How to Install InvoicePlane with Nginx on CentOS 7
InvoicePlane is a free and open source invoicing application. Its source code can be found on this Github. This tutorial will show you how to install InvoicePlane on a fresh CentOS 7 system.
  • WebServer (Apache, NGINX). This tutorial will use Nginx.
  • MySQL version 5.5 or greater or the equivalent version of MariaDB.
  • PHP version 7.0 or greater with the following PHP extensions installed and activated:
  • php-gd
  • php-hash
  • php-json
  • php-mbstring
  • php-mcrypt
  • php-mysqli
  • php-openssl
  • php-recode
  • php-xmlrpc
  • php-zlib
  • A server running CentOS 7.
Initial steps
Check your CentOS system version:
cat /etc/centos-release
# CentOS Linux release 7.6.1810 (Core)
Set up the timezone:
timedatectl list-timezones
Update your operating system’s packages:
sudo yum update -y
Install required packages:
sudo yum install -y vim wget curl git bash-completion unzip
Step 1 – Install PHP and required PHP extensions
InovicePlane web application requires PHP version 7.0.0 or greater. Default CentOS repositories contain older version of PHP, and thus we will need to set up a third-party repository to install a newer PHP version. We will use Webtatic repository.
Setup the Webtatic YUM repo:
sudo yum install -y php72w php72w-cli php72w-fpm php72w-common php72w-gd php72w-json php72w-mbstring php72w-mcrypt php72w-mysql php72w-xmlrpc php72w-recode
Check the PHP version:
php --version
# PHP 7.2.12 (cli) (built: Nov 11 2018 14:54:16) ( NTS )
# Zend Engine v3.2.0, Copyright (c) 1998-2018 Zend Technologies
Step 2 – Install MariaDB
Install MariaDB database server:
sudo yum install -y mariadb-server
Check the MariaDB version:
mysql --version
# mysql Ver 15.1 Distrib 5.5.60-MariaDB, for Linux (x86_64) using readline 5.1
Start and enable MariaDB service:
Run mysql_secure installation script to improve MariaDB security and set the password for MariaDB root user:
Set root password? [Y/n]: Y
Log into MariaDB shell as the user root:
mysql -u root -p
# Enter password
Create a MariaDB database and user that you will use for your installation of InvoicePlane, and remember the credentials:
CREATE DATABASE dbname;
FLUSH PRIVILEGES;
Exit from MariaDB shell:
quit
Step 3 – Install NGINX
Install Nginx web server:
sudo yum install -y nginx
Check the NGINX version:
nginx -v
# nginx version: nginx/1.12.2
Start and enable Nginx service:
Configure NGINX for InvoicePlane. Run sudo vim /etc/nginx/conf.d/invoiceplane.conf and populate the file with the following configuration:
listen [::]:80;
server_name example.com;
root /var/www/invoiceplane;
index index.php index.html;
location ~ .php$ {
fastcgi_index index.php;
try_files $uri =404;
include fastcgi_params;
fastcgi_pass 127.0.0.1:9000;
Test the NGINX configuration:
sudo nginx -t
Reload NGINX:
Step 4 – Install InvoicePlane
Download the latest stable version of InvoicePlane and extract the archive:
sudo mkdir -p /var/www
cd /var/www
sudo curl -O -J -L https://invoiceplane.com/download/v1.5.9
sudo unzip v1.5.9.zip
sudo rm v1.5.9.zip
sudo mv ip invoiceplane
Navigate to /var/www/invoiceplane folder:
cd /var/www/invoiceplane
Make a copy of the ipconfig.php.example file and rename the copy to ipconfig.php:
sudo cp ipconfig.php.example ipconfig.php
Open the ipconfig.php file and add your URL in it:
sudo vim ipconfig.php
# Something like this
IP_URL=http://example.com
Change ownership of the /var/www/invoiceplane directory to nginx:
sudo chown -R nginx:nginx /var/www/invoiceplane
Run sudo vim /etc/php-fpm.d/www.conf and set the user and group to nginx. Initially, they will be set to apache:
# user = nginx
# group = nginx
Run sudo vim /etc/php.ini and set date.timezone:
date.timezone = Region/City
Restart the PHP-FPM service:
Run the InvoicePlane installer from your web browser and follow the instructions:
http://example.com/index.php/setup
Once the installation has finished, you may log into InvoicePlane using the email address and password you have chosen during the installation.
If you want to secure your installation, you may disable the setup. To do so, replace the line DISABLE_SETUP=false with DISABLE_SETUP=true in your ipconfig.php file.
Step 5 – Complete the InvoicePlane setup
InvoicePlane is now installed and configured, it’s time to access their web installation wizard.
InvoicePlane web installer
Now, click on the Setup button. You should see the following page:
Choose language
Next, choose the language and click on the Continue button. You should see the following page:
Prerequisite check successful
Next, click on the Continue button. You should see the following page:
Database setup
Here, provide your database details and click on the Try Again button. You should see the following page:
Database has been set up.
Now, click on the Continue button. You should see the following page:
Create user
Installation complete
Now, provide all the required details, then click on the Continue button. Once the installation is completed, you should see the following page:
Log into InvoicePlane
Now, click on the Login button to access InvoicePlane administration.
