • GDPR compliance
  • Web and mobile analytics
In this tutorial, we will show you how to install and setup Piwik analytics application on CentOS 8 server.
  • A server running CentOS 8.
Install LAMP Server
Piwik runs on a LAMP server so you will need to install the Apache, MariaDB, PHP and other PHP extensions to your system. You can install all of them with the following command:
dnf install httpd mariadb-server php php-mysqlnd php-fpm unzip wget php-json php-dom php-gd php-mbstring -y
Once all the packages are installed, edit the php.ini file and set some desired values:
nano /etc/php.ini
Change the following values:
upload_max_filesize = 10M
post_max_size = 10M
max_execution_time = 300
max_input_time = 300
memory_limit = 256M
Save and close the file then start the Apache and MariaDB service and enable them to start at system reboot:
systemctl start mariadb
systemctl start httpd
systemctl enable mariadb
systemctl enable httpd
Create a Database for Piwik
Next, you will need to create a database and user for Piwik. First, login to MariaDB with the following command:
mysql
Once login, create a database and user with the following command:
mysql> CREATE DATABASE matomo;
mysql> CREATE USER `matomo`@`localhost` IDENTIFIED BY 'password';
Next, grant all the privileges to the database with the following command:
mysql> GRANT ALL ON matomo.* TO `matomo`@`localhost`;
mysql> FLUSH PRIVILEGES;
mysql> EXIT;
Install Piwik
Next, you will need to download the latest version of Piwik from their official website. First, chnage the directory to the Apache web root with the following command:
cd /var/www/html
Next, download the Piwik using the following command:
wget https://builds.matomo.org/matomo-latest.zip
unzip matomo-latest.zip
Next, set proper permission and ownership to the web root with the following command:
chown -R apache:apache /var/www/html/matomo
chmod -R 775 /var/www/html/matomo
Next, you will need to allow port 80 and 443 through the firewall. You can allow them with the following command:
firewall-cmd --permanent --zone=public --add-service=http
firewall-cmd --permanent --zone=public --add-service=https
Next, reload the firewalld to apply the changes:
firewall-cmd --reload
Next, you will also need to setup SELinux for Piwik. You can setup it with the following command:
chcon -R -t httpd_sys_rw_content_t /var/www/html/matomo/
setsebool httpd_can_network_connect on -P
Configure Apache for Piwik
Next, you will need to configure the Apache web server to host Piwik website. You can do it by creating a new Apache virtual host configuration file:
nano /etc/httpd/conf.d/piwik.conf
DocumentRoot "/var/www/html/matomo"
ServerName piwik.example.com
<Directory "/var/www/html/matomo/">
Options MultiViews FollowSymlinks
Order allow,deny
Allow from all
TransferLog /var/log/httpd/matomo_access.log
ErrorLog /var/log/httpd/matomo_error.log
Save and close the file when you are finished. Then, restart the Apache web server to apply the changes:
systemctl restart httpd
You can now check the status of the Apache with the following command:
systemctl status httpd
? httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; disabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/httpd.service.d
??php-fpm.conf
Active: active (running) since Sun 2020-12-27 05:38:29 EST; 5s ago
Docs: man:httpd.service(8)
Main PID: 4228 (httpd)
Status: "Started, listening on: port 80"
Tasks: 213 (limit: 12523)
Memory: 36.8M
CGroup: /system.slice/httpd.service
??4228 /usr/sbin/httpd -DFOREGROUND
??4229 /usr/sbin/httpd -DFOREGROUND
??4230 /usr/sbin/httpd -DFOREGROUND
??4231 /usr/sbin/httpd -DFOREGROUND
??4232 /usr/sbin/httpd -DFOREGROUND
Dec 27 05:38:28 centos8 systemd[1]: Stopped The Apache HTTP Server.
Dec 27 05:38:28 centos8 systemd[1]: Starting The Apache HTTP Server...
Access Piwik Web Interface
Now, open your web browser and access the Piwik web interface using the URL http://piwik.example.com. You will be redirected to the following page:
Piwik Installer
Click on the NEXT, you should see the system check page:
System check
Click on the NEXT, you should see the database setup page:
Database setup
Provide yur database username, database name, password and click on the NEXT, you should see the following page:
Creating database tables
Click on the NEXT, you should see the admin user creation page:
Add admin user account
Provide your admin username, password, email then click on the NEXT. You should see the website setup page:
Setup a website
Provide your website details and click on the NEXT. You should see the your tracking code in the following page:
Log analytics
Click on the NEXT. Once the installation has been finished. You should see the following page:
Installation finished
Click on the CONTINUE TO MATOMO. You should see the MATOMO login page:
Matomo Login
Provide your admin username, password and click on the SIGN IN. You should see the MATOMO dashboard in the following page:
Statistics dashboard
Secure Matomo with Let’s Encrypt SSL
Next, you will need to install the Certbot utility in your system to download and install Let’s Encrypt SSL for your Piwik website.
You can install the Certbot client with the following command:
Next, obtain and install an SSL certificate for your Mantis website with the following command:
certbot-auto --apache -d piwik.example.com
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for piwik.example.com
Waiting for verification...
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/httpd/conf.d/piwik.conf
Next, you will need to choose whether or not to redirect HTTP traffic to HTTPS as shown below:
Type 2 and hit Enter to continue. Once the installation has been finished, you should see the following output:
Redirecting all traffic on port 80 to ssl in /etc/httpd/conf.d/piwik.conf
Congratulations! You have successfully enabled https://piwik.example.com
https://www.ssllabs.com/ssltest/analyze.html?d=piwik.example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/piwik.example.com/fullchain.pem
/etc/letsencrypt/live/piwik.example.com/privkey.pem
Your cert will expire on 2020-03-23. To obtain a new or tweaked
At this point, your website is secured with Let’s Encrypt SSL.
Conclusion Congratulations! you have successfully installed and setup Piwik with Apache and Let’s Encrypt SSL on CentOS 8. You can now add your tracking code in your website and start monitoring your website visitors from the Piwik dashboard. Feel free to ask me if you have any question.
