How to Install Jira Agile Project Management Tool on Ubuntu 20.04
JIRA is a project management tool developed by Atlassian which is used as an issue and bug-tracking system. It is a commercial tool and available as a Trial version for a limited time. You can use JIRA in Support and Customer Services to create tickets and track the status of the created tickets. It comes with a simple and user-friendly dashboard that helps you to track work progress and issues. It offers a rich set of features including, Bugs and defect management, Advanced reporting, Search and filtering, Customizable workflows, Customizable dashboards, Advanced security and administration and many more.
In this tutorial, we will show you how to install JIRA project management tool on Ubuntu 20.04 server.
  • A server running Ubuntu 20.04 with minimum 4GB of RAM.
First, it is recommended to update your system with the latest version. You can update them using the following command:
Once all the packages are updated, install other required packages with the following command:
apt-get install unzip fontconfig -y
Install and Configure MariaDB Database
JIRA uses MySQL/MariaDB to store their data. So you will need to install the MariaDB server in your server. You can install it with the following command:
apt-get install mariadb-server -y
Once the installation has been finished, log in to the MariaDB shell with the following command:
mysql
Once login, create a database and user for JIRA with the following command:
MariaDB [(none)]> CREATE DATABASE jiradb CHARACTER SET utf8mb4 COLLATE utf8mb4_bin;
MariaDB [(none)]> CREATE USER 'jirauser'@'localhost' IDENTIFIED BY 'password';
Next, grant all the privileges to the jiradb with the following command:
MariaDB [(none)]> GRANT ALL ON jiradb.* TO 'jirauser'@'localhost' WITH GRANT OPTION;
MariaDB [(none)]> FLUSH PRIVILEGES; MariaDB [(none)]> EXIT;
Next, edit the MariaDB default configuration file and tweak some settings for better performance.
Add the following lines inside [mysqld]:
default-storage-engine= INNODB
character_set_server = utf8mb4
innodb_default_row_format = DYNAMIC
innodb_large_prefix = ON
innodb_file_format = Barracuda
innodb_log_file_size = 2G
sql_mode = NO_AUTO_VALUE_ON_ZERO
Save and close the file when you are finished. Then, restart the MariaDB service to apply the changes:
systemctl restart mariadb.service
Install JIRA
First, you will need to download the latest version of JIRA from their official website. You can download it with the wget command as shown below:
wget https://www.atlassian.com/software/jira/downloads/binary/atlassian-jira-software-8.7.1-x64.bin
Once the download is completed, change the permission of the downloaded file with the following command:
chmod a+x atlassian-jira-software-8.11.0-x64.bin
Next, install the JIRA software by running the downloaded binary as shown below:
./atlassian-jira-software-8.11.0-x64.bin
This will install Jira Software 8.11.0 on your computer.
OK [o, Enter], Cancel
Press Enter to continue. You should see the following output:
Click Next to continue, or Cancel to exit Setup.
Choose the appropriate installation or upgrade option.
Please choose one of the following:
Express Install (use default settings) [1], Custom Install (recommended for advanced users) [2, Enter], Upgrade an existing Jira installation [3] 2
Type 2 and hit Enter for custom install. You should see the following output:
Select the folder where you would like Jira Software to be installed.
Where should Jira Software be installed?
[/opt/atlassian/jira]
Select the Jira installation path and hit Enter. You should see the following output:
Default location for Jira Software data
[/var/atlassian/application-data/jira]
Now, press Enter to continue. You should see the following output:
Configure which ports Jira Software will use.
Jira requires two TCP ports that are not being used by any other
applications on this machine. The HTTP port is where you will access Jira
through your browser. The Control port is used to startup and shutdown Jira.
Use default ports (HTTP: 8080, Control: 8005) - Recommended [1, Enter], Set custom value for HTTP and Control ports [2] 1
Type 1 and hit Enter to use default HTTP port. You should see the following output:
Jira can be run in the background.
You may choose to run Jira as a service, which means it will start
automatically whenever the computer restarts.
Install Jira as Service?
Yes [y, Enter], No [n] y
Type y and hit Enter to install Jira as a Service. You should see the following output:
Details on where Jira Software will be installed and the settings that will be used.
Installation Directory: /opt/atlassian/jira
Home Directory: /var/atlassian/application-data/jira
HTTP Port: 8080
RMI Port: 8005
Install as service: Yes
Install [i, Enter], Exit [e] i
Type i and hit Enter to start the installation. You should see the following output:
Please wait a few moments while Jira Software is configured.
Installation of Jira Software 8.11.0 is complete
Start Jira Software 8.11.0 now?
Type y and hit Enter to start Jira software. Once the installation has been finished successfully, you should see the following output:
Please wait a few moments while Jira Software starts up.
Launching Jira Software ...
Your installation of Jira Software 8.11.0 is now ready and can be accessed
via your browser.
Jira Software 8.11.0 can be accessed at http://localhost:8080
Finishing installation ...
At this point, Jira is installed in your server. You can now proceed to the next step.
Configure JIRA
Next, you will need to download the MySQL JDBC driver and copy it to the Jira installation directory. First, download it with the following command:
wget https://dev.mysql.com/get/Downloads/Connector-J/mysql-connector-java-8.0.18.zip
Next, unzip the downloaded file with the following command:
unzip mysql-connector-java-8.0.18.zip
Next, copy the MySQL connector with the following command:
cp mysql-connector-java-8.0.18/mysql-connector-java-8.0.18.jar /opt/atlassian/jira/lib
Next, stop and start the Jira service to apply the changes:
/etc/init.d/jira stop
/etc/init.d/jira start
Configure Proxy for JIRA
Next, you will need to define a proxy in Jira. If you want to access Jira using your domain. You can define it by editing the file /opt/atlassian/jira/conf/server.xml:
nano /opt/atlassian/jira/conf/server.xml
Find the following lines:
<Connector port="8080" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^`"<>"
maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false"/>
Replace them with the following lines:
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" scheme="http"
proxyName="jira.example.com" proxyPort="80"/>
Now, run the following command to apply the new configuration.
Configure Nginx as a Reverse Proxy for Jira
Next, you will need to configure the Nginx as a reverse proxy if you want to access Jira on port 80.
First, install the Nginx web server with the following command:
apt-get install nginx -y
Once the Nginx server is installed, create a new Nginx virtual host configuration file:
nano /etc/nginx/sites-available/jira.conf
server_name jira.example.com;
proxy_pass http://localhost:8080;
client_max_body_size 10M;
Save and close the file when you are finished. Then, activate the virtual host file with the following command:
ln -s /etc/nginx/sites-available/jira.conf /etc/nginx/sites-enabled/
Next, check the Nginx for any syntax error with the following command:
nginx -t
Finally, restart Jira and Nginx service to apply the changes:
systemctl nginx restart
Access Jira Web UI
Now, open your web browser and access the Jira web interface using the URL http://jira.example.com. You will be redirected to the following screen:
Jira web installer
Select “i’will set it up myself” and click on the Next button. You should see the following screen:
Database setup
Select “My Own Database“, provide your database details and click on the Next button. You should see the following screen:
Application properties
Provide your application title, Mode, URL and click on the Next button. You should see the following screen:
License key
Provide your trial license key and click on the Next button. You should see the following screen:
Admin account
Provide your administrator account details and click on the Next button. You should see the following screen:
Email notification
Click on the Finish button to complete the installation. You should see the language selection screen:
Language
Select your desired language and click on the Continue button. You should see the following screen:
Choose Avatar
Choose your avatar and click on the Next button. You should see the following screen:
Jira Dashboard
Click on “Create new project” to create your first project. You should see the following screen:
Create a project
Select “Scrum software development” and click on the Next button. You should see the following screen:
Click on the Select button to select your Workflow. You should see the following screen:
project name
Provide your project name and key, then click on the Submit button. You should see the Jira dashboard in the following screen:
Project Management in Jira
In the above guide, you learned how to install JIRA on Ubuntu 20.04. If you are not aware of how to install and use JIRA effectively then this guide will help you to install JIRA without any problem.
